查看: 2322|回复: 0
External Interrupt ----atmega128
ID:80436 发表于 2015-5-21 23:36 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
#include<avr/io.h>
#include<avr/interrupt.h>
// External Interrupt 0 service routine
ISR(INT0_vect)
  PORTA=0X0F;
// External Interrupt 1 service routine
ISR(INT1_vect)
  PORTA=0XF0;
// External Interrupt 2 service routine
ISR(INT2_vect)
  PORTA=0XAA;
// External Interrupt 3 service routine
ISR(INT3_vect)
  PORTA=0X55;
void Poit_init(void)
DDRA=0xFF;//output
PORTA=0XFF;//all of pins out 1
DDRD=0XF0; //low 4bit pins set input mode
PORTD=0XFF;
int main(void)
Poit_init();
SREG=0x80;    //开全局中断
EIMSK=0x0F;   //
EICRA=0x0F;
while (1);
        seabiscuit
        jiujiang
