查看: 2609|回复: 0
单片机1602电子时钟加按键灯程序
ID:509174 发表于 2020-4-10 08:49 | 显示全部楼层 |阅读模式
用1602显示时间
单片机内部定时器计数
按键控制台灯
蓝牙控制台灯
  1. //用51单片机仅更换头文件即可套用
  2. #include <STC12C5A60S2.H>
  3. #include<intrins.h>
  5. #define uint unsigned int
  6.
  7. void UsartConfiguration();
  8. sbit k = P2^4;                                //开灯
  9. sbit led = P1^0;                                //led灯
  10. sbit EP = P2^7; //使能端
  11. sbit RW = P2^5; //数据/命令选择端
  12. sbit RS = P2^6; //读写选择端
  13. sbit KEY_1 = P3^2;          //按键设置模式选择
  14. sbit KEY_2 = P3^3;          //按键
  15. static uint code table1[] = {0, 31, 60, 91, 121, 152,182, 213, 243, 274, 304, 335};
  16. static uchar code *Week[7] = {"Sun","Mon","Tue" ,"Wed", "Thu", "Fri", "Sat"};
  17. uchar sec = 0, hour = 12, minu = 0;
  18. uchar count = 0, week = 0; month = 1, day = 1;
  19. uint a,num;
  20. void InitTimer0()
  21. {
  22.         ET0 = 1;
  23.         TMOD = 0x21;
  24.         TH0 = (65536 - 46071)/256;
  25.         TL0 = (65536 - 46071)%256;
  26.         TR0 = 1;
  27. }
  28. void delay(uint ms)
  29. {
  30.         uint i, j;
  31.         for(i=ms; i>0; i--)
  32.                 for(j=920; j>0; j--);
  33. }
  34. void Write_Cmd(uchar cmd) //写入命令
  35. {
  36.        // Lcd_Ready();
  37.         RS = 0;
  38.         RW = 0;
  39.         EP = 0;
  40.         P0 = cmd;
  41.         delay(5);
  42.         EP = 1;
  43.         delay(5);
  44.         EP = 0;
  45. }
  46. void Write_Dat(uchar dat) //写入数据
  47. {
  48.        // Lcd_Ready();  //LCD1602 不忙则跳出
  49.         RS = 1;
  50.         RW = 0;
  51.         EP = 0;
  52.         P0 = dat;
  53.         delay(5);
  54.         EP = 1;
  55.         delay(5);
  56.         EP = 0;
  57. }
  58. void Write_Week(uchar day, uchar month)                        //星期与日期同步
  59. {
  60.         week = (table1[(month - 1)] + day -5);
  61.         week = week % 7;
  62.         Write_Cmd(0x80 + 12);
  63.         while(*Week[week] != '\0')
  64.                 Write_Dat(*Week[week]++);
  65. }
  66. void Write_Num(uchar x, uchar y, uchar num) //将时分秒和日期写入1602
  67. {
  68.         uchar unit, decad;
  69.         unit = num % 10;
  70.         decad = num /10;
  71.         if(y == 1)
  72.         {
  73.                 Write_Cmd(0x80 + 0x40 + x);
  74.                 Write_Dat(0x30 + decad);         //即加48,将数字转换为ASC||字符数字
  75.                 Write_Dat(0x30 + unit);
  76.         }
  77.         else
  78.         {
  79.                 Write_Cmd(0x80 + x);
  80.                 Write_Dat(0x30 + decad);
  81.                 Write_Dat(0x30 + unit);
  82.         }
  83. }
  84. void Lcd_Init()          //LCD初始化设定
  85. {
  86.         Write_Cmd(0x38); // 16*2显示,5*7点阵,8位数据
  87.         Write_Cmd(0x0c); // 显示开,关光标
  88.         Write_Cmd(0x06); // 读写地址自动加1,光标加1
  89.         Write_Cmd(0x01); //清除屏幕
  90.                 Write_Cmd(0x80);
  91. }
  92. void Display()  //
  93. {
  94.         Write_Week(day, month);
  95.         Write_Num(9, 0, day);
  96.         Write_Num(6, 0, month);
  97.         Write_Num(4, 1, hour);
  98.         Write_Num(7, 1, minu);
  99.         Write_Num(10, 1, sec);
  100.         Write_Cmd(0x80 + 0x40 + 6);
  101.         Write_Dat(':');
  102.         Write_Cmd(0x80 + 0x40 + 9);
  103.         Write_Dat(':');
  104. }
  105. void TimerCount()
  106. {
  107.         if(count == 20)
  108.         {
  109.                 count = 0;
  110.                 sec++;
  111.                 if(sec == 60)
  112.                 {
  113.                         sec = 0;
  114.                         minu++;
  115.                          if(minu == 60)
  116.                         {
  117.                                         minu = 0;
  118.                                         hour++;
  119.                                          if(hour == 24)
  120.                                         {
  121.                                                         hour = 0;
  122.                                                         day++;
  123.                                                         week++;
  124.                                                         if(week == 7)
  125.        week = 0;
  126.                                                         switch(month)
  127.                                                         {
  128.        case 1:
  129.        if(day == 32)
  130.        {
  131.        day = 0;
  132.        month++;
  133.
