查看: 5014|回复: 14
单片机电子时钟程序为什么运行一会就突然卡退,是不是程序少写了还是错了
ID:723220 发表于 2020-9-4 09:50 | 显示全部楼层 |阅读模式
#include<reg52.h>
sbit LCD_RS = P2^0;
sbit LCD_RW = P2^1;
sbit LCD_EN = P2^2;
sbit LED = P2^4;
bit new_s=0, g = 0,k=0;
char t0, sec = 00, min = 00, hour = 00;
char code LCD_line1[] = "GOOD MORNING!";
char code LCD_line2[] = "Timer: 00:00:00 ";
char Timer_buf[] = "00:00:00";
void delay(uint z)//延时
    uint  x, y;
    for(x = z; x > 0; x--)
                for(y = 100; y > 0; y--);
void W_LCD_Com(uchar com)   //写指令
    LCD_RS = 0;
                LCD_RW = 0;
                P3 = com;
    LCD_EN = 1;
                delay(5);
                LCD_EN = 0;
void W_LCD_Dat(uchar dat)//写数据
    LCD_RS = 1;
        LCD_RW = 0;
        P3 = dat;
    LCD_EN = 1;
        delay(5);
        LCD_EN = 0;
void W_LCD_STR(uchar *s)  //写字符
    while(*s)  W_LCD_Dat(*s++);
void W_BUFF(void) //显示
                Timer_buf[0] = hour / 10 + 48;
                Timer_buf[1] = hour % 10 + 48;
                Timer_buf[3] = min / 10 + 48;
                Timer_buf[4] = min % 10 + 48;
                Timer_buf[6] = sec / 10 + 48;
                   Timer_buf[7] = sec % 10 + 48;
                   W_LCD_Com(0xc0 + 7);
                W_LCD_STR(Timer_buf);
uchar read_key(void)//扫描按键
    uchar  x1, x2;
    P1 = 255;
    x1 = P1;
    if (x1 != 255) {
      delay(100);
      x2 = P1;
      if (x1 != x2)
        return 255;
      while(x2 != 255)
        x2 = P1;
      if      (x1 == 0xfe)  return 0;
      else if (x1 == 0xfb)  return 1;
      else if (x1 == 0xfd)  return 2;
      else if (x1 == 0xf7)  return 3;
      else if (x1 == 0xef)  return 4;
else if(x1==0xdf)return 5;
    return 255;
void Init()
    LCD_RW = 0;
    W_LCD_Com(0x38); //显示模式
                delay(50);
                W_LCD_Com(0x0c);
    W_LCD_Com(0x06);//显示光标移动位置
    W_LCD_Com(0x01);//清屏
    W_LCD_Com(0x80);//第一行
                W_LCD_STR(LCD_line1);
    W_LCD_Com(0xC0);//第二行
                W_LCD_STR(LCD_line2);
    TMOD = 0x01;   //T0定时方式1
    TH0 = 0x3c;
        TL0= 0xB0;
    TR0 = 1;
    ET0 = 1;
    EA = 1;
void CountDown()
  if (k)
while(!(sec==0&&min==0&&hour==0))
         if(new_s==1)
           sec--;
           new_s=0;
           sec %=60;
           if(sec<0)
                   sec=58-sec;
        if(sec==59)
                        min--;  min %=60;
                        if(min<0&&hour!=0&&hour>0)
                                min=58-min;
                  if(min==59)
                                  hour--; hour %= 24;
        W_BUFF();
          k=0;
    uint i, j;
    uchar Key;
    Init();
      if (new_s)
            new_s=0;sec++;  sec %= 60;
        if(!sec)
                min++;  min %= 60;
          if(!min)
                  { hour++; hour %= 24;}
        W_BUFF();
          Key = read_key();
      switch(Key) {
      case  0: g = 1; break;
      case  1: if(g) {min++;  min %= 60;  W_BUFF(); break;}
      case  2: if(g) {hour++; hour %= 24; W_BUFF(); break;}
      case  3: g = 0; break;
                case 4:k=1;CountDown();break;
void timer0(void) interrupt 1
                TH0 = 0x3c;
                TL0= 0xB0;
    t0++; t0 %= 20;  //20次
    if(t0 == 0){new_s = 1; LED = ~LED;}
    if(g)  LED = 0;
ID:213173 发表于 2020-9-4 16:30 | 显示全部楼层
这两个花括号位置不对
        switch(Key)
                case  1: if(g) {min++;  min %= 60;  W_BUFF();}break;
                case  2: if(g) {hour++; hour %= 24; W_BUFF();}break;
                case  4: k=1;CountDown();break;
ID:123289 发表于 2020-9-4 16:42 | 显示全部楼层
一定是程序问题。
ID:723220 发表于 2020-9-4 22:15 | 显示全部楼层
wulin 发表于 2020-9-4 16:30
这两个花括号位置不对
      case  2: if ...
这个程序运行时C51单片机接线端的RST端为什么不亮
ID:511890 发表于 2020-9-4 23:49 | 显示全部楼层
case的问题一楼已经说了。CountDown()也有点问题,--的时候用%=不合适,干脆就用if(sec<0) sec = 59;
  还有你说的程序卡退,可能是因为W_LCD_Com,W_LCD_Dat里面都有delay,这可能导致主程序里面的while会和定时器timer0起冲突。
改进的话就是把显示也放到一个定时器里面去。放到timer0里也行,放到另一个定时器也行。
参与人数 1黑币 +20 收起 理由
admin + 20 回帖助人的奖励!
ID:723220 发表于 2020-9-5 15:15 | 显示全部楼层
可不可说的更加具体一点
ID:723220 发表于 2020-9-5 16:47 | 显示全部楼层
这个程序在运行时不仅卡退,而且C51单片机的RST端接复位按钮,按下复位按钮没反应,这是什么原因?
ID:723220 发表于 2020-9-5 16:51 | 显示全部楼层
各位大神可不可以帮忙修改一下,要求不让仿真卡退,C51单片机RST端有反应
ID:723220 发表于 2020-9-5 16:53 | 显示全部楼层
yzwzfyz 发表于 2020-9-4 16:42
一定是程序问题。
可不可以说的具体点
ID:540927 发表于 2020-9-5 17:28 | 显示全部楼层
复位键都没反应就是电路的问题了,要不芯片坏了,还有个人觉得尽量不要用delay
ID:146782 发表于 2020-9-5 18:10 | 显示全部楼层
      case  2: if(g) {hour++; hour %= 24; W_BUFF(); break;}这里的大括号位置不对
ID:723220 发表于 2020-9-5 20:08 | 显示全部楼层
      case  2: if(g) {hour++; hour %= 24; W_B ...
已经修改了不过还是卡退
ID:213173 发表于 2020-9-7 06:41 | 显示全部楼层
这个程序虽然不完善,甚至有错误,但不至于发生灾难性后果。从楼主表述的情况推测是楼主用仿真软件运行的状态。RST无效是因为RC复位电阻是模拟元件属性,要设置为数字属性。所谓“卡退”是仿真软件问题不是程序问题。 无标题.jpg
ID:140489 发表于 2020-9-7 09:11 | 显示全部楼层
仿真卡退,可能是仿真软件有问题,有的版本不行,protuse7.7比较稳定
ID:235954 发表于 2020-9-7 11:59 | 显示全部楼层
仿真软件,我用过8.0/8.8版本都闪退过,现在用8.6版本稳定不少,但打不开了8.7/8.8版本的原理图
