查看: 68931|回复: 70
通过Arduino UNO+RC522 修改UID卡号 复制门禁M1卡
ID:62590 发表于 2017-3-16 15:55 | 显示全部楼层 |阅读模式
1.利用手机NFC读取原卡ID号   卡号为 31 0D 6B 45
读取ID
读取ID
2. 有请 Arduino UNO :
RC522模块                         UNO
VCC  <----------------------->3.3V
RST  <----------------------->9
GND  <----------------------->GND
IRQ  <----------------------->不接
MISO <----------------------->12
MOSI <----------------------->11
SDA  <----------------------->10
SCK  <----------------------->13
3.代码---------------------------------------------------------------------------------------------------------------
  1. /*
  2. * 不同型号arduino的 引脚定义:(vcc接3.3V,  5V必烧!!! 5V必烧!!! 5V必烧!!!)
  3. * -----------------------------------------------------------------------------------------
  4. *             MFRC522      Arduino       Arduino   Arduino    Arduino          Arduino
  5. *             Reader/PCD   Uno           Mega      Nano v3    Leonardo/Micro   Pro Micro
  6. * Signal      Pin          Pin           Pin       Pin        Pin              Pin
  7. * -----------------------------------------------------------------------------------------
  8. * RST/Reset   RST          9             5         D9         RESET/ICSP-5     RST
  9. * SPI SS      SDA(SS)      10            53        D10        10               10
  10. * SPI MOSI    MOSI         11 / ICSP-4   51        D11        ICSP-4           16
  11. * SPI MISO    MISO         12 / ICSP-1   50        D12        ICSP-1           14
  12. * SPI SCK     SCK          13 / ICSP-3   52        D13        ICSP-3           15
  13. */
  14. #include <SPI.h>
  15. #include <MFRC522.h>
  16. #define RST_PIN   9     // Configurable, see typical pin layout above
  17. #define SS_PIN    10    // Configurable, see typical pin layout above
  18. MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance
  19. /*在这里修改卡号,读取的卡号是16进制的,每2位前加0x   */
  20. #define NEW_UID {0x31, 0x0D, 0x6B, 0x45}
  21. MFRC522::MIFARE_Key key;
  22. void setup() {
  23.   Serial.begin(9600);  // Initialize serial communications with the PC
  24.   while (!Serial);     // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  25.   SPI.begin();         // Init SPI bus
  26.   mfrc522.PCD_Init();  // Init MFRC522 card
  27.   Serial.println(F("Warning: this example overwrites the UID of your UID changeable card, use with care!"));
  28.   // Prepare key - all keys are set to FFFFFFFFFFFFh at chip delivery from the factory.
  29.   for (byte i = 0; i < 6; i++) {
  30.     key.keyByte[i] = 0xFF;
  31.   }
  32. }
  33. // Setting the UID can be as simple as this:
  34. void loop() {
  35.   // Look for new cards, and select one if present
  36.   if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
  37.     delay(50);
  38.     return;
  39.   }
  40.   // Now a card is selected. The UID and SAK is in mfrc522.uid.
  41.   // Dump UID
  42.   Serial.print(F("Card UID:"));
  43.   for (byte i = 0; i < mfrc522.uid.size; i++) {
  44.     Serial.print(mfrc522.uid.uidByte[i] < 0x10 ? " 0" : " ");
  45.     Serial.print(mfrc522.uid.uidByte[i], HEX);
  46.   }
  47.   Serial.println();
  48.   // Set new UID
  49.   byte newUid[] = NEW_UID;
  50.   if ( mfrc522.MIFARE_SetUid(newUid, (byte)4, true) ) {
  51.     Serial.println(F("Wrote new UID to card."));
  52.   }
  53.   // Halt PICC and re-select it so DumpToSerial doesn't get confused
  54.   mfrc522.PICC_HaltA();
  55.   if ( ! mfrc522.PICC_IsNewCardPresent() || ! mfrc522.PICC_ReadCardSerial() ) {
  56.     return;
  57.   }
  58.   // Dump the new memory contents
  59.   Serial.println(F("New UID and contents:"));
  60.   mfrc522.PICC_DumpToSerial(&(mfrc522.uid));
  61.   delay(2000);
  62. }
4.上传代码到UNO,然后刷一下UID卡
5.完工
下载:
MFRC522.zip (34.24 KB, 下载次数: 277)
ChangeUID.zip (1.4 KB, 下载次数: 239)
参与人数 6黑币 +131 收起 理由
kuluner + 3 很给力!
QQwert + 5
yywudi + 3 共享资料的黑币奖励!
xljxlj + 15 很给力!
chouruyan + 5 很给力!
admin + 100 共享资料的黑币奖励!
