查看: 3697|回复: 9
51单片机小白求助74HC595时钟显示程序,不知道怎修改才能显示出来
ID:917238 发表于 2021-5-7 21:59 | 显示全部楼层 |阅读模式
本人用的STC89C52RC芯片,4位共阳595两片模块数码管
#include <REG52.H>
sbit sda=P2^0;
sbit sclk=P2^2;
sbit rclk=P2^1;
uchar hou,min,sec;
uchar code table[]=        { 0x84, 0xF5, 0x4C, 0x64, 0x35, 0x26, 0x06, 0xF4, 0x04, 0x24, 0x14, 0x07, 0x8E, 0x45, 0x0E, 0x1E, 0x7F, 0xFB, 0xFF };
void rck(void)
        rclk=0;
        rclk=1;
        rclk=0;
void shift(uchar dat)
        uchar i;
        rclk=0;
        dat=table[dat];
        for(i=0;i<8;i++)
                sclk=0;
                sda=(dat<<i)&0x80;
                sclk=1;
void init(void)
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
        ET0=1;
        EA=1;
void main(void)
{        uchar sec1=255;
    init();
                if(sec1!=sec)
                        shift(sec%10);
                        shift(sec/10);
                        shift(16);
                        shift(min%10);
                        shift(min/10);
                        shift(16);
                        shift(hou%10);
                        shift(hou/10);
                        rck();
                        sec1=sec;
void time0(void) interrupt 1
    static uchar tcount;
        tcount++;
        if(tcount==20)
                tcount=0;
                sec++;
                if(sec==60)
                        sec=0;
                        min++;
                        if(min==60)
                                min=0;
                                hou++;
                                if(hou==24)
                                        hou=0;
ID:390416 发表于 2021-5-8 00:05 | 显示全部楼层
LED16x16点阵 89单片机+四个74HC595的 程序源码原理图 http://www.51hei.com/bbs/dpj-200961-1.html
ID:213173 发表于 2021-5-8 06:52 | 显示全部楼层
  1. #include <REG52.H>
  2. #define uint unsigned int
  4. sbit sda =P2^0;
  5. sbit sclk=P2^2;
  6. sbit rclk=P2^1;
  7. uchar hou=12,min,sec;
  8. uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0x88,0x83,0xc6,0xa1,0x86,0x8e,0xbf,0x7f};//共阳数码管段码"0~f-."
  9. uchar code wela[]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80};//共阳数码管位码
  10. uchar dis_buf[]={0,0,0xbf,0,0,0xbf,0,0};//显示缓存
  11. void rck(void)
  12. {
  13.         rclk=1;
  14.         rclk=0;
  15. }
  16. void shift(uchar dat)
  17. {
  18.         uchar i;
  19.         for(i=0;i<8;i++)
  20.         {
  21.                 sda=dat&0x80;//提取最高位
  22.                 sclk=1;
  23.                 sclk=0;
  24.                 dat<<=1;
  25.         }
  26. }
  27. void DisplayScan()
  28. {
  29.         static uchar i=0;
  30.         shift(wela[i]);//送位码
  31.         shift(dis_buf[i]);//送段码
  32.         rck();//锁存
  33.         i=++i%8;//循环扫描计数
  34. }
  35. void init(void)
  36. {
  37.         TMOD=0x01;
  38.         TH0=(65536-50000)/256;
  39.         TL0=(65536-50000)%256;
  40.         TR0=1;
  41.         ET0=1;
  42.         EA=1;
  43. }
  44. void main(void)
  45. {
  46.         uchar sec1=255;
  47.         init();
  48.         while(1)
  49.         {
  50.                 if(sec1!=sec)
  51.                 {
  52.                         dis_buf[7]=table[sec%10];
  53.                         dis_buf[6]=table[sec/10];
  54.                         dis_buf[4]=table[min%10];
  55.                         dis_buf[3]=table[min/10];
  56.                         dis_buf[1]=table[hou%10];
  57.                         dis_buf[0]=table[hou/10];
  58.                         sec1=sec;
  59.                 }
  60.                 DisplayScan();
