STM32F103 使用 IO 口驱动 320240 TFT(ILI9325) 液晶屏头文件+函数文件。分享给大家,希望对大家有用。
完整源码下载:
ILI9325.rar
(7.13 KB, 下载次数: 128)
主程序:
- #include "mILI9325.h"
- #include "mFONT.h"
- extern mDis_Color ILI9325;
- GPIO_InitTypeDef GPIO_InitStructure;
- //Red Gray scale灰阶(65K)
- const unsigned char RedGrayScale[]={
- 0x00,0x00, 0x08,0x00, 0x10,0x00, 0x18,0x00, 0x20,0x00, 0x28,0x00, 0x30,0x00, 0x38,0x00,
- 0x40,0x00, 0x48,0x00, 0x50,0x00, 0x58,0x00, 0x60,0x00, 0x68,0x00, 0x70,0x00, 0x78,0x00,
- 0x80,0x00, 0x88,0x00, 0x90,0x00, 0x98,0x00, 0xA0,0x00, 0xA8,0x00, 0xB0,0x00, 0xB8,0x00,
- 0xC0,0x00, 0xC8,0x00, 0xD0,0x00, 0xD8,0x00, 0xE0,0x00, 0xE8,0x00, 0xF0,0x00, 0xF8,0x00,
- //Green Gray scale灰阶(65K)
- const unsigned char GreenGrayScale[]={
- 0x00,0x00, 0x00,0x60, 0x00,0xA0, 0x00,0xE0, 0x01,0x00, 0x01,0x60, 0x01,0xA0, 0x01,0xE0,
- 0x02,0x00, 0x02,0x60, 0x02,0xA0, 0x02,0xE0, 0x03,0x00, 0x03,0x60, 0x03,0xA0, 0x03,0xE0,
- 0x04,0x00, 0x04,0x60, 0x04,0xA0, 0x04,0xE0, 0x05,0x00, 0x05,0x60, 0x05,0xA0, 0x05,0xE0,
- 0x06,0x00, 0x06,0x60, 0x06,0xA0, 0x06,0xE0, 0x07,0x00, 0x07,0x60, 0x07,0xA0, 0x07,0xE0,
- //Blue Gray scale灰阶(65K)
- const unsigned char BlueGrayScale[]={
- 0x00,0x00, 0x00,0x01, 0x00,0x02, 0x00,0x03, 0x00,0x04, 0x00,0x05, 0x00,0x06, 0x00,0x07,
- 0x00,0x08, 0x00,0x09, 0x00,0x0A, 0x00,0x0B, 0x00,0x0C, 0x00,0x0D, 0x00,0x0E, 0x00,0x0F,
- 0x00,0x10, 0x00,0x11, 0x00,0x12, 0x00,0x13, 0x00,0x14, 0x00,0x15, 0x00,0x16, 0x00,0x17,
- 0x00,0x18, 0x00,0x19, 0x00,0x1A, 0x00,0x1B, 0x00,0x1C, 0x00,0x1D, 0x00,0x1E, 0x00,0x1F,
- //White Gray scale灰阶(65K)
- const unsigned char WhiteGrayScale[]={
- 0x00,0x00, 0x08,0x61, 0x10,0xA2, 0x18,0xE3, 0x21,0x04, 0x29,0x65, 0x31,0xA6, 0x39,0xE7,
- 0x42,0x08, 0x4A,0x69, 0x52,0xAA, 0x5A,0xEB, 0x63,0x0C, 0x6B,0x6D, 0x73,0xAE, 0x7B,0xEF,
- 0x84,0x10, 0x8C,0x71, 0x94,0xB2, 0x9C,0xF3, 0xA5,0x14, 0xAD,0x75, 0xB5,0xB6, 0xBD,0xF7,
- 0xC6,0x18, 0xCE,0x79, 0xD6,0xBA, 0xDE,0xFB, 0xE7,0x1C, 0xEF,0x7D, 0xF7,0xBE, 0xFF,0xFF,
- * Function Name : Delay_mS
- * Description : 延时功能函数
- * Input : nCount 延时值( mS )
- * Output : None
- * Return : None
- void Delay_mS (uint16_t nCount){
- unsigned int i;
- do{
- for(i=0; i<5000; i++);
- while(nCount--);
- * Function Name : Delay_uS
- * Input : nCount 延时值( uS )
- * Output : None
- * Return : None
- void Delay_uS (uint16_t nCount){
- unsigned int i;
- do{
- for(i=0; i<5; i++);
- }while(nCount--);
- * Function Name : ILI9325_CtrlLinesConfig
- * Description : Configures LCD control lines in Output Push-Pull mode.