ID:173827 发表于 2017-3-20 19:54 | 显示全部楼层
不错的资源顶一个,下来试试
ID:62590 发表于 2017-3-20 21:17 来自触屏版 | 显示全部楼层
UID卡要用0扇区可修改的,某宝1.5元左右
ID:185197 发表于 2017-3-31 21:03 | 显示全部楼层
大神,这只是复制了UID,加密的卡能行不?
ID:62590 发表于 2017-4-1 09:41 | 显示全部楼层
加密扇区需要先读出解密的,不好搞,这有个读写扇区的程序,自己研究吧
接线同上
  1. #include <SPI.h>
  2. #include <MFRC522.h>
  3. #define RST_PIN         9           // Configurable, see typical pin layout above
  4. #define SS_PIN          10          // Configurable, see typical pin layout above
  5. MFRC522 mfrc522(SS_PIN, RST_PIN);   // Create MFRC522 instance.
  6. MFRC522::MIFARE_Key key;
  7. /**
  8. * Initialize.
  9. */
  10. void setup() {
  11.     Serial.begin(9600); // Initialize serial communications with the PC
  12.     while (!Serial);    // Do nothing if no serial port is opened (added for Arduinos based on ATMEGA32U4)
  13.     SPI.begin();        // Init SPI bus
  14.     mfrc522.PCD_Init(); // Init MFRC522 card
  15.     // Prepare the key (used both as key A and as key B)
  16.     // using FFFFFFFFFFFFh which is the default at chip delivery from the factory
  17.     for (byte i = 0; i < 6; i++) {
  18.         key.keyByte[i] = 0xFF;
  19.     }
  20.     Serial.println(F("Scan a MIFARE Classic PICC to demonstrate read and write."));
  21.     Serial.print(F("Using key (for A and B):"));
  22.     dump_byte_array(key.keyByte, MFRC522::MF_KEY_SIZE);
  23.     Serial.println();
  24.
  25.     Serial.println(F("BEWARE: Data will be written to the PICC, in sector #1"));
  26. }
  27. /**
  28. * Main loop.
  29. */
  30. void loop() {
  31.     // Look for new cards
  32.     if ( ! mfrc522.PICC_IsNewCardPresent())
  33.         return;
  34.     // Select one of the cards
  35.     if ( ! mfrc522.PICC_ReadCardSerial())
  36.         return;
  37.     // Show some details of the PICC (that is: the tag/card)
  38.     Serial.print(F("Card UID:"));
  39. dump_byte_array(mfrc522.uid.uidByte, mfrc522.uid.size);
  40.     Serial.println();
  41.     Serial.print(F("PICC type: "));
  42.     MFRC522::PICC_Type piccType = mfrc522.PICC_GetType(mfrc522.uid.sak);
  43.     Serial.println(mfrc522.PICC_GetTypeName(piccType));
  44.     // Check for compatibility
  45.     if (    piccType != MFRC522::PICC_TYPE_MIFARE_MINI
  46.         &&  piccType != MFRC522::PICC_TYPE_MIFARE_1K
  47.         &&  piccType != MFRC522::PICC_TYPE_MIFARE_4K) {
  48.         Serial.println(F("This sample only works with MIFARE Classic cards."));
  49.         return;
  50.     }
  51.     // In this sample we use the second sector,
  52.     // that is: sector #1, covering block #4 up to and including block #7
  53.     byte sector         = 1;
  54.     byte blockAddr      = 4;
  55.     byte dataBlock[]    = {
  56.         0x01, 0x02, 0x03, 0x04, //  1,  2,   3,  4,
  57.         0x05, 0x06, 0x07, 0x08, //  5,  6,   7,  8,
  58.         0x08, 0x09, 0xff, 0x0b, //  9, 10, 255, 12,
  59.         0x0c, 0x0d, 0x0e, 0x0f  // 13, 14,  15, 16
  60.     };
  61.     byte trailerBlock   = 7;
  62.     MFRC522::StatusCode status;
  63.     byte buffer[18];
  64.     byte size = sizeof(buffer);
  65.     // Authenticate using key A
  66.     Serial.println(F("Authenticating using key A..."));
  67.     status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_A, trailerBlock, &key, &(mfrc522.uid));
  68.     if (status != MFRC522::STATUS_OK) {
  69.         Serial.print(F("PCD_Authenticate() failed: "));
  70.         Serial.println(mfrc522.GetStatusCodeName(status));
  71.         return;
  72.     }
  73.     // Show the whole sector as it currently is
  74.     Serial.println(F("Current data in sector:"));
  75.     mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
  76.     Serial.println();
  77.     // Read data from the block
  78.     Serial.print(F("Reading data from block ")); Serial.print(blockAddr);
  79.     Serial.println(F(" ..."));
  80.     status = (MFRC522::StatusCode) mfrc522.MIFARE_Read(blockAddr, buffer, &size);