  61.         }
  62. }
  63. void time0(void) interrupt 1
  64. {
  65.         static uchar tcount;
  66.         TH0=(65536-50000)/256;
  67.         TL0=(65536-50000)%256;
  68.         tcount++;
  69.         if(tcount==20)
  70.         {
  71.                 tcount=0;
  72.                 sec++;
  73.                 if(sec==60)
  74.                 {
  75.                         sec=0;
  76.                         min++;
  77.                         if(min==60)
  78.                         {
  79.                                 min=0;
  80.                                 hou++;
  81.                                 if(hou==24)
  82.                                 {
  83.                                         hou=0;
  84.                                 }
  85.                         }
  86.                 }
  87.         }
  88. }
ID:332444 发表于 2021-5-8 08:19 | 显示全部楼层
ID:155507 发表于 2021-5-8 15:41 | 显示全部楼层
4位共阳595两片模块数码管
  4. sbit sda =P2^0;
  5. sbit sclk=P2^2;
  6. sbit rclk=P2^1;
  7. uchar hou=12,min=32,sec=40;
  11. void rck(void)
  12. {
  13.         rclk=1;
  14.         rclk=0;
  15. }
  17. {
  18.         uchar i;
  20.         {
  22.                 sclk=1;
  23.                 sclk=0;
  24.                 dat<<=1;
  25.         }
  26. }
  28. {
  32.         shift(wela[i]);//送位码
  33.         shift(dis_buf[i+4]);//送段码
  34.         rck();//锁存
  35.         i=++i%4;//循环扫描计数
  36. }
  37. void init(void)
  38. {
  39.         TMOD=0x01;
  40.         TH0=(65536-50000)/256;
  41.         TL0=(65536-50000)%256;
  42.         TR0=1;
  43.         ET0=1;
  44.         EA=1;
  45. }
  46. void main(void)
  47. {
  48.         uchar sec1=255;
  49.         init();
  50.         while(1)
  51.         {
  52.                 if(sec1!=sec)
  53.                 {
  54.                         dis_buf[7]=table[sec%10];
  55.                         dis_buf[6]=table[sec/10];
  56.                         dis_buf[4]=table[min%10];
  57.                         dis_buf[3]=table[min/10];
  58.                         dis_buf[1]=table[hou%10];
  59.                         dis_buf[0]=table[hou/10];
  60.                         sec1=sec;
  61.                 }
  62.                 DisplayScan();
  63.         }
  64. }
  65. void time0(void) interrupt 1
  66. {
  67.         static uchar tcount;
  68.         TH0=(65536-50000)/256;
  69.         TL0=(65536-50000)%256;
  70.         tcount++;
  71.         if(tcount==20)
  72.         {
  73.                 tcount=0;
  74.                 sec++;
  75.                 if(sec==60)
  76.                 {
  77.                         sec=0;
  78.                         min++;
  79.                         if(min==60)
  80.                         {
  81.                                 min=0;
  82.                                 hou++;
  83.                                 if(hou==24)
  84.                                 {
  85.                                         hou=0;
  86.                                 }
  87.                         }
  88.                 }
  89.         }
  90. }
ID:917199 发表于 2021-5-8 18:48 | 显示全部楼层
同小白;  是不是应该加个P2=dat?
ID:917199 发表于 2021-5-8 18:55 | 显示全部楼层
o,我搞错了,麻烦管理删掉
ID:57657 发表于 2021-5-8 20:35 | 显示全部楼层
timerzero 发表于 2021-5-8 18:55
o,我搞错了,麻烦管理删掉
点编辑,可以自己删除
ID:917238 发表于 2021-5-15 21:14 来自触屏版 | 显示全部楼层
angmall 发表于 2021-5-8 15:41
4位共阳595两片模块数码管
大神!这个代码显示8和6,但数字会跳动,请问哪里还需要修改一下,谢谢
ID:600695 发表于 2021-10-25 03:27 | 显示全部楼层
复制过去显示乱码,6688,找不到原因
