查看: 2209|回复: 1
AVR驱动12864的C程序,怎么不显示
ID:99453 发表于 2016-4-6 20:03 | 显示全部楼层 |阅读模式
#define F_CPU 8000000UL
#include <avr/io.h>
#include <util/delay.h>
/*#define CLK_H PORTB|=(1<<1)
#define CLK_L PORTB&=~(1<<1)
#define SID_H PORTB|=(1<<0)
#define SID_L PORTB&=~(1<<0)*/
#define CLK_H PORTC|=(1<<PC4)
#define CLK_L PORTC&=~(1<<PC4)
#define SID_H PORTC|=(1<<PC3)
#define SID_L PORTC&=~(1<<PC3)
void send_byte(uchar byte)
uint i;
for (i=0;i<8;i++)
  if(byte&0x80)
   SID_H; //为1 给1
   SID_L;  //为0 给0
  CLK_L;//拉低时钟
  CLK_H;//拉高时钟
  byte=byte<<1;
void write_com(uchar com)
send_byte(0xf8);//step 1
send_byte(0xf0&com);//step 2
send_byte(0xf0&(com<<4));//step 3
_delay_ms(50);
void write_data(uchar data)
send_byte(0xfa);
send_byte(0xf0&data);
send_byte(0xf0&(data<<4));
_delay_ms(50);
void lcd12864_init()
_delay_ms(50);
write_com(0x30);
_delay_ms(50);
write_com(0x0f);//整体和游标显示
_delay_ms(50);
write_com(0x01);
_delay_ms(50);
void display()
  write_com(0x80);
  _delay_ms(50);
  write_data(200);
  _delay_ms(50);
  write_com(0x80+0x10);
  _delay_ms(50);
  write_data(0x31);
DDRB|=(1<<PB0)|(1<<PB1);
  DDRC|=(1<<PC3)|(1<<PC4);
lcd12864_init();
_delay_ms(100);
while (1)
  display();
上面是我的代码,是串口写的,记得刚写好的时候还可以看到游标闪烁,但写了一个数据进去后就出问题了,再没显示,只是屏幕亮着,请问你们遇到过这种情况吗
ID:113338 发表于 2016-4-10 19:44 | 显示全部楼层
牛牛牛牛