- * Input : None
- * Output : None
- * Return : None
- void ILI9325_Reset(void){
- //对TFT进行复位一次
- ILI9325_RESET_HIGH();
- Delay_mS(50);
- ILI9325_RESET_LOW();
- Delay_mS(100);
- Delay_mS(50);
- * Function Name : ILI9325_CtrlLinesConfig 控制线配置
- * Input : None
- * Output : None
- * Return : None
- void ILI9325_CtrlLinesConfig(void) {
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOB, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOD, ENABLE);
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOE, ENABLE);
- /* Configure PD.7--PD.11 as Output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_LCD_CS | GPIO_LCD_RS | GPIO_LCD_WR | GPIO_LCD_RD |
- GPIO_LCD_PW ;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- GPIO_InitStructure.GPIO_Pin = GPIO_LCD_RESET;
- GPIO_Init(GPIOE, &GPIO_InitStructure);
- /* Configure PE.00 -- PE.15 as Output push-pull */
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
- GPIO_Init(GPIOD, &GPIO_InitStructure);
- * Function Name : ILI9325_WriteIndex
- * Description : 寻址寄存器
- * Input : Index
- * Output : None
- * Return : None
- void ILI9325_WriteIndex(uint8_t Index) {
- //写索引寄存器
- ILI9325_RS_LOW();
- ILI9325_CS_LOW();
- ILI9325_RD_HIGH();
- GPIO_Write(GPIOD,Index);
- ILI9325_WR_LOW();
- ILI9325_WR_HIGH();
- ILI9325_CS_HIGH();
- * Function Name : ILI9325_WriteData
- * Description :
- * Input : Data
- * Output : None
- * Return : None
- void ILI9325_WriteData(uint16_t Data) {
- ILI9325_RS_HIGH();
- ILI9325_CS_LOW();
- GPIO_Write(GPIOD,Data);
- ILI9325_WR_LOW();
- * Function Name : ILI9325_ReadData
- * Description :
- * Input : None
- * Output : None
- * Return : None
- uint16_t ILI9325_ReadData(void) {
- unsigned short Data=0;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
- ILI9325_CS_LOW();
- //丢掉第一次读出的不确定数
- ILI9325_RD_LOW();
- Data = GPIO_ReadInputData(GPIOD);
- ILI9325_RD_LOW();
- return Data;
- * Function Name : ILI9325_WriteReg
- * Description : Writes to the selected LCD register.
- * Input : - LCD_Reg: address of the selected register.
- * - LCD_RegValue: value to write to the selected register.
- * Output : None
- * Return : None
- /*void ILI9325_WriteReg(unsigned char LCD_Reg, unsigned short LCD_RegValue) {
- //写索引寄存器
- ILI9325_WriteIndex(unsigned char LCD_Reg);
- //向所寻寄存器中写入值
- ILI9325_WriteData(unsigned short LCD_RegValue);
- void ILI9325_WriteReg(uint8_t LCD_Reg, uint16_t LCD_RegValue) {
- //写索引寄存器
- ILI9325_RS_LOW();
- ILI9325_CS_LOW();
- GPIO_Write(GPIOD,LCD_Reg);
- ILI9325_WR_LOW();
- //向所寻寄存器中写入值
- ILI9325_CS_LOW();
- GPIO_Write(GPIOD,LCD_RegValue);
- ILI9325_WR_LOW();
- * Function Name : ILI9325_BackLight(
- * Description : LCD 背景灯状态设置.
- * Input : - State: 背景灯状态 ON 或者 OFF
- * Output : None
- * Return : None
- void ILI9325_BackLight(uint8_t State) {
- if(State == ON)
- ILI9325_PW_HIGH();
- else
- ILI9325_PW_LOW();
- * Function Name : ILI9325_WriteGRAM
- * Description : Writes to the LCD RAM.
- * Input : - RGB_Code: the pixel color in RGB mode (5-6-5).
