查看: 6368|回复: 9
指纹模块51单片机程序
ID:123163 发表于 2016-5-25 17:19 | 显示全部楼层 回帖奖励 |倒序浏览 |阅读模式
指纹模块 51程序
  1. #include "MAIN.h"
  2. #include "UART.h"
  3. volatile unsigned char FPMXX_RECEICE_BUFFER[24];
  4. //FINGERPRINT通信协议定义
  5. code unsigned char FPMXX_Pack_Head[6] = {0xEF,0x01,0xFF,0xFF,0xFF,0xFF};  //协议包头
  6. code unsigned char FPMXX_Get_Img[6] = {0x01,0x00,0x03,0x01,0x0,0x05};    //获得指纹图像
  7. code unsigned char FPMXX_Get_Templete_Count[6] ={0x01,0x00,0x03,0x1D,0x00,0x21 }; //获得模版总数
  8. code unsigned char FP_Search[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x03,0xA1,0x0,0xB2}; //搜索指纹搜索范围0 - 929
  9. code unsigned char FP_Search_0_9[11]={0x01,0x0,0x08,0x04,0x01,0x0,0x0,0x0,0x13,0x0,0x21}; //搜索0-9号指纹
  10. code unsigned char FP_Img_To_Buffer1[7]={0x01,0x0,0x04,0x02,0x01,0x0,0x08}; //将图像放入到BUFFER1
  11. code unsigned char FP_Img_To_Buffer2[7]={0x01,0x0,0x04,0x02,0x02,0x0,0x09}; //将图像放入到BUFFER2
  12. code unsigned char FP_Reg_Model[6]={0x01,0x0,0x03,0x05,0x0,0x09}; //将BUFFER1跟BUFFER2合成特征模版
  13. code unsigned char FP_Delet_All_Model[6]={0x01,0x0,0x03,0x0d,0x00,0x11};//删除指纹模块里所有的模版
  14. volatile unsigned char  FP_Save_Finger[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19};//将BUFFER1中的特征码存放到指定的位置
  15. volatile unsigned char FP_Delete_Model[10]={0x01,0x00,0x07,0x0C,0x0,0x0,0x0,0x1,0x0,0x0}; //删除指定的模版
  16. //volatile unsigned char FINGER_NUM;
  17. /*------------------ FINGERPRINT命令字 --------------------------*/
  18. void FPMXX_Cmd_Send_Pack_Head(void) //发送包头
  19. {
  20.                 int i;
  21.
  22.                 for(i=0;i<6;i++) //包头
  23.     {
  24.       UART_Send_Byte(FPMXX_Pack_Head[i]);
  25.     }
  26. }
  27. //FINGERPRINT_获得指纹图像命令
  28. void FPMXX_Cmd_Get_Img(void)
  29. {
  30.     unsigned char i;
  31.     FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  32.
  33.     for(i=0;i<6;i++) //发送命令 0x1d
  34.        UART_Send_Byte(FPMXX_Get_Img[i]);
  35. }
  36. //讲图像转换成特征码存放在Buffer1中
  37. void FINGERPRINT_Cmd_Img_To_Buffer1(void)
  38. {
  39.             unsigned char i;
  40.
  41.                FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  42.
  43.                       for(i=0;i<7;i++)   //发送命令 将图像转换成 特征码 存放在 CHAR_buffer1
  44.              {
  45.                          UART_Send_Byte(FP_Img_To_Buffer1[i]);
  46.                         }
  47. }
  48. //将图像转换成特征码存放在Buffer2中
  49. void FINGERPRINT_Cmd_Img_To_Buffer2(void)
  50. {
  51.      unsigned char i;
  52.            for(i=0;i<6;i++)    //发送包头
  53.                  {
  54.                    UART_Send_Byte(FPMXX_Pack_Head[i]);
  55.                         }
  56.
  57.                       for(i=0;i<7;i++)   //发送命令 将图像转换成 特征码 存放在 CHAR_buffer1
  58.              {
  59.                          UART_Send_Byte(FP_Img_To_Buffer2[i]);
  60.                         }
  61. }
  62. //将BUFFER1 跟 BUFFER2 中的特征码合并成指纹模版
  63. void FINGERPRINT_Cmd_Reg_Model(void)
  64. {
  65.     unsigned char i;
  66.     for(i=0;i<6;i++) //包头
  67.     {
  68.       UART_Send_Byte(FPMXX_Pack_Head[i]);
  69.     }
  70.     for(i=0;i<6;i++) //命令合并指纹模版
  71.     {
  72.       UART_Send_Byte(FP_Reg_Model[i]);
  73.     }
  74. }
  75. //删除指纹模块里的所有指纹模版
  76. void FINGERPRINT_Cmd_Delete_All_Model(void)
  77. {
  78.      unsigned char i;
  79.     for(i=0;i<6;i++) //包头
  80.       UART_Send_Byte(FPMXX_Pack_Head[i]);
  81.     for(i=0;i<6;i++) //命令合并指纹模版
  82.       UART_Send_Byte(FP_Delet_All_Model[i]);
  83. }
  84. //删除指纹模块里的指定指纹模版
  85. void FINGERPRINT_Cmd_Delete_Model(unsigned int uiID_temp)
  86. {
  87.     volatile unsigned int uiSum_temp = 0;
  88.         unsigned char i;
  89.