  81.     if (status != MFRC522::STATUS_OK) {
  82.         Serial.print(F("MIFARE_Read() failed: "));
  83.         Serial.println(mfrc522.GetStatusCodeName(status));
  84.     }
  85.     Serial.print(F("Data in block ")); Serial.print(blockAddr); Serial.println(F(":"));
  86.     dump_byte_array(buffer, 16); Serial.println();
  87.     Serial.println();
  88.     // Authenticate using key B
  89.     Serial.println(F("Authenticating again using key B..."));
  90.     status = (MFRC522::StatusCode) mfrc522.PCD_Authenticate(MFRC522::PICC_CMD_MF_AUTH_KEY_B, trailerBlock, &key, &(mfrc522.uid));
  91.     if (status != MFRC522::STATUS_OK) {
  92.         Serial.print(F("PCD_Authenticate() failed: "));
  93.         Serial.println(mfrc522.GetStatusCodeName(status));
  94.         return;
  95.     }
  96.     // Write data to the block
  97.     Serial.print(F("Writing data into block ")); Serial.print(blockAddr);
  98.     Serial.println(F(" ..."));
  99.     dump_byte_array(dataBlock, 16); Serial.println();
  100.     status = (MFRC522::StatusCode) mfrc522.MIFARE_Write(blockAddr, dataBlock, 16);
  101.     if (status != MFRC522::STATUS_OK) {
  102.         Serial.print(F("MIFARE_Write() failed: "));
  103.         Serial.println(mfrc522.GetStatusCodeName(status));
  104.     }
  105.     Serial.println();
  106.     // Read data from the block (again, should now be what we have written)
  107.     Serial.print(F("Reading data from block ")); Serial.print(blockAddr);
  108.     Serial.println(F(" ..."));
  109.     status = (MFRC522::StatusCode) mfrc522.MIFARE_Read(blockAddr, buffer, &size);
  110.     if (status != MFRC522::STATUS_OK) {
  111.         Serial.print(F("MIFARE_Read() failed: "));
  112.         Serial.println(mfrc522.GetStatusCodeName(status));
  113.     }
  114.     Serial.print(F("Data in block ")); Serial.print(blockAddr); Serial.println(F(":"));
  115.     dump_byte_array(buffer, 16); Serial.println();
  116.
  117.     // Check that data in block is what we have written
  118.     // by counting the number of bytes that are equal
  119.     Serial.println(F("Checking result..."));
  120.     byte count = 0;
  121.     for (byte i = 0; i < 16; i++) {
  122.         // Compare buffer (= what we've read) with dataBlock (= what we've written)
  123.         if (buffer[i] == dataBlock[i])
  124.             count++;
  125.     }
  126.     Serial.print(F("Number of bytes that match = ")); Serial.println(count);
  127.     if (count == 16) {
  128.         Serial.println(F("Success :-)"));
  129.     } else {
  130.         Serial.println(F("Failure, no match :-("));
  131.         Serial.println(F("  perhaps the write didn't work properly..."));
  132.     }
  133.     Serial.println();
  134.
  135.     // Dump the sector data
  136.     Serial.println(F("Current data in sector:"));
  137.     mfrc522.PICC_DumpMifareClassicSectorToSerial(&(mfrc522.uid), &key, sector);
  138.     Serial.println();
  139.     // Halt PICC
  140.     mfrc522.PICC_HaltA();
  141.     // Stop encryption on PCD
  142.     mfrc522.PCD_StopCrypto1();
  143. }
  144. /**
  145. * Helper routine to dump a byte array as hex values to Serial.
  146. */
  147. void dump_byte_array(byte *buffer, byte bufferSize) {
  148.     for (byte i = 0; i < bufferSize; i++) {
  149.         Serial.print(buffer[i] < 0x10 ? " 0" : " ");
  150.         Serial.print(buffer[i], HEX);
  151.     }
  152. }
参与人数 1黑币 +100 收起 理由
admin + 100 回帖助人的奖励!
ID:193930 发表于 2017-4-26 18:28 | 显示全部楼层
编译时出错
ID:202098 发表于 2017-5-18 10:52 | 显示全部楼层
不错的资源顶一个
ID:204135 发表于 2017-5-24 01:01 | 显示全部楼层
进来学习,谢谢
ID:204745 发表于 2017-5-25 16:02 | 显示全部楼层
h好好学习了e
ID:204912 发表于 2017-5-25 22:05 | 显示全部楼层
编译时出错了
ID:208140 发表于 2017-6-5 19:07 | 显示全部楼层
好东西,不错的
ID:208516 发表于 2017-6-6 20:47 | 显示全部楼层
很棒耶,還沒試過  很期待
ID:185197 发表于 2017-6-16 13:04 | 显示全部楼层
编译通过,测试如下:
Card UID: B4 F7 6C DB
Card did not respond to 0x40 after HALT command. Are you sure it is a UID changeable one?
