查看: 3671|回复: 5
用stm32C8t6控制DS18B20
ID:171057 发表于 2017-5-4 16:52 | 显示全部楼层 |阅读模式
1000黑币
ID:171057 发表于 2017-5-4 16:53 | 显示全部楼层
只要程序!!!!加急!!!求压缩包!!!
ID:82765 发表于 2017-5-4 17:00 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
ID:171057 发表于 2017-5-5 08:53 | 显示全部楼层
cjjcjj1 发表于 2017-5-4 17:00
给你一个参考一下吧
#include "stdio.h" // printf用
/****************************************Copyright (c)****************************************************
**--------------File Info---------------------------------------------------------------------------------
** File name:
** Last modified Date:
** Last Version:
** Descriptions:
** Created by:                        FiYu
** Created date:                2015-12-12
** Version:                            1.0
** Descriptions:                DS18B20温度传感器实验
** Modified by:                        FiYu
** Modified date:
** Version:
** Descriptions:
** Rechecked by:
/****-----请阅读ReadMe.txt进行实验-----***********/
#include "stm32f10x.h"
#include "delay.h"
#include "ds18b20.h"
#include "usart.h"
int n;
* 描  述 : GPIO/USART1初始化配置
* 入  参 : 无
* 返回值 : 无
void GPIO_Configuration(void)
        /* Enable the GPIO_LED Clock */
        RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_AFIO , ENABLE);
  GPIO_DeInit(GPIOB);         //将外设GPIOA寄存器重设为缺省值
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
        GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;    //推挽输出
        GPIO_Init(GPIOB, &GPIO_InitStructure);
        GPIO_DeInit(GPIOA);         //将外设GPIOA寄存器重设为缺省值
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;    //推挽输出
        GPIO_Init(GPIOA, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;    //浮空输入
        GPIO_SetBits(GPIOB , GPIO_Pin_9);   //初始状态,熄灭指示灯LED1
* 描  述 : MAIN函数
* 入  参 : 无
* 返回值 : 无
int main(void)
        SystemInit();                        //设置系统时钟72MHZ
        GPIO_Configuration();
        USART1_Init();    //初始化配置TIM
        GPIO_ResetBits(GPIOB , GPIO_Pin_2);
        delay_ms(500);
        while( DS18B20_Init())
                printf("\r\n no ds18b20 exit \r\n");
                GPIO_SetBits(GPIOB , GPIO_Pin_2);
        printf("\r\n ds18b20 exit \r\n");
        for(;;)
                n=DS18B20_Get_Temp();
                printf("\r\n temperature %.1f\r\n",DS18B20_Get_Temp());
                delay_ms(1500);                     // 1.5s 读取一次温度值
/*********************************END FILE***********************************/
这么写对么??
ID:170270 发表于 2017-5-5 11:32 | 显示全部楼层
加我QQ 2944428743 给你发程序
ID:170270 发表于 2017-5-5 11:37 | 显示全部楼层
#ifndef __DS18B20_H
#define __DS18B20_H
#include "sys.h"
//IO方向设置
#define DS18B20_IO_IN()  {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=8<<0;}
#define DS18B20_IO_OUT() {GPIOA->CRL&=0XFFFFFFF0;GPIOA->CRL|=3<<0;}
////IO操作函数
#define        DS18B20_DQ_OUT PAout(0) //数据端口        PA0
#define        DS18B20_DQ_IN  PAin(0)  //数据端口        PA0
u8 DS18B20_Init(void);                        //初始化DS18B20
short DS18B20_Get_Temp(void);        //获取温度
void DS18B20_Start(void);                //开始温度转换
void DS18B20_Write_Byte(u8 dat);//写入一个字节
u8 DS18B20_Read_Byte(void);                //读出一个字节
u8 DS18B20_Read_Bit(void);                //读出一个位
u8 DS18B20_Check(void);                        //检测是否存在DS18B20
void DS18B20_Rst(void);                        //复位DS18B20
#endif
#include "delay.h"
//复位DS18B20
        DS18B20_IO_OUT(); //SET PA0 OUTPUT
    DS18B20_DQ_OUT=0; //拉低DQ
    delay_us(750);    //拉低750us
    DS18B20_DQ_OUT=1; //DQ=1
        delay_us(15);     //15US
//等待DS18B20的回应
//返回1:未检测到DS18B20的存在
//返回0:存在
        u8 retry=0;
        DS18B20_IO_IN();//SET PA0 INPUT
    while (DS18B20_DQ_IN&&retry<200)
                retry++;
                delay_us(1);
        if(retry>=200)return 1;
        else retry=0;
    while (!DS18B20_DQ_IN&&retry<240)
                retry++;
                delay_us(1);
        if(retry>=240)return 1;
        return 0;
//从DS18B20读取一个位
//返回值:1/0
u8 DS18B20_Read_Bit(void)                          // read one bit
    u8 data;
        DS18B20_IO_OUT();//SET PA0 OUTPUT
    DS18B20_DQ_OUT=0;
        delay_us(2);
    DS18B20_DQ_OUT=1;
        delay_us(12);
        if(DS18B20_DQ_IN)data=1;
    else data=0;
    delay_us(50);
    return data;
//从DS18B20读取一个字节
//返回值:读到的数据
u8 DS18B20_Read_Byte(void)    // read one byte
    u8 i,j,dat;
    dat=0;
        for (i=1;i<=8;i++)
        j=DS18B20_Read_Bit();
        dat=(j<<7)|(dat>>1);
    return dat;
//写一个字节到DS18B20
//dat:要写入的字节
    u8 j;
    u8 testb;
        DS18B20_IO_OUT();//SET PA0 OUTPUT;
    for (j=1;j<=8;j++)
        testb=dat&0x01;
        dat=dat>>1;
        if (testb)
            DS18B20_DQ_OUT=0;// Write 1
            delay_us(2);
            DS18B20_DQ_OUT=1;
            delay_us(60);
            DS18B20_DQ_OUT=0;// Write 0
            delay_us(60);
            DS18B20_DQ_OUT=1;
            delay_us(2);
//开始温度转换
void DS18B20_Start(void)// ds1820 start convert
    DS18B20_Rst();
        DS18B20_Check();
    DS18B20_Write_Byte(0xcc);// skip rom
    DS18B20_Write_Byte(0x44);// convert
//初始化DS18B20的IO口 DQ 同时检测DS的存在
//返回1:不存在
//返回0:存在
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA, ENABLE);         //使能PORTA口时钟
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;                                //PORTA0 推挽输出
        GPIO_SetBits(GPIOA,GPIO_Pin_0);    //输出1
        DS18B20_Rst();
        return DS18B20_Check();
//从ds18b20得到温度值
//精度:0.1C
//返回值:温度值 (-550~1250)
    u8 temp;
    u8 TL,TH;
        short tem;
    DS18B20_Start ();                    // ds1820 start convert
    DS18B20_Rst();
    DS18B20_Check();
    DS18B20_Write_Byte(0xbe);// convert
    TL=DS18B20_Read_Byte(); // LSB
    TH=DS18B20_Read_Byte(); // MSB
    if(TH>7)
        TH=~TH;
        TL=~TL;
        temp=0;//温度为负
    }else temp=1;//温度为正
    tem=TH; //获得高八位
    tem<<=8;
    tem+=TL;//获得底八位
    tem=(float)tem*0.625;//转换
        if(temp)return tem; //返回温度值
        else return -tem;
int main(void)
        short temperature;
          DS18B20_Init();
                temperature=DS18B20_Get_Temp();