- * Output : None
- * Return : None
- void ILI9325_WriteGRAM(uint16_t RGB_Code) {
- ILI9325_WriteReg(R22,RGB_Code);
- * Function Name : ILI9325_Init
- * Description : Initializes LCD.
- * Input : None
- * Output : None
- * Return : None
- void ILI9325_Init(void) {
- //Driver IC:ILI9325
- ILI9325_CtrlLinesConfig(); //TFT的系统接口配置(本TFT模块采用的是i80 16-bit System Bus)
- ILI9325_Reset(); //复位一次
- //ILI9325_WriteReg(0x00E3, 0x3008);
- //ILI9325_WriteReg(0x00E7, 0x0012);
- //ILI9325_WriteReg(0x00EF, 0x1231);
- ILI9325_WriteReg(0x00E5, 0x78F0);
- /*其中的SM位配合R96中的GS位,来决定图像刷新方向。本配置为从上到下
- SM GS=00从下到上 SM GS=01从上到下 SM GS=10 从右到左 SM GS=11 从左到右*/
- ILI9325_WriteReg(R1, 0x0100);//R1:驱动输出控制
- ILI9325_WriteReg(R2, 0x0700);//line inversion
- /*GRAM水平方向更新*/
- ILI9325_WriteReg(R3, 0x1018);//R3:数据进入模式设置 1030
- /*保持原图像大小*/
- ILI9325_WriteReg(R4, 0x0000);//R4:可将原图像缩小到1/2或1/4来显示
- /*****************Display Control*******************/
- ILI9325_WriteReg(R8, 0x0202);//0207
- ILI9325_WriteReg(R9, 0x0000);
- ILI9325_WriteReg(R0A, 0x0000);
- ILI9325_WriteReg(R0C, 0x0000);
- ILI9325_WriteReg(R0D, 0x0000);
- ILI9325_WriteReg(R0F, 0x0000);
- /***************Power Control*********************/
- ILI9325_WriteReg(R10, 0x0000);
- ILI9325_WriteReg(R11, 0x0007);//0004
- ILI9325_WriteReg(R12, 0x0000);
- ILI9325_WriteReg(R13, 0x0000);
- ILI9325_WriteReg(R7, 0x0000);
- Delay_mS(200);
- ILI9325_WriteReg(R10, 0x1690);
- ILI9325_WriteReg(R11, 0x0227);//0224
- Delay_mS(50);
- ILI9325_WriteReg(R12, 0x009d);//001b
- Delay_mS(50);
- ILI9325_WriteReg(R13, 0x1900);//1100
- ILI9325_WriteReg(R29, 0x0025);//0008
- ILI9325_WriteReg(R2B, 0x000d);
- Delay_mS(50);
- //默认显示坐标(0,0)
- ILI9325_WriteReg(R20, 0x0000);
- ILI9325_WriteReg(R21, 0x0000);
- /**************Gamma Control***********/
- ILI9325_WriteReg(R30, 0x0007);
- ILI9325_WriteReg(R31, 0x0303);
- ILI9325_WriteReg(R32, 0x0003);
- ILI9325_WriteReg(R35, 0x0206);
- ILI9325_WriteReg(R36, 0x0008);
- ILI9325_WriteReg(R37, 0x0406);
- ILI9325_WriteReg(R38, 0x0304);
- ILI9325_WriteReg(R39, 0x0007);
- ILI9325_WriteReg(R3C, 0x0602);
- ILI9325_WriteReg(R3D, 0x0008);
- /********Sets display window,默认为整个屏幕********/
- ILI9325_WriteReg(R50, 0x0000);
- ILI9325_WriteReg(R51, 0x00ee);
- ILI9325_WriteReg(R52, 0x0000);
- ILI9325_WriteReg(R53, 0x013f);
- /*******Gate Scan Control*************************/
- ILI9325_WriteReg(R60, 0xa700);
- ILI9325_WriteReg(R61, 0x0001);
- ILI9325_WriteReg(R6A, 0x0000);
- /********Partial Image Display Position Control***/
- ILI9325_WriteReg(R80, 0x0000);
- ILI9325_WriteReg(R81, 0x0000);
- ILI9325_WriteReg(R82, 0x0000);
- ILI9325_WriteReg(R83, 0x0000);
- ILI9325_WriteReg(R84, 0x0000);
- ILI9325_WriteReg(R85, 0x0000);
- /*******Panel Interface Control******************/
- ILI9325_WriteReg(R90, 0x0010);
- ILI9325_WriteReg(R92, 0x0600);
- ILI9325_WriteReg(R7, 0x0133);
- ILI9325_WriteReg(R0, 0x0022);
- ILI9325.TextColor = 0x0000;
- ILI9325.BackColor = 0x667F;
- ILI9325_FillSCR(ILI9325.BackColor);
- ILI9325_BackLight(ON);
- * Function Name : ILI9325_SetDisplayWindow
- * Description : 设置显示窗口
- * Input : - startx: specifies the X buttom left position.
