查看: 3112|回复: 4
求这个c程序的最详细解释
ID:73480 发表于 2015-4-1 20:20 | 显示全部楼层 |阅读模式
这是一个计时器
#include<reg51.h>
sbit lcden=P0^5;//1602的使能端
sbit lcdrs=P0^7;
sbit lcdrw=P0^6;
sbit k1=P3^5;//功能按键
sbit k2=P3^4;//加按键
sbit k3=P3^3;//减按键
sbit bz=P0^4;//蜂鸣器
uchar code table[]="countdown...";
uchar code table1[]="00:00:00";
uchar num,aa,k1num,k2num,k3num;
char shi,fen,miao,qian,bai,beepz;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void beep()        //控制无源蜂鸣器响函
     bz=1;
         delay(2);
         bz=0;
         delay(2);
void write_com(uchar com)//1602写命令函数
        lcdrs=0;
        lcdrw=0;
        P2=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)//1602写数据函数
        lcdrs=1;
        lcdrw=0;
        P2=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_sfm(uchar add,uchar date)//写时分秒函数
        uchar shi,ge;
        shi=date/10;
        ge=date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void init()//初始化函数
        miao=59;
        fen=59;
        shi=23;
        lcden=0;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
    write_com(0x80);
        for(num=0;num<12;num++)
                        write_date(table[num]);
                        delay(5);
                write_com(0x80+0x40);
                for(num=0;num<8;num++)
                        write_date(table1[num]);
                        delay(5);
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        write_sfm(6,miao);
        write_sfm(3,fen);
        write_sfm(0,shi);
void keyscan()//按键函数
        if(k1==0)        //检测K1按键按下
                delay(5);        //延时
                if(k1==0)        //再次检测K1按键按下
                        k1num++;
                        while(!k1);
                      if(k1num==1) //第一次按K1
                                                TR0=0;//关闭定时器
                                        write_com(0x80+0x40+7);//光标闪烁的位置
                                        write_com(0x0f);//开启光标闪烁
                                if(k1num==2)//第二次按K1
                                        write_com(0x80+0x40+4);//光标闪烁的位置
                                if(k1num==3)//第三次按K1
                                        write_com(0x80+0x40+1);//光标闪烁的位置
                                                if(k1num==4)//第四次按K1
                                        TR0=1;//开定时器
                                        k1num=0;//按清零键次数
                                        write_com(0x0c);//关闭光标闪烁
        if(k1num!=0)//K1没有按下的时候
                                if(k2==0)
                                                delay(5);
                                                if(k2==0)
                                                        while(!k2);
        if(k1num==1)
        miao++;
        if(miao==60)
        miao=0;
        //s1=0;
        write_sfm(6,miao);
        if(k1num==2)
        fen++;
        if(fen==60)
        fen=0;
        //s1=0;
        write_sfm(3,fen);
        if(k1num==3)
        shi++;
        if(shi==24)
        shi=0;
        //s1=0;
        write_sfm(0,shi);
                                        if(k3==0)
                                                delay(5);
                                                if(k3==0)
                                                        while(!k3);
                                                        if(k1num==1)
        miao--;
        if(miao==-1)
        miao=59;
        write_sfm(6,miao);
                                                        if(k1num==2)
        fen--;
        if(fen==-1)
        fen=59;
        write_sfm(3,fen);
                                                        if(k1num==3)
        shi--;
        if(shi==-1)
        shi=23;
        write_sfm(0,shi);
void main()        //主函数
        init();//初始化
                keyscan();//等待检测是否有按键按下
void timer0() interrupt 1 //中断函数
        aa++;
                if(aa==18)
                        aa=0;
                        miao--;
                        if((miao==-1)&&(fen==1)&&(shi==0))         //判断到计时一分钟一秒钟报警
        for(beepz=0;beepz<110;beepz++)         //一秒钟报警
                                beep();
                        if((miao==-1)&&(fen==0)&&(shi==0))         //判断倒计时到时长响报警
                                  TR0=0;
                                  miao=0;
                                  fen=0;
                                  shi=0;
                                  while(1) //长报警
                                          beep();
                        if(miao==-1)
                                miao=59;
                                fen--;
                                if(fen==-1)
                                        fen=59;
                                        shi--;
        write_sfm(0,shi);
                                   write_sfm(3,fen);
                          write_sfm(6,miao);
ID:75077 发表于 2015-4-2 09:51 | 显示全部楼层
ID:73833 发表于 2015-4-2 20:23 | 显示全部楼层
ID:29301 发表于 2015-4-3 10:00 | 显示全部楼层
自己先看,看不懂了再问,这个都是模块的东西,一个一个看总会懂的
ID:76287 发表于 2015-4-7 18:53 | 显示全部楼层
想要画一个点火芯片的封装,可是一到pcb就出错。这个芯片的底部也作为一个焊盘。我的思路是,用一个多层的焊盘作为引脚11,然后上面加几个过孔从而可以从下面走线,可是这样在pcb中显示出错
