查看: 3816|回复: 1
PWM_控制LED达到呼吸灯效果(如果要移植但还得改一下因为有延时程序)
ID:76556 发表于 2015-4-10 01:49 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg52.h>
sbit PWMOUT = P0^0;
sbit ADDR0 = P1^0;
sbit ADDR1 = P1^1;
sbit ADDR2 = P1^2;
sbit ADDR3 = P1^3;
sbit ENLED = P1^4;
unsigned char HighRH = 0;
unsigned char HighRL = 0;
unsigned char LowRH = 0;
unsigned char LowRL = 0;
void PWM_Delays(unsigned int x)
unsigned int q;
for(q=x;q>0;q--);
    ENLED = 0;  //使能独立LED
    ADDR3 = 1;
    ADDR2 = 1;
    ADDR1 = 1;
    ADDR0 = 0;
    while (1)
static unsigned int Num1=0;
static unsigned int Num2=500;
static bit bit1=0;
PWMOUT=1;
  if(bit1==1)
  if(Num1==0)
   PWMOUT=0;
   bit1=0;
  Num1--;
  Num2++;
PWM_Delays(Num1);
PWMOUT=0;
PWM_Delays(Num2);
if(bit1==0)
  if(Num1==500)
   unsigned int q,h;
   PWMOUT=1;
   for(h=60000;h>0;h--);
   for(q=60000;q>0;q--);
   bit1=1;
  Num1++;
  Num2--;
ID:156130 发表于 2016-12-22 21:09 | 只看该作者
怎么修改