- * - starty: specifies the Y buttom left position.
- * - endx: display window width.
- * - endy: display window height.
- * Output : None
- * Return : None
- void ILI9325_SetDisplayWindow(uint16_t startx, uint16_t starty, uint16_t endx, uint16_t endy) {
- // 顺转90度
- ILI9325_WriteReg(R50, starty);
- ILI9325_WriteReg(R51, endy);
- ILI9325_WriteReg(R52, 319-endx);
- ILI9325_WriteReg(R53, 319-startx);
- ILI9325_WriteReg(R20, endy);
- ILI9325_WriteReg(R21, 319-endx);
- /*// 逆转90度
- ILI9325_WriteReg(R50, 239-endy);
- ILI9325_WriteReg(R51, 239-starty);
- ILI9325_WriteReg(R52, startx);
- ILI9325_WriteReg(R53, endx);
- ILI9325_WriteReg(R20, 239-starty);
- ILI9325_WriteReg(R21, startx);
- * Function Name : ILI9325_EnterSleep
- * Description : LCD 进入休眠模式
- * Input : None
- * Output : None
- * Return : None
- void ILI9325_EnterSleep(void) {
- ILI9325_WriteReg(R7, 0x0131);
- Delay_mS(10);
- ILI9325_WriteReg(R7, 0x0130);
- Delay_mS(10);
- ILI9325_WriteReg(R10, 0x0080);
- ILI9325_WriteReg(R11, 0x0000);
- Delay_mS(10);
- ILI9325_WriteReg(R10, 0x0082);
- * Function Name : ILI9325_ExitSleep
- * Description : LCD 退出休眠模式
- * Input : None
- * Output : None
- * Return : None
- void ILI9325_ExitSleep(void) {
- Delay_mS(10);
- ILI9325_WriteReg(R10, 0x1490);
- ILI9325_WriteReg(R11, 0x0224);
- Delay_mS(10);
- ILI9325_WriteReg(R12, 0x001A);
- Delay_mS(10);
- ILI9325_WriteReg(R13, 0x1100);
- ILI9325_WriteReg(R29, 0x0011);
- Delay_mS(10);
- * Function Name : ILI9325_SetPixel
- * Description : 在指定的 x,y 坐标描点
- * Input : -x: 指定描点坐标 x 值
- * -y: 指定描点坐标 y 值
- * -color: 描点颜色值
- * Output : None
- * Return : None
- void ILI9325_SetPixel(uint16_t x, uint16_t y, uint16_t color) {
- ILI9325_SetDisplayWindow(x,y,x,y);
- ILI9325_WriteGRAM(color);
- * Function Name : ILI9325_RectangleFill
- * Description : 显示窗口内以指定颜色局部填充
- * Input : -x: 指定起点坐标 x 值
- * -y: 指定起点坐标 y 值
- * -width: 指定填充宽度
- * -hight: 指定填充高度
- * -color: 指定填充颜色
- * Output : None
- * Return : None
- void ILI9325_RectangleFill(uint16_t x, uint16_t y, uint16_t width, uint16_t hight, uint16_t color) {
- uint16_t i,j;
- ILI9325_SetDisplayWindow(x, y, x+width-1, y+hight-1);
- for(i=0; i<width; i++) {
- for(j=0; j<hight; j++) {
- * Function Name : ILI9325_FillSCR
- * Description : 显示窗口全部以指定颜色填充
- * Input : -color: 指定填充颜色
- * Output : None
- * Return : None
- void ILI9325_FillSCR(uint16_t color) {
- uint16_t i,j;
- ILI9325_SetDisplayWindow(0, 0, 319, 239);
- for(i=0; i<320; i++) {
- for(j=0; j<240; j++) {
- * Function Name : ILI9325_DrawBMP
- * Description : 图片显示
- * -y: 指定起点坐标 y 值
- * -width: 指定图片宽度
- * -hight: 指定图片高度
- * -*pBmp: 图片数据指针
- * Output : None
- * Return : None
- void ILI9325_DrawBMP(uint16_t x,uint16_t y,uint16_t width,uint16_t hight,const uint8_t *pBmp) {
- uint16_t i,j;
- uint16_t Data;
- Data = (*pBmp++)<<8;
- Data = Data | (*pBmp++);
- ILI9325_WriteGRAM(Data);
- * Function Name : ILI9325_SetCursor
- * Description : Sets the cursor position.
