查看: 2954|回复: 7
LCD1602显示,在实验室使用单片机板成功 在仿真上无法显示
这个需要到LCD显示,但是我在单片机板上显示成功,但是在仿真上无法显示,电路连接应该没有错
#include <reg52.h>
#define uchar  unsigned   char
#define uint  unsigned         int
#define out P2
sbit LED =P1^4;
sbit key1=P3^2;
sbit key2=P3^3;
sbit key3=P3^4;
sbit key4=P3^5;
sbit lcdrs=P0^5;
sbit lcdrw=P0^6;
sbit lcden=P0^7;
void check_busy();
void write_cmd(uchar cmd);
void write_data(uchar dat);
void write_str(uchar *str);
void lcd_init();
void T0_init();//T0初始化
void display(uchar date);
void keyscan();
void delay(uint z);
uchar sec=0,count=0,flag=0,keyflag=0;
{  T0_init();
  lcd_init();
   write_cmd(0x82);
   write_str("sec:");
  {         keyscan();
  switch(keyflag)
  {  case 1:TR0=1;LED=0;break;
     case 2:TR0=0;LED=1;break;
    display(sec);
void T0_init()
{          TMOD=0X01;
          TH0=(65536-50000)/256;
          TL0=(65536-50000)%256;
          ET0=1;
          EA=1;
void lcd_init()
{ write_cmd(0x38);
   write_cmd(0x0c);
   write_cmd(0x06);
   write_cmd(0x01);
   delay(1);
{          check_busy();
          lcdrs=0;
          lcdrw=0;
          lcden=0;
          out=cmd;
          lcden=1;
          delay(1);
          lcden=0;
          delay(1);
void check_busy()
{  uchar dt;
   do
   {dt=0xff;
    lcdrs=0;
        lcdrw=1;
        lcden=0;
        lcden=1;
        dt=out;
   }while(dt&0x80);
   lcden=0;
{         lcdrs=1;
         lcdrw=0;
         lcden=0;
         out=dat;
         lcden=1;
         delay(1);
         lcden=0;
         delay(1);
void delay(uint z)
{ uint i,j;
  for(j=z;j>0;j--)
   for(i=110;i>0;i--);
{  while(*str!='\0')
           write_data(*str++);
           delay(5);
void T0_it()interrupt 1
         count++;
         if(count>=20)
         {   count=0;
             sec++;
         if(sec>=60)
         {sec=0;flag=1;  }
{        write_cmd(0x88);
    write_data(date/10+0x30);
        write_cmd(0x89);
        write_data(date%10+0x30);
void keyscan()
{         key1=1;
    if(key1==0)
        {        delay(10);
           if(key1==0)
           {   while(!key1);
               keyflag=1;
        key2=1;
    if(key2==0)
        {        delay(10);
           if(key2==0)
           {   while(!key2);
               keyflag=2;
        if(key3==0)
        {sec++;
         if(sec==60)sec=60;}
        if(key4==0)
        {sec--;
         if(sec<=0)sec=0;}
屏幕截图 2023-11-17 075529.png (46.4 KB, 下载次数: 73)
ID:94031 发表于 2023-11-17 10:58 | 只看该作者
LCD有多种驱动,实体显示成功仿真不成功很正常。
ID:180919 发表于 2023-11-17 12:04 | 只看该作者
仿真正在的,检查下1602的连线
ID:180919 发表于 2023-11-17 13:39 | 只看该作者
仿真电路MCU的P2口与P1口的网络重复了
ID:213173 发表于 2023-11-17 15:06 | 只看该作者
除了地板指出的P2口与P1口的网络重复了,另外P0.5、P0.6、P0.7还要外接上拉电阻。
ID:1096616 发表于 2023-11-17 22:30 | 只看该作者
哦,原来问题出现在这里,我明白了,不过为什么一定要外接电阻lcd才可以正常显示呢?
ID:213173 发表于 2023-11-18 06:55 | 只看该作者
仿真用的AT89C52的P0与其它端口不同,是开漏模式,内部没有上拉电阻。外部器件如不能提供高电平条件就得外加上拉电阻。
ID:1099277 发表于 2023-11-18 19:11 | 只看该作者
需要加上拉电阻才能驱动lcd显示
