查看: 4125|回复: 6
求教 单片机程序应该在哪个地方把这些按钮加上去啊?
ID:786338 发表于 2020-6-22 16:33 | 显示全部楼层 |阅读模式
50黑币
按下A键启动,数码管的时、分、秒显示00.00.00CL,从零开始,按照钟表走时,再次按下A键停止,数码管保持显示当前时间,其中,CL代表时钟状态clock。
按“B” 键一次,秒钟加一,按多次则加多次,秒钟到59再按则为0;
按“C” 键一次,分钟加一,按多次则加多次,分钟到59再按则为0;
按“D” 键一次,时钟加一,按多次则加多次,时钟到23再按则为0;
这个是我源程序,A按键应该怎么改,我要怎么改A才能控制启停,求教!!
#include<regx51.h>
#define TIME=1200
sbit K1=P1^0;
sbit K2=P1^1;
sbit K3=P1^2;
sbit K4=P1^3;
sbit K5=P1^4;
unsigned int cnt=0;
unsigned char i=0;
unsigned long sec=0;
unsigned char second = 0;
unsigned char minute = 0;
unsigned char hour = 0;
unsigned char code segment_code[10] = {0x3f, 0x06, 0x5b, 0x4f,0x66, 0x6d, 0x7d, 0x07,0x7f, 0x6f};
unsigned char digital_tube[8]={0x3f,0x3f,0x3f,0x3f,0x3f,0x39,0x38};
void ScanLed()
        static unsigned char display_bit = 0;
        switch (display_bit)
        case 0:
                P2=0xfe;
                break;
        case 1:
                P2=0xfd;
                break;
        case 2:
                P2=0xfb;
                break;
        case 3:
                P2=0xf7;
                break;
        case 4:
                P2=0xef;
                break;
        case 5:
                P2=0xdf;
                break;
        case 6:
                P2=0xbf;
                break;
        case 7:
                P2=0x7f;
                break;
        default:
                break;
        P0=digital_tube[display_bit];
                display_bit++;
        if (display_bit == 8)
                display_bit = 0;
        TMOD = 0x01;
    TH0 = 64536 / 256;
    TL0 = 64536 % 256;
    EA = 1;
    ET0 = 1;
    TR0 = 1;
        while (1)
void delay(unsigned int xms)
        unsigned int i,j;
        for(i=xms;i>0;i--)
                for(j=100;j>0;j--);
void Timer0() interrupt 1
        static int index = 0;
        TH0 = 64536 / 256;
   TL0 = 64536 % 256;
        index++;
        ScanLed();
        if (index == 1000)
                index = 0;
                second++;
        if (second == 60)
                second = 0;
                minute++;
        if (minute == 60)
                minute = 0;
                hour++;
        if (hour == 24)
                hour = 0;
        if(K4==0)
  delay(10);
   if(K4==0)
hour++;
if(hour==24)        hour=0;
  while(!K4);
if(K3==0)
  delay(10);
  if(K3==0)
  minute++;
  if(minute==60)        minute=0;
while(!K3);
if(K2==0)
delay(10);
if(K2==0)
second++;
if(second==24)       second=0;
while(!K2);
if(K1==0)
delay(10);
if(K1==0)
hour=0;
minute=0;
second=0;
while(!K1);
digital_tube[0] = segment_code[hour / 10];
digital_tube[1] = segment_code[hour % 10]+0x80;
digital_tube[2] = segment_code[minute / 10];
digital_tube[3] = segment_code[minute % 10]+0x80;
digital_tube[4] = segment_code[second / 10];
digital_tube[5] = segment_code[second % 10]+0x80;
digital_tube[6] = 0x39;
digital_tube[7] = 0x38;
ID:332444 发表于 2020-6-22 17:04 | 显示全部楼层
ID:739545 发表于 2020-6-22 17:28 | 显示全部楼层
ScanLed()函数不就是按键么,在你的中断函数里面,也可以放到mian函数的while(1)里面去
ID:786916 发表于 2020-6-22 17:39 | 显示全部楼层
右键单击横线  选择 PLACE WIRE LABLE
ID:672631 发表于 2020-6-22 19:40 | 显示全部楼层
试一试加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
if(K1==0)hour++;(没加按键去抖,要给一点延时)
或者可以试一试加在定时器中断函数里面
ID:786338 发表于 2020-6-23 08:37 | 显示全部楼层
123ty 发表于 2020-6-22 19:40
试一试加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
好的我试试,谢谢
ID:786338 发表于 2020-6-23 08:41 | 显示全部楼层
试一试加到main()里面,
if(K1==0)second++;
if(K1==0)minute++;
这样就变成了A按下就都加一啊,我只是想让A键控制启停
