查看: 899|回复: 3
51单片机ILI9341彩屏Proteus仿真程序
  1. #include <reg52.h>
  2. #include <intrins.h>
  3. /* ========== 引脚定义(按接线修改) ========== */
  4. sbit TFT_CS   = P1^0;   // 片选(低有效)
  5. sbit TFT_DC   = P1^1;   // 数据/命令:1=数据 0=命令
  6. sbit TFT_RST  = P1^2;   // 复位(低有效)
  7. sbit TFT_SCK  = P1^3;   // SPI时钟
  8. sbit TFT_MOSI = P1^4;   // SPI主出从入(DIN)
  9. /* ========== 公用延时 ========== */
  10. static void tiny_delay(void) { _nop_(); _nop_(); _nop_(); _nop_(); }
  11. void delay_ms(unsigned int ms){
  12.     unsigned int i,j;
  13.     for(i=0;i<ms;i++) for(j=0;j<125;j++);
  14. }
  15. /* ========== SPI位打发送 ========== */
  16. static void spi_write8(unsigned char v){
  17.     unsigned char i;
  18.     for(i=0;i<8;i++){
  19.         TFT_SCK = 0;
  20.         TFT_MOSI = (v & 0x80) ? 1 : 0;  // 发送高位
  21.         tiny_delay();
  22.         TFT_SCK = 1;                    // 上升沿采样
  23.         tiny_delay();
  24.         v <<= 1;
  25.     }
  26.     TFT_SCK = 0;
  27. }
  28. /* ========== ILI9341 基本写接口 ========== */
  29. static void tft_write_cmd(unsigned char cmd){
  30.     TFT_CS = 0;
  31.     TFT_DC = 0;           // 命令
  32.     spi_write8(cmd);
  33.     TFT_CS = 1;
  34. }
  35. static void tft_write_data8(unsigned char dato){
  36.     TFT_CS = 0;
  37.     TFT_DC = 1;           // 数据
  38.     spi_write8(dato);
  39.     TFT_CS = 1;
  40. }
  41. static void tft_write_data16(unsigned int dato){
  42.     TFT_CS = 0;
  43.     TFT_DC = 1;
  44.     spi_write8((unsigned char)(dato >> 8));  // 高字节
  45.     spi_write8((unsigned char)(dato & 0xFF));// 低字节
  46.     TFT_CS = 1;
  47. }
  48. /* 连续写数据流(提升效率) */
  49. static void tft_begin_stream(void){
  50.     TFT_CS = 0;
  51.     TFT_DC = 1;
  52. }
  53. static void tft_stream_data16(unsigned int dato){
  54.     spi_write8((unsigned char)(dato >> 8));
  55.     spi_write8((unsigned char)(dato & 0xFF));
  56. }
  57. static void tft_end_stream(void){
  58.     TFT_CS = 1;
  59. }
  60. /* ========== 参数与颜色 ========== */
  61. #define TFT_W 240
  62. #define TFT_H 320
  63. /* RGB888→RGB565 */
  64. #define RGB565(r,g,b) ( ((r&0xF8)<<8) | ((g&0xFC)<<3) | ((b)>>3) )
  65. /* 常用色 */
  66. #define COLOR_BLACK   0x0000
  67. #define COLOR_WHITE   0xFFFF
  68. #define COLOR_RED     0xF800
  69. #define COLOR_GREEN   0x07E0
  70. #define COLOR_BLUE    0x001F
  71. #define COLOR_YELLOW  0xFFE0
  72. #define COLOR_CYAN    0x07FF
  73. #define COLOR_MAGENTA 0xF81F
  74. #define COLOR_GRAY    0x8410
  75. /* ========== 设置窗口 & 基础绘图 ========== */
  76. static void tft_set_window(unsigned int x0, unsigned int y0, unsigned int x1, unsigned int y1){
  77.     // Column Address Set
  78.     tft_write_cmd(0x2A);
  79.     tft_write_data8(x0 >> 8); tft_write_data8(x0 & 0xFF);
  80.     tft_write_data8(x1 >> 8); tft_write_data8(x1 & 0xFF);
  81.     // Page Address Set
  82.     tft_write_cmd(0x2B);
