现在把代码全都贴出来,求大神们帮我看看哪错了!十分感谢
查看数: 2577 | 评论数: 6 | 收藏 0
发布时间: 2016-12-21 22:40
#include<reg52.h> #define uchar unsigned char #define uint unsigned int uchar code table[4]={0xef,0xdf,0xbf,0x7f}; //位选码 uchar code table1[4]={0x3d,0x28,0x3c,0x61};//显示"锁 ...
ID:140371 发表于 2016-12-23 06:18
#include<reg52.h>
uchar code table[4]={0xef,0xdf,0xbf,0x7f}; //???
uchar code table1[4]={0x3d,0x28,0x3c,0x61};//??"?"?
uchar code table2[4]={0x28,0x70,0x30,0x68};//??"?"?
uchar code table3[4]={0x74,0x60,0xeb,0x3d};//??"??"?
uchar inbuf[4]={0x3d,0x28,0x3c,0x61};      //?????
uchar  pm[4]={1,2,3,4};//??
uchar inbuf[4],pmbuf[4];
uchar temp,enterflag,num2,count;
sbit sda=P3^5;
sbit scl=P3^4;
sbit D1=P3^7;   //???
sbit D2=P3^3;   //???
sbit D3=P3^6;   //???
void delayus()   //?????
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=120;y>0;y--);
void start()  //????
        sda=1;
        delayus();
        scl=1;
        delayus();
        sda=0;
        delayus();
void stop()   //????
        sda=0;
        delayus();
        scl=1;
        delayus();
        sda=1;
        delayus();
void respons()  //????
        uchar i;
        scl=1;
        delayus();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delayus();
void init()   //???
        sda=1;
        delayus();
        scl=1;
        delayus();
void write_byte(uchar date)  //???24c02???
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delayus();
                sda=CY;
                delayus();
                scl=1;
                delayus();
                delayus();
        scl=0;
        delayus();
        sda=1;
        delayus();
uchar read_byte()  //???24c02???
        uchar i,k;
        scl=0;
        delayus();
        sda=1;
        delayus();
        for(i=0;i<8;i++)
                scl=1;
                delayus();
                k=(k<<1)|sda;
                scl=0;
                delayus();
        return k;
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respons();
        write_byte(address);
        respons();
        write_byte(date);
        respons();
        stop();
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respons();
        respons();
        start();
        write_byte(0xa1);
        respons();
        date=read_byte();
        stop();
        return date;
void pmset()
        uchar i;
        for(i=0;i<4;i++)
                init();
                write_add(i,pmbuf[i]);
        delay(100);
        for(i=0;i<4;i++)
                init();
                pm[i]=read_add(i);
void readpm()
        uchar i;
        for(i=0;i<4;i++)
                init();
                pm[i]=read_add(i);
uchar pmcmp()
        char flag;
        char t,num1;
        t=0;
        num1=0;
        for(t=0;t<4;t++)
        if(pm[t]==pmbuf[t])
        num1++;
        if(num1==4)
        flag=1;
        else{ flag=0;t=4;}
        return(flag);
uchar keyscan()
        uchar num=0;
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                while(temp!=0xf0)
                        temp=P2;
                        switch(temp)
                        case 0xee:num=1;
                                break;
                        case 0xde:num=2;
                                break;
                        case 0xbe:num=3;
                                break;
                        case 0x7e:num=4;
                                break;
                        while(temp!=0xf0)
                                temp=P2;
                                temp=temp&0xf0;
        P2=0xfd;
        temp=P2;
        temp=temp&0xf0;
        while(temp!=0xf0)
                delay(10);
                temp=P2;
                temp=temp&0xf0;
                while(temp!=0xf0)
                        delay(10);
                        temp=P2;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                temp=P2;
                                switch(temp)
                                case 0xed:num=5;
                                        break;
                                case 0xdd:num=6;
                                        break;
                                case 0xbd:num=7;
                                        break;
                                case 0x7d:num=8;
                                        break;
                                while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
                P2=0xfb;
                temp=P2;
                temp=temp&0xf0;
                while(temp!=0xf0)
                        delay(10);
                        temp=P2;
                        temp=temp&0xf0;
                        while(temp!=0xf0)
                                temp=P2;
                                switch(temp)
                                case 0xeb:num=9;
                                        break;