- * Input : - Xpos: specifies the X position.
- * - Ypos: specifies the Y position.
- * Output : None
- * Return : None
- void ILI9325_SetCursor(uint16_t x, uint16_t y) {
- ILI9325_SetDisplayWindow(x, y, x, y);
- //ILI9325_WriteReg(R20, x);
- //ILI9325_WriteReg(R21, y);
- * Function Name : ILI9325_BGR2RGB
- * Description :
- * Input :
- * Output :
- * Return :
- uint16_t ILI9325_BGR2RGB(uint16_t BGR_Code) {
- uint16_t r, g, b;
- r = BGR_Code & 0x1f;
- g = (BGR_Code>>5) & 0x3f;
- b = (BGR_Code>>11) & 0x1f;
- return( (r<<11) + (g<<5) + (b<<0) );
- * Function Name : ILI9325_ReadRegister
- * Description : Get the data of the appointed register.
- * Input :
- * Output :
- * Return :
- uint16_t ILI9325_ReadRegister(uint16_t LCD_Reg) {
- //写索引寄存器
- ILI9325_WriteIndex(LCD_Reg);
- return(ILI9325_ReadData());
- * Function Name : CheckController
- * Description : 读取 LCD 标示字符串
- * Input :
- * Output :
- * Return : int 类型标示字符串代码
- uint16_t CheckController(void) {
- return(ILI9325_ReadRegister(R0));
- * Function Name : ILI9325_GetPointRGB 获得指定像素点的颜色数据
- * Description : Get the color data of the appointed pixel.
- * Input :
- * Output :
- * Return :
- uint16_t ILI9325_GetPointRGB(uint16_t x,uint16_t y) {
- //ILI9325_SetDisplayWindow(x, y, x, y);
- ILI9325_SetCursor(x,y);
- return(ILI9325_BGR2RGB(ILI9325_ReadRegister(R22)));
- * Function Name : ILI9325_ClearLine
- * Description : Clears the selected line.
- * Input : - Line: the Line to be cleared.
- * This parameter can be one of the following values:
- * - Linex: where x can be 0..19
- * Output : None
- * Return : None
- void ILI9325_ClearLine(uint8_t Line) {
- //ILI9325_DisplayStringLine(Line, " ");
- * Function Name : ILI9325_SetTextColor
- * Description : Sets the Text color.
- * Input : - Color: specifies the Text color code RGB(5-6-5).
- * Output : - TextColor: Text color global variable used by LCD_DrawChar
- * and LCD_DrawPicture functions.
- * Return : None
- void ILI9325_SetTextColor(uint16_t Color) {
- ILI9325.TextColor = Color;
- * Function Name : ILI9325_SetBackColor
- * Description : Sets the Background color.
- * Input : - Color: specifies the Background color code RGB(5-6-5).
- * Output : - BackColor: Background color global variable used by
- * LCD_DrawChar and LCD_DrawPicture functions.
- * Return : None
- void ILI9325_SetBackColor(uint16_t Color) {
- ILI9325.BackColor = Color;
- - 功能描述:将一个32位的变量dat转为字符串,比如把1234转为"1234"
- - 参数说明:dat:带转的long型的变量
- str:指向字符数组的指针,转换后的字节串放在其中
- - 返回说明:无
- void u32tostr(uint32_t dat,uint8_t *str) {
- int8_t temp[20];
- uint8_t i=0,j=0;
- i=0;
- while(dat){
- temp[i]=dat%10+0x30;
- i++;
- dat/=10;
- j=i;
- for(i=0;i<j;i++) {
- str[i]=temp[j-i-1];
- if(!i) {str[i++]='0';}
- str[i]=0;
- - 功能描述:将一个字符串转为32位的变量,比如"1234"转为1234
- - 参数说明:str:指向待转换的字符串
- - 返回说明:转换后的数值
- unsigned long strtou32(unsigned char *str) {
- uint32_t temp=0;
- uint32_t fact=1;
- uint8_t len=StrLength(str);
- uint8_t i;
- for(i=len;i>0;i--) {
- temp+=((str[i-1]-0x30)*fact);
- fact*=10;
- return temp;
- * Function Name : StrLength
- * Description : Returns length of string.
