查看: 7414|回复: 3
单片机运行老是出现这些错误 error C141: syntax error near 'if'
Build target '目标 1'
compiling 十花样.c...
十花样.C(94): error C141: syntax error near 'if'
十花样.C(94): error C141: syntax error near '==', expected ')'
十花样.C(94): error C129: missing ';' before '=='
目标未创建
#include<reg51.h>
#define        false 0
#define        true 1
sbit pause_key=P3^0;
sbit auto_key=P3^1;
sbit change_key=P3^2;
sbit pauseLed=P3^6;
sbit autoLed=P3^7;
int ledCode[8]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f} ;
int ledCode2[8]={0xfe,0xfc,0xf8,0xf0,0xe0,0xc0,0x80,0x00} ;
int disCode[10]={0x03,0x9f,0x25,0x0d,0x99,0x49,0x41,0x1f,0x01,0x09}        ;
void displayLed(void);
void keyScan(void) ;
void Delay10ms( unsigned int n);
bit isPause=false;
bit isAuto=true;
bit isChange=false;
uchar  time;
uchar types;
uchar counts;
void T0_INT(void)   interrupt 1
TL0=(65536-50000)/256;
TH0=(65536-50000)%256;
time++;
if(time>=10)
time=0;
if(isChange==true)
counts=0;
types++;
if(types>9)types=0;
P0=disCode[types] ;
isChange=false;
displayLed();
counts++;
void main(void)
TMOD=0x61;
TR0=1;
ET0=1;
EA=1;
time=0;
counts=0;
types=0;
pauseLed=0;
P0=disCode[types] ;
keyScan();
void keyScan(void)
if(pause_key==0)
Delay10ms(1);
if(pause_key==0)
isPause=~isPause;
pauseLed=isPause ;
if(isPause==true)
ET0=0;
P0=0xfd;
P1=0x00;
P2=0x00;
ET0=1;
P0=disCode[types];
displayLed();
while(pause_key==0);
if(auto_key==0)
isAuto=~isAuto;
autoLed=isAuto;
while(auto_key==0);
if(change_key==0&&isAuto==false)
Delay10ms(1);
if(change_key==0)
isChange=true;
while (change_key==0);
switch(types)
case:0
if(counts>=16)counts=0;
if(counts>=15)
if(isAuto==true)   isChange=true;
if(counts<8)
P1=0xff;
P2=ledCode[7-counts];
P1=ledCode[15-counts];
P2=0xff;
break;
case 1:
if(counts>=15)
if(isAuto==true)isChange=true;
if(counts<8)
P1=ledCode[counts];
P2=0xff;
P1=0xff;
P2=ledCode[counts-8];
break;
case 2:
if(counts>=15)
if(counts%2==0)
P1=0xaa;
P2=0xaa;
P1=0x55;
P2=0x55;
break;
case 3:
if(counts>=8)counts=0;
if(counts>=7)
P1=ledCode[7-counts];
break;
case 4:
if(counts>=7)
P1=ledCode[counts];
P2=ledCode[counts];
break;
case 5:
if(counts>=17)counts=0;
if(counts<8)
P1=~ledCode2[7-counts];
P2=0xff;
else if(counts<16)
P1=0x00;
P2=~ledCode2[15-counts];
P1=0x00;
P2=0x00;
break;
case 6:
if(counts<8)
P1=ledCode2[7-counts];
P2=0x00;
else if(counts<16)
P1=0xff;
P2=ledCode2[15-counts];
P1=0xff;
P2=0xff;
break;
case 7:
if(counts<8)
P1=0xff;
P2=ledCode2[counts];
else if(counts<16)
P1=ledCode2[counts-7];
P2=0x00;
P1=0x00;
P2=0x00;
break;
case 8:
if(counts<8)
P1=0x00;
P2=~ledCode2[counts];
else if(counts<16)
P1=~ledCode2[counts-7];
P2=0xff;
P1=0xff;
P2=0xff;
break;
case 9:
if(counts>=255)counts=0;
if(counts==254&&isAuto==true)
isChange=true;
P1=        ~counts;
P2=        ~counts;
break;
default:
types=0;
P0=disCode[types];
  unsigned char a,b;
  for(;n>0;n--)
    for(b=38;b>0;b--)
  for(a=130;a>0;a--);
ID:267719 发表于 2020-4-29 18:26 | 只看该作者
keyScan 函数里大括号不配对
ID:267719 发表于 2020-4-29 18:30 | 只看该作者
void keyScan(void)
    if(pause_key==0)
        Delay10ms(1);
        if(pause_key==0)
            isPause=~isPause;
            pauseLed=isPause ;
            if(isPause==true)
                ET0=0;
                P0=0xfd;
                P1=0x00;
                P2=0x00;
                ET0=1;
                P0=disCode[types];
                displayLed();
    if(auto_key==0)
        isAuto=~isAuto;
        autoLed=isAuto;
    while(auto_key==0);
    Delay10ms(1);
    if(change_key==0)
        isChange=true;
大括号配对了就这样。
要养成良好的代码编写习惯。
ID:592807 发表于 2020-4-30 09:31 | 只看该作者
括号没配对
