查看: 1848|回复: 0
软件 PWM配置 STM32F103
ID:730478 发表于 2020-4-16 13:36 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include "turn.h"
u8 led0_statelift;
u8 led0_stateright;
u8 pwm_high_counterlift;
u8 pwm_high_counterright;
//配置嵌套中断控制器
void tim3_nvic_config(void)
    NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
    NVIC_InitTypeDef  NVIC_Init_Struct;
    NVIC_Init_Struct.NVIC_IRQChannel =TIM3_IRQn;    //设置定时器 3中断
    NVIC_Init_Struct.NVIC_IRQChannelPreemptionPriority =0 ;//抢占与优先级
    NVIC_Init_Struct.NVIC_IRQChannelSubPriority = 0;        //zi优先级
    NVIC_Init_Struct.NVIC_IRQChannelCmd =ENABLE;  //shineng
    NVIC_Init(&NVIC_Init_Struct);
//定时器初始化配置
void tim3_config(void)
TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStruct;
tim3_nvic_config();
RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3,ENABLE);
TIM_DeInit(TIM3);
TIM_TimeBaseInitStruct.TIM_Prescaler = 36-1;
TIM_TimeBaseInitStruct.TIM_CounterMode = TIM_CounterMode_Up;
TIM_TimeBaseInitStruct.TIM_Period = 10-1;              // 200khz翻转 100k个周期
TIM_TimeBaseInitStruct.TIM_ClockDivision = TIM_CKD_DIV1;
TIM_TimeBaseInit(TIM3, &TIM_TimeBaseInitStruct); //初始化 TIM2 配置
TIM_ClearFlag(TIM3,TIM_FLAG_Update); //清除溢出中断标志
TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE);
TIM_Cmd(TIM3,ENABLE); //开启时钟
//定时器中断函数处理
void set_pwm_highlift(u8 high_pd)
pwm_high_counterlift = high_pd;
void set_pwm_highright(u8 high_pd)
pwm_high_counterright = high_pd;
void TIM3_IRQHandler(void)
     //进中断
   if(TIM_GetITStatus(TIM3, TIM_IT_Update)!= RESET)
        //left
        led0_statelift ++;
        if(led0_statelift <= pwm_high_counterlift)
            LEFT0_ON();
            LEFT1_OFF();
         else if((led0_statelift > pwm_high_counterlift) && (led0_statelift <= 100))
            LEFT0_OFF();
            LEFT1_ON();
            led0_statelift = 0;
   TIM_ClearITPendingBit(TIM3,TIM_FLAG_Update);
   //right
        led0_stateright ++;
           if(led0_stateright <= pwm_high_counterright)
            RIGHT0_ON();
            RIGHT1_OFF();
         else if((led0_stateright > pwm_high_counterright) && (led0_stateright <= 100))
            RIGHT0_OFF();
            RIGHT1_ON();
            led0_stateright = 0;