- * Input : - Str: Character Pointer.
- * Output : None
- * Return : String length.
- static uint32_t StrLength(uint8_t *Str) {
- uint32_t Index = 0;
- /* Increment the Index unless the end of string */
- for(Index = 0; *Str != '\0'; Str++, Index++);
- return Index;
- * Function Name : ILI9325_DrawChar
- * Description : Draws a character on LCD.
- * Input : - Xpos: the Line where to display the character shape.
- * - Ypos: start column address.
- * - c: pointer to the character data.
- * Output : None
- * Return : None
- void ILI9325_DrawChar_8x16(uint16_t x, uint16_t y, uint8_t *c) {
- uint16_t i=0,j=0,str=0;
- uint16_t OffSet=0;
- OffSet = (*c - 32)*16;//寻找ASCII_Table[]中相应字符的点阵数据
- /*pAscii传过来的是该字符的ASCII码数字表示(参看ASCII表,有严格
- 顺序表示),减32是因为第0~31号是控制字符,第32号为“空格”字符
- 除以16是因为在ASCII_Table[]中的每个字符点阵为16个字节表示*/
- ILI9325_SetDisplayWindow(x, y, x+7, y+15);
- for(i=0;i<16;i++) {
- str = *(ascii_8x16 + OffSet + i);
- for(j=0;j<8;j++) {
- if(str & (0x80>>j)) {
- ILI9325_WriteGRAM(ILI9325.TextColor);
- else {
- ILI9325_WriteGRAM(ILI9325.BackColor);
- * Function Name : ILI9325_DisplayChar
- * Description : Displays one character .
- * Input : - Line: the Line where to display the character shape .
- * - Column: start column address.
- * - Ascii: character ascii code
- * Output : None
- * Return : None
- void ILI9325_DisplayChar_8x16(uint16_t x, uint16_t y, uint8_t *Ascii) {
- while(*Ascii != 0){
- ILI9325_DrawChar_8x16(x,y,Ascii);
- x += 8;
- Ascii += 1;
- * Output : None
- * Return : None
- void ILI9325_DrawChar_16x16(uint16_t x,uint16_t y,uint16_t Num){
- uint8_t i=0,j=0;
- uint16_t str=0;
- OffSet = Num*32;//寻找ASCII_Table[]中相应字符的点阵数据
- ILI9325_SetDisplayWindow(x,y,x+15,y+15);
- for(i = 0; i < 16; i++){
- str = ((uint16_t)(*(china_16x16 + OffSet + i*2)<<8)+*(china_16x16 + OffSet + i*2+1));
- for(j=0;j<16;j++) {
- if(str & (0x8000>>j)) {
- else {
- * Output : None
- * Return : None
- void ILI9325_DrawChar_16x24(uint16_t x, uint16_t y, uint8_t *c) {
- uint8_t i=0,j=0;
- uint16_t str=0;
- OffSet = (*c - 32)*48;//寻找ASCII_Table[]中相应字符的点阵数据
- ILI9325_SetDisplayWindow(x, y, x+15, y+23);
- for(i=0;i<24;i++) {
- str = ((uint16_t)(*(ascii_16x24 + OffSet + i*2)<<8))+(*(ascii_16x24 + OffSet + i*2+1));
- else {
- * Output : None
- * Return : None
- void ILI9325_DisplayChar_16x24(uint16_t x, uint16_t y, uint8_t *Ascii) {
- ILI9325_DrawChar_16x24(x,y,Ascii);
- x += 16;
- Ascii += 1;
- * Output : None
- * Return : None
- void ILI9325_DrawChar_24x24(uint16_t x,uint16_t y,uint16_t Num){
- uint8_t i=0,j=0;
- uint32_t str=0;
- OffSet = Num*72;//寻找ASCII_Table[]中相应字符的点阵数据
- ILI9325_SetDisplayWindow(x,y,x+23,y+23);
- for(i = 0; i < 24; i++){
