查看: 5093|回复: 2
NJW1194量产单片机源程序
大批量产的程序,可以直接使用。
  1. #include  "TypeDefine.H"
  2. #include "ConstantDefine.h"
  3. #include "NJW1194.H"
  4. #include "PublicVariable.H"
  5. /*******************************************************************************************************************
  6. 程序名称:   void NJW1194Driver(u8 type, u8 Value1, BYTE Value2)
  7. 程序功能:   驱动音调输入等控制
  8. 入口参数:   type,Value
  9. 出口参数:   无
  10. 调用子程序:WriteNjw1194(DataTemp)
  11. ********************************************************************************************************************/
  12. void NJW1194Driver(u8 type, u8 Value1, u8 Value2)
  13. {
  14.                 u16 DataTemp;
  15.                 switch(type)
  16.                 {
  17.                                 case NJW1194_VOLUME:
  18.                                         if((Value1 <= VOLUME_MIN) || (Value2 <= VOLUME_MIN))
  19.                                         {
  20.                                                     Value1 = Value2 = VOLUME_MIN;
  21.                                         }
  22.                                         else
  23.                                         {
  24.                                                     if((Value1 + MUSIC_BALANC_0DB) >= MusicBalanc)
  25.                                                     {
  26.        Value1 = Value1 + MUSIC_BALANC_0DB - MusicBalanc;
  27.                                                     }
  28.                                                     else
  29.                                                     {
  30.        Value1 = VOLUME_MIN;
  31.                                                     }
  32.                                                     if((Value2 + MusicBalanc) >= MUSIC_BALANC_0DB)
  33.                                                     {
  34.        Value2 = Value2 + MusicBalanc - MUSIC_BALANC_0DB;
  35.                                                     }
  36.                                                     else
  37.                                                     {
  38.        Value2 = VOLUME_MIN;
  39.                                                     }
  40.                                         }
  41.
  42.                                         if(Value1 > VOLUME_MAX)
  43.                                         {
  44.                                                     Value1 = VOLUME_MAX;
  45.                                         }
  46.                                         if(Value2 > VOLUME_MAX)
  47.                                         {
  48.                                                     Value2 = VOLUME_MAX;
  49.                                         }
  50.
  51.        if(Value1 <= 0)
  52.        {
  53.        DataTemp = 255;
  54.        }
  55.                                         else
  56.                                         {
  57.                                                 DataTemp = 255 - Value1 - 55;
  58.                                         }
  59.                                         DataTemp = (((DataTemp << 8) & 0xFF00)) | NJW1194_ADD;
  60.        WriteNjw1194(DataTemp);
  61.
  62.        if(Value2 <= 0)
  63.        {
  64.        DataTemp = 255;
  65.        }
  66.        else
  67.        {
  68.        DataTemp = 255 - Value2 - 55;
  69.        }
  70.        DataTemp = (((DataTemp << 8) & 0xFF00)) | NJW1194_ADD;
  71.        WriteNjw1194(DataTemp | 0x10);
  72.        break;
  73.
  74.                                  case INPUT1194_SEL:
  75.        DataTemp = Value1;
  76.        DataTemp = (((DataTemp << 10) & 0xFF00) | 0x20 | NJW1194_ADD);
  77.        WriteNjw1194(DataTemp);
  78.        break;
  79.
  80.                                 case TREB1194:
  81.        DataTemp = NJW1194TONE_TAB[Value1];
  82.        if(Value1 > 10)
  83.        {
  84.        DataTemp |=  0x80;
  85.        }
  86.        //if(BypassMode)
  87.        {
  88.        DataTemp |= 0x04;
  89.        }
  90.        /*else
  91.        {
  92.        DataTemp &= 0xFB;                        //音调控制OFF
  93.        }*/
  94.        DataTemp = (((DataTemp << 8) & 0xFF00) | 0x30 | NJW1194_ADD);
  95.        WriteNjw1194(DataTemp);
  96.        break;
  97.                                 case BASS1194:
  98.        DataTemp = NJW1194TONE_TAB[Value1];
  99.        if(Value1 > 10)
  100.        {
  101.        DataTemp |=  0x80;
  102.        }
  103.
  104.        DataTemp = (((DataTemp << 8) & 0xFF00) | 0x40 | NJW1194_ADD);
  105.        WriteNjw1194(DataTemp);
  106.        break;
  107.                                  default:
  108.                                                         break;
  109.                 }
  110. }
  111. /***************************************************************************************************************
  112. 程序名称:   void        WriteNjw1194(u16 InData)
  113. 程序功能:   送数据
  114. 入口参数:   In_Data
  115. 出口参数:   无
  116. 调用子程序:Delay_1us(BYTE Count)
  117. ****************************************************************************************************************/
  118. void        WriteNjw1194(u16 InData)
  119. {
  120.                 u8 Couner;
  121.                 NJW1194EnPort(0);
  122.                 Delay_us(2);
  123.
  124.                 //_asm("sim");
  125.                 for(Couner = 0; Couner < 16; Couner ++)
  126.                 {
  127.                                 NJW1194DataPort(InData & 0x8000);
  128.                                 Delay_us(2);
  129.                                 NJW1194ClkPort(0);
  130.
  131.                                 Delay_us(2);
  132.                                 NJW1194ClkPort(1);
  133.                                 InData = InData << 1;
  134.                 }
  135.                 //_asm("rim");
  136.                 Delay_us(2);
  137.                 NJW1194EnPort(1);
  138.                 Delay_us(2);
  139.                 NJW1194ClkPort(1);
  140.
  141. }
  142. /*******************************************************************************************************************
  143. 程序名称:   void NJW1194Driver(u8 type, u8 Value1, BYTE Value2)
  144. 程序功能:   驱动音调输入等控制
  145. 入口参数:   type,Value
  146. 出口参数:   无
  147. 调用子程序:void NJW1194Init(void)
  148. ********************************************************************************************************************/
  149. void NJW1194Init(void)
  150. {
  151.         NJW1194Driver(NJW1194_VOLUME, 0, 0);
  152.         NJW1194Driver(INPUT1194_SEL, 0, 0);
  153.         NJW1194Driver(TREB1194, MUSIC_TREBLE_0DB, MUSIC_TREBLE_0DB);
  154.         NJW1194Driver(BASS1194, MUSIC_BASS_0DB, MUSIC_BASS_0DB);
  155. }
NJW1194 code .rar (1.42 KB, 下载次数: 70)
ID:386811 发表于 2018-8-16 18:34 | 只看该作者
还有3个H头文件没上传呢。请上传一下,谢谢。
ID:48994 发表于 2021-10-15 15:26 | 只看该作者
程序不完整呢!