  134.        break;
  135.        }
  136.        case 2:
  137.        if(day == 29)
  138.        {
  139.        day = 0;
  140.        month++;
  141.
  142.        break;
  143.        }
  144.        case 3:
  145.        if(day == 32)
  146.        {
  147.        day = 0;
  148.        month++;
  149.        Write_Num(6, 0, month);
  150.        break;
  151.        }
  152.        case 4:
  153.        if(day == 31)
  154.        {
  155.        day = 0;
  156.        month++;
  157.
  158.        break;
  159.        }
  160.        case 5:
  161.        if(day == 32)
  162.        {
  163.        day = 0;
  164.        month++;
  165.
  166.        break;
  167.        }
  168.        case 6:
  169.        if(day == 31)
  170.        {
  171.        day = 0;
  172.        month++;
  173.
  174.        break;
  175.        }
  176.        case 7:
  177.        if(day == 32)
  178.        {
  179.        day = 0;
  180.        month++;
  181.
  182.        break;
  183.        }
  184.        case 8:
  185.        if(day == 32)
  186.        {
  187.        day = 0;
  188.        month++;
  189.
  190.        break;
  191.        }
  192.        case 9:
  193.        if(day == 31)
  194.        {
  195.        day = 0;
  196.        month++;
  197.
  198.        break;
  199.        }
  200.        case 10:
  201.        if(day == 32)
  202.        {
  203.        day = 0;
  204.        month++;
  205.
  206.        break;
  207.        }
  208.        case 11:
  209.        if(day == 31)
  210.        {
  211.        day = 0;
  212.        month++;
  213.        Write_Num(6, 0, month);
  214.        break;
  215.        }
  216.        case 12:
  217.        if(day == 32)
  218.        {
  219.        day = 0;
  220.        month = 1;
  221.        Write_Num(6, 0, month);
  222.        break;
  223.        }
  224.                                                         }
  225.
  226.                                         }
  227.
  228.                         }
  229.
  230.                 }
  231.                 Display();
  232.         }
  233. }
  234. void KeyScan()
  235. {
  236.                 static uchar key1cnt = 0;                //KEY_1按下的次数
  237.