                                case 0xdb:num=10;
                                        break;
                                case 0xbb:num=11;
                                        break;
                                case 0x7b:num=12;
                                        break;
                                while(temp!=0xf0)
                                        temp=P2;
                                        temp=temp&0xf0;
        return num;
{ uchar key,count,pmflag;
        uchar i,j;
        count=0;
        num2=0;
        enterflag=0;
        pmflag=0;
        readpm();
                for(i=0;i<4;i++)
                        P2=table[i];
                        P0=inbuf[i];
                        for(j=500;j>0;j--);
                P2=0xff;
                key=keyscan();
                switch(key)
                case 1:
                        if(count<4)
                        { inbuf[count]=0xf7;
                                pmbuf[count]=0;
                                count++;
                        break;
                case 2:
                        if(count<4)
                                pmbuf[count]=1;
                                count++;
                        break;
                case 3:
                        if(count<4)
                                pmbuf[count]=2;
                                count++;
                        count++;
                break;
        case 3:
                if(count<4)
                        pmbuf[count]=2;
                        count++;
                break;
case 4:
               if(count<4)
                       pmbuf[count]=3;
                         count++;
              break;
        case 5:
                if(count<4)
                        pmbuf[count]=4;
                        count++;
                break;
        case 6:
                if(count<4)
                        pmbuf[count]=5;
                        count++;
                break;
        case 7:
                if(count<4)
                        pmbuf[count]=6;
                        count++;
                break;
        case 8:
                if(count<4)
                        pmbuf[count]=7;
                        count++;
                break;
        case 9:
                if(count<4)
                        pmbuf[count]=8;
                        count++;
                break;
        case 10:
                if(count<4)
                        pmbuf[count]=9;
                        count++;
                break;
        case 11://
                { //if(count= =4)
        if(count==4)
                        {count=0;
                                pmset();
                        for(i=0;i<4;i++)
                        inbuf[i]=table1[i];
                        //break;
        break;
        case 12:
                { enterflag=1;
                        //if(count= =4)
        if(count==4)
                        pmflag=pmcmp();
                        else pmflag=0;
                        break;
        default:
                                         break;
       // if(enterflag= =1)
                                        if(enterflag==1)
        {  enterflag=0;
                count=0;
                for(i=0;i<4;i++)
                pmbuf[i]=0xf7;
                //if(pmflag= =1)
        if(pmflag==1)
                        P1=0xf0;
                        D3=0;
                        { for(i=0;i<4;i++)
                                        P2=table[i];
                                        P0=table2[i];
                                        for(j=500;j>0;j--);
                                //if(D2= =0)   //??
        if(D2==0)
                                { D3=1;
                                        P1=0xff;
                                        for(i=0;i<4;i++)
                                        inbuf[i]=table1[i];
                                        break;
                //if(pmflag= =0)
        if(pmflag==0)
                        num2++;
                        P1=0x0f;
                        for(i=0;i<4;i++)
                        inbuf[i]=table1[i];
                       // if(num2= =3)
        if(num2==3)
                                { P1=0;
                                        for(i=0;i<4;i++)
                                                for(j=500;j>0;j--);
                                                P2=table[i];
                                                P0=table3[i];
                                                for(j=500;j>0;j--);
                                                for(j=50;j>0;j--)
                                                D1=~D1;
                                        //if(D2= =0)    //??
