查看: 2598|回复: 2
求助,PCF8591模块程序那里写的不对
用PCF8591模块,连接单片机,1602液晶显示,大师们帮忙看看那里写的不对,液晶只显示0000,初学者,谢谢!
#include<reg51.h>
sbit scl=P2^6;
sbit sda=P2^7;
sbit rs=P2^0;
sbit rw=P2^1;
sbit lcden=P2^2;
uchar date;
uchar code table[]="0123456789";
void i2cinit();
void i2cstart();
void i2crespons();
void i2cstop();
void i2cwritebyte(uchar date);
uchar i2creadbyte();
void readi2c();
void write_com(uchar com);
void write_date(uchar date);
void lcdinit();
void lcdplay();
void delay(uchar z)
        uchar x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void i2cinit()
        scl=1;
        delay(5);
        sda=1;
        delay(5);
void i2cstart()
        sda=1;
        delay(5);
        scl=1;
        delay(5);
        sda=0;
        delay(5);
void i2crespons()
        uchar i=0;
        scl=1;
        delay(5);
        while(sda==1&&i<255)
                i++;
        scl=0;
        delay(5);
void i2cstop()
        sda=0;
        delay(5);
        scl=1;
        delay(5);
        sda=1;
        delay(5);
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;
                scl=0;
                delay(5);
                sda=CY;
                delay(5);
                scl=1;
                delay(5);
        scl=0;
        delay(5);
        sda=1;
        delay(5);
uchar i2creadbyte()
        uchar i,k;
        scl=0;
        delay(5);
        sda=1;
        for(i=0;i<8;i++)
                scl=1;
                delay(5);
                k=(k<<1|sda);
                scl=0;
                delay(5);
        return k;
void readi2c()
        uchar date;
        i2cinit();
        i2cstart();
        i2cwritebyte(0x90);
        i2crespons();
        i2cwritebyte(0x01);
        i2crespons();
        i2cwritebyte(0x91);
        i2crespons();
        date=i2creadbyte();
        i2cstop();
        rs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
        rs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void lcdinit()
        rw=0;
        write_com(0x38);
        write_com(0x0c);
void lcdplay()
        uchar qian,bai,shi,ge;
        lcdinit();
        qian=date/1000;
        bai=date%1000/100;
        shi=date%100/10;
        ge=date%10;
        write_com(0x80+0x00);
        write_date(table[qian]);
        write_com(0x80+0x01);
        write_date(table[bai]);
        write_com(0x80+0x02);
        write_date(table[shi]);
        write_com(0x80+0x03);
        write_date(table[ge]);
        readi2c();
                lcdplay();
ID:227639 发表于 2017-8-14 21:30 | 只看该作者
你参考这个例程
PCF8563芯片时序程序.doc
227.5 KB, 下载次数: 10
ID:111634 发表于 2017-8-25 17:17 | 只看该作者
实例85  PCF8591 I2C串行A-D(1602显示)
实例85 PCF8591 I2C串行A-D.rar (57.96 KB, 下载次数: 10)
Proteus仿真一下,确认有效。
以上摘自张志良编著《80C51单片机仿真设计实例教程——基于Keil CProteus》清华大学出版社ISBN 978-7-302-41682-1书中电路和程序设计有详细说明,程序语句条条有注解。仿真电路和Hex文件能在清华出版社网站免费下载,程序源代码只能到书上看了。到图书馆借,或到新华书店翻阅,或到网上书店打折购买。