  83.     tft_write_data8(y0 >> 8); tft_write_data8(y0 & 0xFF);
  84.     tft_write_data8(y1 >> 8); tft_write_data8(y1 & 0xFF);
  85.     // Memory Write
  86.     tft_write_cmd(0x2C);
  87. }
  88. void tft_draw_pixel(unsigned int x, unsigned int y, unsigned int color){
  89.     if(x>=TFT_W || y>=TFT_H) return;
  90.     tft_set_window(x, y, x, y);
  91.     tft_write_data16(color);
  92. }
  93. void tft_fill_rect(unsigned int x, unsigned int y, unsigned int w, unsigned int h, unsigned int color){
  94.     unsigned long count;
  95.     unsigned int i;
  96.     if(x>=TFT_W || y>=TFT_H) return;
  97.     if(x+w-1 >= TFT_W) w = TFT_W - x;
  98.     if(y+h-1 >= TFT_H) h = TFT_H - y;
  99.     tft_set_window(x, y, x+w-1, y+h-1);
  100.     count = (unsigned long)w * h;
  101.     tft_begin_stream();
  102.     while(count--) tft_stream_data16(color);
  103.     tft_end_stream();
  104. }
  105. void tft_fill_screen(unsigned int color){
  106.     tft_fill_rect(0, 0, TFT_W, TFT_H, color);
  107. }
  108. /* 画线(Bresenham) */
  109. void tft_draw_line(int x0,int y0,int x1,int y1,unsigned int color){
  110.     int dx = (x1>x0) ? (x1-x0) : (x0-x1);
  111.     int sx = (x0<x1) ? 1 : -1;
  112.     int dy = (y1>y0) ? (y0-y1) : (y1-y0);
  113.     int sy = (y0<y1) ? 1 : -1;
  114.     int err = dx + dy, e2;
  115.     for(;;){
  116.         tft_draw_pixel(x0,y0,color);
  117.         if(x0==x1 && y0==y1) break;
  118.         e2 = 2*err;
  119.         if(e2 >= dy){ err += dy; x0 += sx; }
  120.         if(e2 <= dx){ err += dx; y0 += sy; }
  121.     }
  122. }
  123. /* 画矩形(边框) */
  124. void tft_draw_rect(unsigned int x, unsigned int y, unsigned int w, unsigned int h, unsigned int color){
  125.     if(w==0 || h==0) return;
  126.     tft_draw_line(x, y, x+w-1, y, color);
  127.     tft_draw_line(x, y+h-1, x+w-1, y+h-1, color);
  128.     tft_draw_line(x, y, x, y+h-1, color);
  129.     tft_draw_line(x+w-1, y, x+w-1, y+h-1, color);
  130. }
  131. /* ========== ILI9341 初始化(常用序列) ========== */
  132. void tft_reset(void){
  133.     TFT_RST = 1; TFT_CS = 1; TFT_SCK = 0; TFT_MOSI = 0;
  134.     delay_ms(5);
  135.     TFT_RST = 0; delay_ms(20);
  136.     TFT_RST = 1; delay_ms(120);
  137. }
  138. void tft_init(void){
  139.     tft_reset();
  140.     // ILI9341 init (通用稳定序列)
  141.     tft_write_cmd(0xEF); tft_write_data8(0x03); tft_write_data8(0x80); tft_write_data8(0x02);
  142.     tft_write_cmd(0xCF); tft_write_data8(0x00); tft_write_data8(0xC1); tft_write_data8(0x30);
  143.     tft_write_cmd(0xED); tft_write_data8(0x64); tft_write_data8(0x03); tft_write_data8(0x12); tft_write_data8(0x81);
  144.     tft_write_cmd(0xE8); tft_write_data8(0x85); tft_write_data8(0x00); tft_write_data8(0x78);
  145.     tft_write_cmd(0xCB); tft_write_data8(0x39); tft_write_data8(0x2C); tft_write_data8(0x00); tft_write_data8(0x34); tft_write_data8(0x02);
  146.     tft_write_cmd(0xF7); tft_write_data8(0x20);