- str = ((uint32_t)(*(china_24x24 + OffSet + i*3)<<16))+((uint16_t)(*(china_24x24 + OffSet + i*3+1)<<8))+(*(china_24x24 + OffSet + i*3+2));
- for(j=0;j<24;j++) {
- if(str & (0x00800000>>j)) {
- else {
- * Output : None
- * Return : None
- void ILI9325_DisplayChar_24x24(uint16_t x, uint16_t y, uint8_t *Ascii) {
- ILI9325_DrawChar_24x24(x,y,Ascii);
- x += 24;
- Ascii += 1;
- * Output : None
- * Return : None
- void ILI9325_DrawChar_24x48(uint16_t x,uint16_t y,uint8_t *c){
- unsigned char i=0,j=0;
- unsigned long str=0;
- unsigned short OffSet=0;
- OffSet = (*c - 32)*144;//寻找ASCII_Table[]中相应字符的点阵数据
- ILI9325_SetDisplayWindow(x,y,x+23,y+47);
- for(i = 0; i < 48; i++){
- str = ((uint32_t)(*(ascii_24x48 + OffSet + i*3)<<16))+((uint16_t)(*(ascii_24x48 + OffSet + i*3+1)<<8))+(*(ascii_24x48 + OffSet + i*3+2));
- else {
- * Output : None
- * Return : None
- void ILI9325_DisplayChar_24x48(uint16_t x, uint16_t y, uint8_t *Ascii) {
- ILI9325_DrawChar_24x48(x,y,Ascii);
- x += 24;
- Ascii += 1;
- * Function Name : ILI9325_Bre_Line
- * Description : Bresenham 画线程序
- * Input : - x1: 指定的画线起点 x 坐标
- * - y1: 指定的画线起点 y 坐标
- * - x2: 指定的画线终点 x 坐标
- * - y2: 指定的画线终点 y 坐标
- * - color: 画线颜色
- * - type: 类型
- * Output : None
- * Return : None
- void ILI9325_Bre_Line(uint16_t x1,uint16_t y1,uint16_t x2,uint16_t y2,uint16_t color,uint16_t type) {
- int16_t dx,dy,e,count = 0;
- dx=x2-x1;
- dy=y2-y1;
- if(dx>=0) {
- if(dy >= 0) { // dy>=0
- if(dx>=dy) { // 1/8 octant
- e=dy-dx/2;
- while(x1<=x2) {
- count++;
- if(type != 0){
- if(count%2)
- ILI9325_SetPixel(x1,y1,ILI9325.BackColor);
- else
- ILI9325_SetPixel(x1,y1,color);
- else
- if(e>0){
- y1+=1;
- e-=dx;
- x1+=1;
- e+=dy;
- else { // 2/8 octant
- e=dx-dy/2;
- while(y1<=y2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- x1+=1;
- e-=dy;
- y1+=1;
- e+=dx;
- else { // dy<0
- dy=-dy; // dy=abs(dy)
- if(dx>=dy) { // 8/8 octant
- e=dy-dx/2;
- while(x1<=x2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- y1-=1;
- e-=dx;
- x1+=1;
- e+=dy;
- else { // 7/8 octant
- e=dx-dy/2;
- while(y1>=y2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- x1+=1;
- e-=dy;
- y1-=1;
- e+=dx;
- else { //dx<0
- dx=-dx; //dx=abs(dx)
- if(dx>=dy) { // 4/8 octant
- e=dy-dx/2;
- while(x1>=x2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- y1+=1;
- e-=dx;
- x1-=1;
- e+=dy;
- else { // 3/8 octant
- e=dx-dy/2;
- while(y1<=y2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- x1-=1;
- e-=dy;
- y1+=1;
- e+=dx;
- else { // dy<0
- if(dx>=dy) { // 5/8 octant
- e=dy-dx/2;
- while(x1>=x2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- y1-=1;
- e-=dx;
- x1-=1;
- e+=dy;
- else { // 6/8 octant
- e=dx-dy/2;
- while(y1>=y2) {
- count++;
- if(type != 0){
- if(count%2)
- else
- else
- if(e>0){
- x1-=1;
- e-=dy;
- y1-=1;
- e+=dx;