  238.                 if(KEY_1 == 0)
  239.                 {
  240.                         delay(10);
  241.                         if(KEY_1 == 0)
  242.                         {
  243.                                         key1cnt++;
  244.                                         while(!KEY_1);
  245.                                         switch(key1cnt)
  246.                                         {
  247.                                                 case 1:
  248.        TR0 = 0;
  249.        Write_Cmd(0x80 + 0x40 + 5);
  250.        Write_Cmd(0x0F);            //显示光标且光标闪烁
  251.        break;
  252.                                                 case 2:
  253.        Write_Cmd(0x80 + 0x40 + 8);
  254.        break;
  255.                                                 case 3:
  256.        Write_Cmd(0x80 + 0x40 + 11);
  257.        break;
  258.                                                 case 4:
  259.        Write_Cmd(0x80 + 7);
  260.        break;
  261.                                                 case 5:
  262.        Write_Cmd(0x80 + 10);
  263.        break;
  264.                                                 case 6:
  265.        TR0 = 1;
  266.        Write_Cmd(0x0C);           //不显示光标
  267.        key1cnt = 0;
  268.        break;
  269.                                         }
  270.                         }
  271.                 }
  272.                 if(key1cnt != 0)
  273.                 {
  274.                         if(KEY_2 == 0)
  275.                         {
  276.                                 delay(10);
  277.                                 if(KEY_2 == 0)
  278.                                 {
  279.                                         while(!KEY_2);
  280.                                         switch(key1cnt)
  281.                                         {
  282.                                                 case 1:
  283.        hour++;
  284.        if(hour == 24)
  285.        hour = 0;
  286.        Write_Num(4, 1, hour);
  287.        Write_Cmd(0x80 + 0x40 + 5);
  288.        break;
  289.                                                 case 2:
  290.        minu++;
  291.        if(minu == 60)
  292.        minu = 0;
  293.        Write_Num(7, 1, minu);
  294.        Write_Cmd(0x80 + 0x40 + 8);
  295.        break;
  296.                                                 case 3:
  297.        sec++;
  298.        if(sec == 60)
  299.        sec = 0;
  300.        Write_Num(10, 1, sec);
  301.        Write_Cmd(0x80 + 0x40 + 11);
  302.        break;
  303.                                                 case 4:
  304.        month++;
  305.        if(month == 13)
  306.        month = 1;
  307.        Write_Num(6, 0, month);
  308.        Write_Cmd(0x80 + 7);
  309.        break;
  310.                                                 case 5:
  311.        day++;
  312.        if(day == 32)
  313.        day = 1;
  314.        Write_Num(9, 0, day);
  315.        Write_Cmd(0x80 + 10);
  316.        break;
  317.                                         }
  318.                                 }
  319.                         }
  320.                 }
  321. }
  322. void desp_led()
  323. {
  324.         if(k==0)
  325.                 {
  326.                         delay(50);
  327.
  328.                         if(k==0)
  329.                         {
  330.                                 a++;
  331.                                 if(a==2)
  332.                                 a=0;
  333.                         }
  334.                 }
  335.                 if(a==0)
  336.                         {
  337.                                 led=0;
  338.                         }
  339.                 if(a==1)
  340.                         {
  341.                                 led=1;
  342.                         }
  343.                         while(!k);
  344.
  345. }
  346. /***************** 主函数******************/
  347. /***************** 主函数******************/
  348. void main()
  349. {
  350.         uchar i = 0;
  351.         uchar code table[] = {"2020-01-01 Wed"};
  352.         EA = 1;
  353.         Lcd_Init();                        //1602初始化
  354.         InitTimer0();         //定时器0初始化
  355.         UsartConfiguration();        //调用蓝牙接受的参数
  356.         P1M0=0XFF;
  357.         P1M1=0X00;
  358.         Write_Cmd(0x80 + 1);
  359.         while(table[i] != '\0')
  360.         {
  361.                                         Write_Dat(table[i]);
  362.                                         i++;
  363.         }
  364.
  365.         while(1)
  366.         {
  367.                 desp_led();
  368.                 KeyScan();
  369.                 SBUF=num;//蓝牙
  370.                 if(num == 'm')                //灭
  371.                 {
  372.                                 led=0;
  373.                                 a=0;
  374.                 }
  375.                 if(num == 'l')                //亮
  376.                 {
  377.                                 led=1;
  378.                                 a=1;
  379.                 }
  380.                 if(num == 'b')                //半亮
  381.                 {
  382.                                 led=1;
  383.                                 delay(50); //设置为75%亮度
  384.                                 led=0;
  385.                 }
  386.         }
  387. }
  388. /***************** 主函数******************/
  389. /***************** 主函数******************/
  390. 具体源文件查看压缩包,该作品移植性能好
1602电子时钟加按键灯.rar
35.32 KB, 下载次数: 10, 下载积分: 黑币 -5