        if(D2==0)
                                        {num2=0;
                                                P1=0xff;
                                                for(i=0;i<4;i++)
                                                inbuf[i]=table1[i];
                                                break;
ID:155507 发表于 2016-12-22 21:37
  1. #include<reg52.h>
  3. #define uint unsigned int
  4. uchar code table[4]={0xef,0xdf,0xbf,0x7f}; //位选码
  5. uchar code table1[4]={0x3d,0x28,0x3c,0x61};//显示"锁"字
  6. uchar code table2[4]={0x28,0x70,0x30,0x68};//显示"开"字
  7. uchar code table3[4]={0x74,0x60,0xeb,0x3d};//显示"失败"字
  8. uchar inbuf[4]={0x3d,0x28,0x3c,0x61};      //输入缓冲区
  9. uchar  pm[4]={1,2,3,4};//密码
  10. uchar inbuf[4],pmbuf[4];
  11. uchar temp,enterflag,num2,count;
  12. sbit sda=P3^5;
  13. sbit scl=P3^4;
  14. sbit D1=P3^7;   //蜂鸣器
  15. sbit D2=P3^3;   //复位键
  16. sbit D3=P3^6;   //继电器
  17. void delayus()   //延时几微秒
  18. { ;; }
  19. void delay(uint z)
  20. {
  21.         uint x,y;
  22.         for(x=z;x>0;x--)
  23.         for(y=120;y>0;y--);
  24. }
  25. void start()  //开始信号
  26. {
  27.         sda=1;
  28.         delayus();
  29.         scl=1;
  30.         delayus();
  31.         sda=0;
  32.         delayus();
  33. }
  34. void stop()   //停止信号
  35. {
  36.         sda=0;
  37.         delayus();
  38.         scl=1;
  39.         delayus();
  40.         sda=1;
  41.         delayus();
  42. }
  43. void respons()  //应答信号
  44. {
  45.         uchar i;
  46.         scl=1;
  47.         delayus();
  48.         while((sda==1)&&(i<250))i++;
  49.         scl=0;
  50.         delayus();
  51. }
  52. void init()   //初始化
  53. {
  54.         sda=1;
  55.         delayus();
  56.         scl=1;
  57.         delayus();
  58. }
  59. void write_byte(uchar date)  //主机向24c02写数据
  60. {
  61.         uchar i,temp;
  62.         temp=date;
  63.         for(i=0;i<8;i++)
  64.         {
  65.                 temp=temp<<1;
  66.                 scl=0;
  67.                 delayus();
  68.                 sda=CY;
  69.                 delayus();
  70.                 scl=1;
  71.                 delayus();
  72.                 delayus();
  73.         }
  74.         scl=0;
  75.         delayus();
  76.         sda=1;
  77.         delayus();
  78. }
  79. uchar read_byte()  //主机从24c02读数据
  80. {
  81.         uchar i,k;
  82.         scl=0;
  83.         delayus();
  84.         sda=1;
  85.         delayus();
  86.         for(i=0;i<8;i++)
  87.         {
  88.                 scl=1;
  89.                 delayus();
  90.                 k=(k<<1)|sda;
  91.                 scl=0;
  92.                 delayus();
  93.         }
  94.         return k;
  95. }
  96. void write_add(uchar address,uchar date)
  97. {
  98.         start();
  99.         write_byte(0xa0);
  100.         respons();
  101.         write_byte(address);
  102.         respons();
  103.         write_byte(date);
  104.         respons();
  105.         stop();
  106. }
  107. uchar read_add(uchar address)
  108. {
  109.         uchar date;
  110.         start();
  111.         write_byte(0xa0);
  112.         respons();
  113.         write_byte(address);
  114.         respons();
  115.         start();
  116.         write_byte(0xa1);
  117.         respons();
  118.         date=read_byte();
  119.         stop();
  120.         return date;
  121. }
  122. //****设置密码****//
  123. void pmset()
  124. {
  125.         uchar i;
  126.         for(i=0;i<4;i++)
  127.         {
  128.                 init();
  129.                 write_add(i,pmbuf[i]);
  130.         }
  131.         delay(100);
  132.         for(i=0;i<4;i++)
  133.         {
  134.                 init();
  135.                 pm[i]=read_add(i);
  136.         }
  137. }
  138. //****读取密码****//
  139. void readpm()
  140. {
  141.         uchar i;
  142.         for(i=0;i<4;i++)
  143.         {
  144.                 init();
  145.                 pm[i]=read_add(i);
  146.         }
  147. }
  148. //****密码比较****//
  149. uchar pmcmp()
  150. {
  151.         char flag;
  152.         char t,num1;
  153.         t=0;
  154.         num1=0;
  155.         for(t=0;t<4;t++)
  156.         if(pm[t]==pmbuf[t])
  157.         num1++;
  158.         if(num1==4)
  159.         flag=1;
  160.         else{ flag=0;t=4;}
  161.         return(flag);
  162. }
  163. //****键盘扫描****//
  164. uchar keyscan()
  165. {
  166.         uchar num=0;
  167.         temp=P2;
  168.         temp=temp&0xf0;
  169.         while(temp!=0xf0)
  170.         {
  171.                 delay(10);
  172.                 temp=P2;
  173.                 temp=temp&0xf0;
  174.                 while(temp!=0xf0)
  175.                 {
  176.                         temp=P2;
  177.                         switch(temp)
  178.                         {
  179.                         case 0xee:num=1;
  180.                                 break;
  181.                         case 0xde:num=2;
  182.                                 break;
  183.                         case 0xbe:num=3;
  184.                                 break;
