基于STM32的超声波测距,超声波模块使用HC-SR04TRIG接PA6、ECHO接PA7显示在显示屏上,测试程序使用的是正点原子的精英版带屏幕版本,模块化带注释
- #include "stm32f10x.h" // Device header
- #include "lcd.h"
- #include "Delay.h"
- #include "Ultra.h"
- int main(void)
- LCD_Init();
- LCD_Clear(WHITE);
- LCD_ShowString(0, 770, 480, 24, 24, "2022/02/04 -------- LZDTK");
- Ultra_Init();
- while(1)
- LCD_ShowxNum(0, 0, Senor_Using(), 10,24, 0); //显示 数字
- //理综答题卡
- //通用定时器3中断初始化
- //这里时钟选择为APB1的2倍,而APB1为36M
- //arr:自动重装值。
- //psc:时钟预分频数
- //这里使用的是定时器3!
- unsigned overcount=0;//记录定时器溢出次数
- void Ultra_Init()
- GPIO_InitTypeDef GPIO_InitStruct;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- NVIC_InitTypeDef NVIC_InitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE); //时钟使能
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA,ENABLE);
- GPIO_InitStruct.GPIO_Mode=GPIO_Mode_Out_PP;
- GPIO_InitStruct.GPIO_Pin=GPIO_Pin_6;
- GPIO_InitStruct.GPIO_Speed=GPIO_Speed_50MHz;
- GPIO_Init(GPIOA,&GPIO_InitStruct);
- GPIO_InitStruct.GPIO_Mode=GPIO_Mode_IN_FLOATING;
- GPIO_InitStruct.GPIO_Pin=GPIO_Pin_7;
- //定时器TIM3初始化
- TIM_TimeBaseStructure.TIM_Period = 999; //设置重装载值为999
- TIM_TimeBaseStructure.TIM_Prescaler =71; //设置用来作为TIM3时钟频率除数的预分频值
- TIM_TimeBaseStructure.TIM_ClockDivision = TIM_CKD_DIV1; //设置时钟分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根据指定的参数初始化TIMx的时间基数单位
- TIM_ITConfig(TIM3,TIM_IT_Update,ENABLE ); //使能指定的TIM3中断,允许更新中断
- //中断优先级NVIC设置
- NVIC_InitStructure.NVIC_IRQChannel = TIM3_IRQn; //TIM3中断
- NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0; //先占优先级0级
- NVIC_InitStructure.NVIC_IRQChannelSubPriority = 3; //从优先级3级
- NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE; //IRQ通道被使能
- NVIC_Init(&NVIC_InitStructure); //初始化NVIC寄存器
- TIM_Cmd(TIM3, DISABLE); //使能TIMx
- //测距函数
- float Senor_Using(void)//单精度数据类型
- float length=0,sum=0;
- u16 tim;
- unsigned int i=0;
- /*测五次数据计算一次平均值*/
- while(i!=5)
- PAout(6)=1;//拉高信号,作为触发信号
- Delay_us(20);//高电平信号超过10us
- PAout(6)=0;//等待回响信号
- while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7)==RESET);
- TIM_Cmd(TIM3,ENABLE);//回响信号到来,开启定时器计数
- i+=1;//每收到一次回响信号+1,收到5次就计算均值
- while(GPIO_ReadInputDataBit(GPIOA,GPIO_Pin_7)==SET);//回响信号消失
- TIM_Cmd(TIM3,DISABLE);//关闭定时器
- tim=TIM_GetCounter(TIM3);//获取计TIM2数寄存器中的计数值
- length=(tim+overcount*1000)/58.0;//通过回响信号计算距离
- sum=length+sum;
- TIM3->CNT=0;//将TIM2计数寄存器的计数值清零
- overcount=0;//中断溢出次数清零
- Delay_ms(100);
- length=sum/5;//距离作为函数返回值
- return length;
- //定时器3中断服务程序
- void TIM3_IRQHandler(void) //TIM3中断
- if (TIM_GetITStatus(TIM3,TIM_IT_Update)!= RESET) //检查TIM3更新中断发生与否
- TIM_ClearITPendingBit(TIM3, TIM_IT_Update ); //清除TIMx更新中断标志
- overcount++;
Keil5代码下载:
超声波测距程序.7z
(205.94 KB, 下载次数: 29)