  147.     tft_write_cmd(0xEA); tft_write_data8(0x00); tft_write_data8(0x00);
  148.     tft_write_cmd(0xC0); tft_write_data8(0x23);      // Power control VRH[5:0]
  149.     tft_write_cmd(0xC1); tft_write_data8(0x10);      // Power control SAP[2:0];BT[3:0]
  150.     tft_write_cmd(0xC5); tft_write_data8(0x3E); tft_write_data8(0x28); // VCM
  151.     tft_write_cmd(0xC7); tft_write_data8(0x86);      // VCM control2
  152.     // 内存访问控制:0x48 竖屏,BGR=1;如需横屏可改 0x28/0xE8 等
  153.     tft_write_cmd(0x36); tft_write_data8(0x48);
  154.     // 像素格式:16bpp RGB565
  155.     tft_write_cmd(0x3A); tft_write_data8(0x55);
  156.     tft_write_cmd(0xB1); tft_write_data8(0x00); tft_write_data8(0x18);  // Frame rate
  157.     tft_write_cmd(0xB6); tft_write_data8(0x08); tft_write_data8(0x82); tft_write_data8(0x27); // Display Function
  158.     tft_write_cmd(0xF2); tft_write_data8(0x00);  // 3Gamma off
  159.     tft_write_cmd(0x26); tft_write_data8(0x01);  // Gamma curve
  160.     // Gamma设置(可按需调整)
  161.     tft_write_cmd(0xE0);
  162.     tft_write_data8(0x0F); tft_write_data8(0x31); tft_write_data8(0x2B); tft_write_data8(0x0C);
  163.     tft_write_data8(0x0E); tft_write_data8(0x08); tft_write_data8(0x4E); tft_write_data8(0xF1);
  164.     tft_write_data8(0x37); tft_write_data8(0x07); tft_write_data8(0x10); tft_write_data8(0x03);
  165.     tft_write_data8(0x0E); tft_write_data8(0x09); tft_write_data8(0x00);
  166.     tft_write_cmd(0xE1);
  167.     tft_write_data8(0x00); tft_write_data8(0x0E); tft_write_data8(0x14); tft_write_data8(0x03);
  168.     tft_write_data8(0x11); tft_write_data8(0x07); tft_write_data8(0x31); tft_write_data8(0xC1);
  169.     tft_write_data8(0x48); tft_write_data8(0x08); tft_write_data8(0x0F); tft_write_data8(0x0C);
  170.     tft_write_data8(0x31); tft_write_data8(0x36); tft_write_data8(0x0F);
  171.     // 退出睡眠、开显示
  172.     tft_write_cmd(0x11); delay_ms(120);
  173.     tft_write_cmd(0x29); delay_ms(20);
  174.     tft_fill_screen(COLOR_BLACK);
  175. }
  176. /* ========== 6×8 点阵字体(精简版) ========== */
  177. /* 说明:为控制篇幅,此处提供数字'0'~'9'、大写'A'~'Z'、空格及符号".:-/"等
  178.    未覆盖字符显示为空白。你可按需扩展完整ASCII表。 */
  179. typedef struct { char ch; unsigned char cols[6]; } glyph_t;
  180. unsigned char code GLYPH_SPACE[6] = {0,0,0,0,0,0};
  181. const glyph_t code font6x8[] = {
  182.     {' ',{0,0,0,0,0,0}},
  183.     {'0',{0x3E,0x51,0x49,0x45,0x3E,0x00}},
  184.     {'1',{0x00,0x42,0x7F,0x40,0x00,0x00}},
  185.     {'2',{0x62,0x51,0x49,0x49,0x46,0x00}},
  186.     {'/',{0x40,0x30,0x0C,0x03,0x00,0x00}}
  187. };
  188. #define FONT_COUNT (sizeof(font6x8)/sizeof(font6x8[0]))
  189. /* 查找字模;未找到返回空白 */
  190. static const unsigned char* font_lookup(char ch){
  191.     unsigned char i;
  192.     for(i=0;i<FONT_COUNT;i++){
  193.         if(font6x8[i].ch == ch) return font6x8[i].cols;
  194.     }
  195.     return GLYPH_SPACE;
  196. }
  197. /* 在(x,y)绘制6×8字符(前景/背景色),左上为起点 */