  185.                         case 0x7e:num=4;
  186.                                 break;
  187.                         }
  188.                         while(temp!=0xf0)
  189.                         {
  190.                                 temp=P2;
  191.                                 temp=temp&0xf0;
  192.                         }
  193.                 }
  194.         }
  195.         P2=0xfd;
  196.         temp=P2;
  197.         temp=temp&0xf0;
  198.         while(temp!=0xf0)
  199.         {
  200.                 delay(10);
  201.                 temp=P2;
  202.                 temp=temp&0xf0;
  203.                 while(temp!=0xf0)
  204.                 {
  205.                         delay(10);
  206.                         temp=P2;
  207.                         temp=temp&0xf0;
  208.                         while(temp!=0xf0)
  209.                         {
  210.                                 temp=P2;
  211.                                 switch(temp)
  212.                                 {
  213.                                 case 0xed:num=5;
  214.                                         break;
  215.                                 case 0xdd:num=6;
  216.                                         break;
  217.                                 case 0xbd:num=7;
  218.                                         break;
  219.                                 case 0x7d:num=8;
  220.                                         break;
  221.                                 }
  222.                                 while(temp!=0xf0)
  223.                                 {
  224.                                         temp=P2;
  225.                                         temp=temp&0xf0;
  226.                                 }
  227.                         }
  228.                 }
  229.                 P2=0xfb;
  230.                 temp=P2;
  231.                 temp=temp&0xf0;
  232.                 while(temp!=0xf0)
  233.                 {
  234.                         delay(10);
  235.                         temp=P2;
  236.                         temp=temp&0xf0;
  237.                         while(temp!=0xf0)
  238.                         {
  239.                                 temp=P2;
  240.                                 switch(temp)
  241.                                 {
  242.                                 case 0xeb:num=9;
  243.                                         break;
  244.                                 case 0xdb:num=10;
  245.                                         break;
  246.                                 case 0xbb:num=11;
  247.                                         break;
  248.                                 case 0x7b:num=12;
  249.                                         break;
  250.                                 }
  251.                                 while(temp!=0xf0)
  252.                                 {
  253.                                         temp=P2;
  254.                                         temp=temp&0xf0;
  255.                                 }
  256.                         }
  257.                 }
  258.         }
  259.         return num;
  260. }
  261. //****主程序****//
  262. void main()
  263. { uchar key,count,pmflag;
  264.         uchar i,j;
  265.         count=0;
  266.         num2=0;
  267.         enterflag=0;
  268.         pmflag=0;
  269.         readpm();
  270.         while(1)
  271.         {
  272.                 for(i=0;i<4;i++)
  273.                 {
  274.                         P2=table[i];
  275.                         P0=inbuf[i];
  276.                         for(j=500;j>0;j--);
  277.                 }
  278.                 P2=0xff;
  279.                 key=keyscan();
  280.                 switch(key)
  281.                 {
  282.                 case 1:
  283.                         if(count<4)
  284.                         { inbuf[count]=0xf7;
  285.                                 pmbuf[count]=0;
  286.                                 count++;
  287.                         }
  288.                         break;
  289.                 case 2:
  290.                         if(count<4)
  291.                         { inbuf[count]=0xf7;
  292.                                 pmbuf[count]=1;
  293.                                 count++;
  294.                         }
  295.                         break;
  296.                 case 3:
  297.                         if(count<4)
  298.                         { inbuf[count]=0xf7;
  299.                                 pmbuf[count]=2;
  300.                                 count++;
  301.                         }
  302.                         count++;
  303.                 }
  304.                 break;
  305.                 /*
  306.         case 3:
  307.                 if(count<4)
  308.                 { inbuf[count]=0xf7;
  309.                         pmbuf[count]=2;
  310.                         count++;
  311.                 }
  312.                 break;
  313. */
  314.         case 4:
  315.                 if(count<4)
  316.                 { inbuf[count]=0xf7;