  90.         FP_Delete_Model[4]=(uiID_temp&0xFF00)>>8;
  91.         FP_Delete_Model[5]=(uiID_temp&0x00FF);
  92.
  93.         for(i=0;i<8;i++)
  94.             uiSum_temp = uiSum_temp + FP_Delete_Model[i];
  95.
  96.         //UART0_Send_Byte(uiSum_temp);
  97.
  98.         FP_Delete_Model[8]=(uiSum_temp&0xFF00)>>8;
  99.         FP_Delete_Model[9]=uiSum_temp&0x00FF;
  100.
  101.     for(i=0;i<6;i++) //包头
  102.       UART_Send_Byte(FPMXX_Pack_Head[i]);
  103.     for(i=0;i<10;i++) //命令合并指纹模版
  104.       UART_Send_Byte(FP_Delete_Model[i]);
  105. }
  106. //获得指纹模板数量
  107. void FINGERPRINT_Cmd_Get_Templete_Num(void)
  108. {  unsigned int i;
  109.    unsigned char temp[14];
  110.          FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  111.    //发送命令 0x1d
  112.    for(i=0;i<6;i++)
  113.      UART_Send_Byte(FPMXX_Get_Templete_Count[i]);
  114.
  115.
  116. }
  117. //搜索全部用户999枚
  118. void FINGERPRINT_Cmd_Search_Finger(void)
  119. {
  120.        unsigned char i;
  121.
  122.                          FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  123.        for(i=0;i<11;i++)
  124.            {
  125.                   UART_Send_Byte(FP_Search[i]);
  126.                       }
  127. }
  128. //搜索全部用户999枚
  129. void FINGERPRINT_Cmd_Search_Finger_Admin(void)
  130. {
  131.        unsigned char i;
  132.
  133.              FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  134.        for(i=0;i<11;i++)
  135.            {
  136.                   UART_Send_Byte(FP_Search_0_9[i]);
  137.                       }
  138. }
  139. void FINGERPRINT_Cmd_Save_Finger( unsigned char ucH_Char,unsigned char ucL_Char )
  140. {
  141.            unsigned long temp = 0;
  142.                    unsigned char i;
  143. //           SAVE_FINGER[9]={0x01,0x00,0x06,0x06,0x01,0x00,0x0B,0x00,0x19};//将BUFFER1中的特征码存放到指定的位置
  144.            FP_Save_Finger[5] = ucH_Char;
  145.            FP_Save_Finger[6] = ucL_Char;
  146.
  147.                    for(i=0;i<7;i++)   //计算校验和
  148.                               temp = temp + FP_Save_Finger[i];
  149.
  150.                    FP_Save_Finger[7]=(temp & 0x00FF00) >> 8; //存放校验数据
  151.                    FP_Save_Finger[8]= temp & 0x0000FF;
  152.
  153.           FPMXX_Cmd_Send_Pack_Head(); //发送通信协议包头
  154.
  155.            for(i=0;i<9;i++)
  156.                          UART_Send_Byte(FP_Save_Finger[i]);      //发送命令 将图像转换成 特征码 存放在 CHAR_buffer1
  157. }
  158. //接收反馈数据缓冲
  159. void FPMXX_Receive_Data(unsigned char ucLength)
  160. {
  161.   unsigned char i;
  162.   for (i=0;i<ucLength;i++)
  163.      FPMXX_RECEICE_BUFFER[i] = UART_Receive_Byte();
  164. }
  165. /*
  166. //指纹添加新用户
  167. unsigned char FP_add_new_user(unsigned char ucH_user,unsigned char ucL_user)
  168. {
  169.
  170.                        do {
  171.                     FINGERPRINT_Cmd_Get_Img(); //获得指纹图像
  172.                         FINGERPRINT_Recevice_Data(12); //接收12个长度的反馈码
  173.                   }
  174.                while ( UART1_FINGERPRINT_RECEVICE_BUFFER[9]!=0x0 ); //检测是否成功的按了指纹
  175.                                    FINGERPRINT_Cmd_Img_To_Buffer1(); //将图像转换成特征码存放在Buffer1中
  176.                          FINGERPRINT_Recevice_Data(12);   //接收12个长度的反馈码
  177.                 do{
  178.                                      FINGERPRINT_Cmd_Get_Img(); //获得指纹图像
  179.                                      FINGERPRINT_Recevice_Data(12); //接收12个长度的反馈码
  180.                                  }
  181.                                  while( UART1_FINGERPRINT_RECEVICE_BUFFER[9]!=0x0 );
  182.
  183.                                  FINGERPRINT_Cmd_Img_To_Buffer2(); //将图像转换成特征码存放在Buffer2中
  184.                          FINGERPRINT_Recevice_Data(12);   //接收12个长度的反馈码
  185.                                  FP_Cmd_Reg_Model();//转换成特征码
  186.                  FINGERPRINT_Recevice_Data(12);
  187.
  188.                                  FINGERPRINT_Cmd_Save_Finger(ucH_user,ucL_user);
  189.                  FINGERPRINT_Recevice_Data(12);
  190.
  191.                          return 0;
  192. }
  193. */
FPMXX_Test_C51_Soures.rar
40.47 KB, 下载次数: 98, 下载积分: 黑币 -5
