带有闹钟的电子时钟
查看数: 4253 | 评论数: 1 | 收藏 0
发布时间: 2016-9-6 22:11
带有闹钟的电子时钟 #include<reg52.h> #include<intrins.h> #define uint unsigned int #define uchar unsigned char uchar a,miao,shi,fen,ri,yue,nian,week,key1n,temp; uchar shi1,fen1=5,shi2, ...
ID:709315 发表于 2020-3-17 20:25
为什么我运行不了?提示是这样的错误......(我用的是Keil3)
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 0D1AH BYTE (163%) *
Program Size: data=39.1 xdata=0 code=3583
LINK/LOCATE RUN COMPLETE.  0 WARNING(S),  0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
    MODULE:  D:\KEIL\C51\LIB\C51S.LIB (-----)
    LIMIT:   0800H BYTES
Target not created