  317.                         pmbuf[count]=3;
  318.                         count++;
  319.                 }
  320.                 break;
  321.         case 5:
  322.                 if(count<4)
  323.                 { inbuf[count]=0xf7;
  324.                         pmbuf[count]=4;
  325.                         count++;
  326.                 }
  327.                 break;
  328.         case 6:
  329.                 if(count<4)
  330.                 { inbuf[count]=0xf7;
  331.                         pmbuf[count]=5;
  332.                         count++;
  333.                 }
  334.                 break;
  335.         case 7:
  336.                 if(count<4)
  337.                 { inbuf[count]=0xf7;
  338.                         pmbuf[count]=6;
  339.                         count++;
  340.                 }
  341.                 break;
  342.         case 8:
  343.                 if(count<4)
  344.                 { inbuf[count]=0xf7;
  345.                         pmbuf[count]=7;
  346.                         count++;
  347.                 }
  348.                 break;
  349.         case 9:
  350.                 if(count<4)
  351.                 { inbuf[count]=0xf7;
  352.                         pmbuf[count]=8;
  353.                         count++;
  354.                 }
  355.                 break;
  356.         case 10:
  357.                 if(count<4)
  358.                 { inbuf[count]=0xf7;
  359.                         pmbuf[count]=9;
  360.                         count++;
  361.                 }
  362.                 break;
  363.         case 11:  //设置键
  364.                 { if(count= =4)
  365.                         {count=0;
  366.                                 pmset();
  367.                         }
  368.                         for(i=0;i<4;i++)  //擦除缓冲区
  369.                         inbuf[i]=table1[i];
  370.                         break;
  371.                 }
  372.         case 12:     //确认键
  373.                 { enterflag=1;
  374.                         if(count= =4)
  375.                         pmflag=pmcmp();
  376.                         else pmflag=0;
  377.                         break;
  378.                 }
  379.         default:  break;
  380.         }
  381.         if(enterflag= =1)
  382.         {  enterflag=0;
  383.                 count=0;
  384.                 for(i=0;i<4;i++)
  385.                 pmbuf[i]=0xf7;
  386.                 if(pmflag= =1)
  387.                 {
  388.                         P1=0xf0;
  389.                         D3=0;
  390.                         while(1)
  391.                         { for(i=0;i<4;i++)
  392.                                 {
  393.                                         P2=table[i];
  394.                                         P0=table2[i];
  395.                                         for(j=500;j>0;j--);
  396.                                 }
  397.                                 if(D2= =0)   //复位
  398.                                 { D3=1;
  399.                                         P1=0xff;
  400.                                         for(i=0;i<4;i++)
  401.                                         inbuf[i]=table1[i];
  402.                                         break;
  403.                                 }
  404.                         }
  405.                 }
  406.                 if(pmflag= =0)
  407.                 {
  408.                         num2++;
  409.                         P1=0x0f;
  410.                         for(i=0;i<4;i++)
  411.                         inbuf[i]=table1[i];
  412.                         if(num2= =3)
  413.                         {
  414.                                 while(1)
  415.                                 { P1=0;
  416.                                         for(i=0;i<4;i++)
  417.                                         {
  418.                                                 for(j=500;j>0;j--);
  419.                                                 P2=table[i];
  420.                                                 P0=table3[i];
  421.                                                 for(j=500;j>0;j--);
  422.                                                 for(j=50;j>0;j--)
  423.                                                 D1=~D1;
  424.                                         }
  425.                                         if(D2= =0)    //复位
  426.                                         {num2=0;
  427.                                                 P1=0xff;
  428.                                                 for(i=0;i<4;i++)
  429.                                                 inbuf[i]=table1[i];
  430.                                                 break;
  431.                                         }
  432.                                 }
  433.                         }
  434.                 }
  435.         }
  436. }
ID:98767 发表于 2016-12-22 16:21
没错,括号的确是出了问题
ID:135369 发表于 2016-12-22 12:54
你这键盘扫描函数,层层嵌套,中括号可能有少或多的,恕我暂时手里没有电脑。只能推测
ID:135369 发表于 2016-12-22 12:48
手上没电脑,用手机看你这代码特蛋疼!!!
ID:156796 发表于 2016-12-22 11:01
这叫人怎么要看。。。起码要知道那一块有问题吧、