Error name: Timeout in communication.
Activating the UID backdoor failed.
Card SAK: 08
PICC type: MIFARE 1KB
Sector Block   0  1  2  3   4  5  6  7   8  9 10 11  12 13 14 15  AccessBits
  15     63   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         62   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         61   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         60   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  14     59   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         58   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         57   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         56   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  13     55   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         54   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         53   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         52   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  12     51   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         50   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         49   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         48   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  11     47   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         46   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         45   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         44   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
  10     43   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         42   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         41   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         40   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   9     39   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         38   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         37   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         36   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   8     35   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         34   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         33   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         32   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   7     31   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         30   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         29   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         28   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   6     27   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         26   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         25   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         24   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   5     23   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         22   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         21   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         20   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   4     19   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         18   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         17   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         16   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   3     15   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         14   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         13   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
         12   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   2     11   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
         10   00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00  [ 0 0 0 ]
   1      7   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
   0      3   00 00 00 00  00 00 FF 07  80 69 FF FF  FF FF FF FF  [ 0 0 1 ]
          0   B4 F7 6C DB  F4 08 04 00  62 63 64 65  66 67 68 69  [ 0 0 0 ]
请问楼主,是不是我的卡是不可擦写的?
ID:216924 发表于 2017-7-3 22:12 | 显示全部楼层
want download
ID:187533 发表于 2017-7-4 05:19 | 显示全部楼层
楼主太棒了,我家的物业太差劲,门禁卡尽然不好用,打不开门,我可以试试能不能学会楼主教的方法把物业KO了。
ID:221197 发表于 2017-7-20 21:31 | 显示全部楼层
不错的资源顶一个,下来试试
ID:152369 发表于 2017-7-31 13:31 | 显示全部楼层
大神,
有实物连线图没
ID:225614 发表于 2017-8-25 08:41 | 显示全部楼层
谢谢,好用
ID:229774 发表于 2017-8-29 00:47 | 显示全部楼层
正要学习,谢谢了。
ID:229732 发表于 2017-9-12 11:11 | 显示全部楼层
学习中……
ID:237269 发表于 2017-10-4 19:49 | 显示全部楼层
直接可以下载吧 在ide上的库
ID:237584 发表于 2017-10-7 10:17 | 显示全部楼层
  怎么修改啊了。
ID:137231 发表于 2017-10-7 23:32 | 显示全部楼层
正要学习,谢谢了。
ID:248934 发表于 2017-11-13 15:14 | 显示全部楼层
学习中,谢谢了。
ID:152369 发表于 2017-11-18 19:08 | 显示全部楼层
怎么再把卡号显示在LED屏上啊??
ID:252134 发表于 2017-11-22 10:55 | 显示全部楼层
显示到LED屏要用LED库,调用相应的函数把串口读取的数据打印出来即可
ID:252131 发表于 2017-11-22 15:25 | 显示全部楼层
yangsir_001 发表于 2017-6-16 13:04
**** 作者被禁止或删除 内容自动屏蔽 ****
对。MF1卡第0扇区第0块好像是产商写死了,里面包含的是卡号、检查字节和制造厂商的数据,可能真的要买1.5的空白卡才能更改
ID:254019 发表于 2017-11-27 09:07 | 显示全部楼层
学习中,谢谢了。
ID:236106 发表于 2017-11-30 19:49 | 显示全部楼层
无以为报,直接点赞666
ID:242562 发表于 2017-12-17 23:19 来自触屏版 | 显示全部楼层
已下载,待测试!
已下载,待测试!有空再搞
ID:106211 发表于 2017-12-18 00:07 | 显示全部楼层
好资料,自已学习还须加把劲
ID:262988 发表于 2017-12-18 10:10 | 显示全部楼层
不错的东西,回头试试
ID:143443 发表于 2018-3-30 17:03 | 显示全部楼层
黑币,您当前的黑币不足,请通过以下途径获取黑币:
ID:296286 发表于 2018-4-2 00:27 | 显示全部楼层
呃 没有看懂 是不是太蠢了
ID:100167 发表于 2018-4-4 16:08 | 显示全部楼层
了解下,弄这个复制问题已弄了很久了
ID:281421 发表于 2018-4-13 20:06 | 显示全部楼层
66666666666666666666666
ID:330537 发表于 2018-5-15 16:18 | 显示全部楼层
正要找这个
ID:265120 发表于 2018-5-25 00:58 | 显示全部楼层
用白卡还是出现" Card did not respond to 0x40 after HALT command. Are you sure it is a UID changeable one?"
ID:127550 发表于 2018-7-27 12:50 | 显示全部楼层
不错的资源顶一个,下来试试