  198. void tft_draw_char6x8(unsigned int x, unsigned int y, char ch, unsigned int fg, unsigned int bg){
  199.     unsigned char col, row;
  200.     const unsigned char* p = font_lookup(ch);
  201.     if(x+6 > TFT_W || y+8 > TFT_H) return;
  202.     tft_set_window(x, y, x+5, y+7);
  203.     tft_write_cmd(0x2C); // RAMWR
  204.     tft_begin_stream();
  205.     for(row=0; row<8; row++){
  206.         for(col=0; col<6; col++){
  207.             if( (p[col] >> row) & 0x01 ) tft_stream_data16(fg);
  208.             else                         tft_stream_data16(bg);
  209.         }
  210.     }
  211.     tft_end_stream();
  212. }
  213. /* 打印字符串,等宽间隔=6像素 */
  214. void tft_print6x8(unsigned int x, unsigned int y, const char* s, unsigned int fg, unsigned int bg){
  215.     unsigned int cx = x;
  216.     while(*s){
  217.         if(*s=='\n'){ y += 8; cx = x; s++; continue; }
  218.         tft_draw_char6x8(cx, y, *s, fg, bg);
  219.         cx += 6;
  220.         s++;
  221.         if(cx+6 > TFT_W){ y+=8; cx = x; }
  222.         if(y+8 > TFT_H) break;
  223.     }
  224. }
  225. /* ========== 示例:主程序 ========== */
  226. void main(void){
  227.     unsigned int i;
  228.     tft_init();
  229.     // 彩条测试
  230.     tft_fill_rect(0,   0, TFT_W, 40, COLOR_RED);
  231.     tft_fill_rect(0,  40, TFT_W, 40, COLOR_GREEN);
  232.     tft_fill_rect(0,  80, TFT_W, 40, COLOR_BLUE);
  233.     tft_fill_rect(0, 120, TFT_W, 40, COLOR_CYAN);
  234.     tft_fill_rect(0, 160, TFT_W, 40, COLOR_MAGENTA);
  235.     tft_fill_rect(0, 200, TFT_W, 40, COLOR_YELLOW);
  236.     tft_fill_rect(0, 240, TFT_W, 40, COLOR_GRAY);
  237.     tft_fill_rect(0, 280, TFT_W, 40, COLOR_WHITE);
  238.     // 文本与图形
  239.     tft_print6x8(10, 10,  "TFT LCD ILI9341", COLOR_WHITE, COLOR_RED);
  240.     tft_print6x8(10, 26,  "SPI 4-WIRE DEMO", COLOR_WHITE, COLOR_GREEN);
  241.     tft_print6x8(10, 42,  "RES 240x320",     COLOR_WHITE, COLOR_BLUE);
  242.     tft_draw_rect(20, 100, 200, 120, COLOR_WHITE);
  243.     for(i=0;i<50;i++){
  244.         tft_draw_line(20,100+i, 219,100+119-i, COLOR_WHITE);
  245.     }
  246.     // 简单计数刷新(避开全屏,以免过慢)
  247.     {
  248.         unsigned int cnt = 0;
  249.         char buf[20];
  250.         while(1){
  251.             // 覆盖区域清背景
  252.             tft_fill_rect(20, 230, 200, 16, COLOR_BLACK);
  253.             // 构造字符串(只用到数字/大写)
  254.             buf[0]='C';buf[1]='N';buf[2]='T';buf[3]=':';buf[4]=' '; // "CNT:
仿真程序下载:
TFT9341_SPI.rar (133.21 KB, 下载次数: 0)
收藏收藏1 分享淘帖 顶 踩
ID:164988 发表于 2026-4-21 12:06 | 只看该作者
附件下载不了,光标移动到附件标题上时出现的提示框正好挡在要下载的附件标题上,导致不能下载附件。我尝试关掉文件重启,无效。关掉浏览器后重新操作,无效。关机重启后操作也还是无效。去查看其他帖子的附件下载情况发现:当光标移动到要下载的附件标题上时,出现的提示框是在要下载附件标题的上方,且不会遮挡到要下载附件标题
ID:164988 发表于 2026-4-21 14:44 | 只看该作者
LXJ50 发表于 2026-4-21 12:06
附件下载不了,光标移动到附件标题上时出现的提示框正好挡在要下载的附件标题上,导致不能下载附件。我尝试 ...
刚刚又试了下,这回可以了。
ID:433219 发表于 2026-4-21 17:05 | 只看该作者
刷新一屏幕,速度多少????  超过200ms就没有实际效果了
