查看: 3612|回复: 1
ADC0832模数转换与显示的程序文件和仿真及实物
用ADC0832做的模数转换与显示,具体实物图如下本人已经搞成功了:
ADC0832模数转换的仿真图
源程序:
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. #define uint unsigned int
  5. #define delay4us() {_nop_();_nop_();_nop_();_nop_();}
  6. sbit RS = P2^0;
  7. sbit RW = P2^1;
  8. sbit E  = P2^2;
  9. sbit CS  = P1^0;
  10. sbit CLK = P1^1;
  11. sbit DIO = P1^2;
  12. uchar Display_Buffer[] = "0.00V";
  13. uchar code Line1[] = "Current Voltage:";
  14. void DelayMS(uint ms)
  15. {
  16.         uchar i;
  17.         while(ms--)
  18.         {
  19.                  for(i=0;i<120;i++);
  20.         }
  21. }
  22. bit LCD_Busy_Check()
  23. {
  24.         bit result;
  25.         RS = 0;
  26.         RW = 1;
  27.         E  = 1;
  28.         delay4us();
  29.         result = (bit)(P0&0x80);
  30.         E  = 0;
  31.         return result;
  32. }
  33. void LCD_Write_Command(uchar cmd)
  34. {
  35.         while(LCD_Busy_Check());
  36.         RS = 0;
  37.         RW = 0;
  38.         E  = 0;
  39.         _nop_();
  40.         _nop_();
  41.         P0 = cmd;
  42.         delay4us();
  43.         E = 1;
  44.         delay4us();
  45.         E = 0;
  46. }
  47. void Set_Disp_Pos(uchar pos)
  48. {
  49.         LCD_Write_Command(pos | 0x80);
  50. }
  51. void LCD_Write_Data(uchar dat)
  52. {
  53.         while(LCD_Busy_Check());
  54.         RS = 1;
  55.         RW = 0;
  56.         E  = 0;
  57.         P0 = dat;
  58.         delay4us();
  59.         E = 1;
  60.         delay4us();
  61.         E = 0;
  62. }
  63. void LCD_Initialise()
  64. {
  65.         LCD_Write_Command(0x38); DelayMS(1);
  66.         LCD_Write_Command(0x0c); DelayMS(1);
  67.         LCD_Write_Command(0x06); DelayMS(1);
  68.         LCD_Write_Command(0x01); DelayMS(1);
  69. }
  70. //获取AD转换结果(0通道)
  71. uchar Get_AD_Result()
  72. {
  73.         uchar i,dat1=0,dat2=0;
  74.         //起始控制位
  75.         CS  = 0;
  76.         CLK = 0;
  77.         DIO = 1; _nop_(); _nop_();
  78.         CLK = 1; _nop_(); _nop_();
  79.         //第一个下降沿之前,设DIO=1/0
  80.         //选择单端/差分模式中的单端输入模式
  81.         CLK = 0;DIO = 1; _nop_(); _nop_();
  82.         CLK = 1; _nop_(); _nop_();
  83.         //第二个下降沿之前,设DIO=0/1,选择CH0/CH1
  84.         CLK = 0;DIO = 0; _nop_(); _nop_();
  85.         CLK = 1;DIO = 1; _nop_(); _nop_();
  86.         //第三个下降沿之前,高DIO=1
  87.         CLK = 0;DIO = 1; _nop_(); _nop_();
  88.         //第4-11个,共8个下降沿读数据(MSB->LSB)
  89.         for(i=0;i<8;i++)
  90.         {
  91.                  CLK = 1; _nop_(); _nop_();
  92.                 CLK = 0; _nop_(); _nop_();
  93.                 dat1 = dat1 << 1 | DIO;
  94.         }
  95.         //第11-18个,共8个下降沿读数据(LSB->MSB)
  96.         for(i=0;i<8;i++)
  97.         {
  98.                  dat2 = dat2 << ((uchar)(DIO)<<i);
  99.                 CLK = 1; _nop_(); _nop_();
  100.                 CLK = 0; _nop_(); _nop_();
  101.         }
  102.         CS = 1;
  103.         //如果MSB->LSB和LSB->MSB读取的结果相同,则返回读取的结果,否则返回0
  104.         return (dat1 == dat2) ? dat1:0;
  105. }
  106. void main()
  107. {
  108.         uchar i;
  109.         uint d;
  110.         LCD_Initialise();
  111.         DelayMS(10);
  112.         while(1)
  113.         {
  114.                  d = Get_AD_Result()*500.0/255;
  115.                 Display_Buffer[0]=d/100+'0';
  116.                 Display_Buffer[2]=d/10%10+'0';
  117.                 Display_Buffer[3]=d%10+'0';
  118.                 Set_Disp_Pos(0x01);
  119.                 i = 0;
  120.                 while(Line1[i]!='\0')
  121.                 {
  122.                          LCD_Write_Data(Line1[i+1]);
  123.                 }
  124.                 Set_Disp_Pos(0x46);
  125.                 i = 0;
  126.                 while(Display_Buffer[i]!='\0')
  127.                 {
  128.                          LCD_Write_Data(Display_Buffer[i+1]);
  129.                 }
  130.         }
  131. }
仿真工程文件及源码打包下载:
ADC0832模数转换与显示.rar (3.87 MB, 下载次数: 28)
ID:362069 发表于 2018-6-29 23:29 | 只看该作者
根本仿真不出来啊
