查看: 4994|回复: 5
设计的51数字时钟不走数,求大神解答,学生党
ID:362198 发表于 2018-6-30 11:54 | 显示全部楼层 |阅读模式
老师布置的作业,整了一天没弄明白,是不是缺少刷新啊?
#include<reg51.h>
sbit key1=P2^0;
sbit key2=P2^1;
sbit key3=P2^2;
uchar num=0,temp=0,count=0;
uchar aa;
uchar hour,min,sec;
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xbf};
void delay(uint z);
void display(uchar a,uchar b,uchar ab,uchar c,uchar d,uchar cd,uchar e,uchar f,uchar aa);
void read_key();
void time_change();
/***************主函数***************/
P2=0xff,
hour=00;
min=0;
sec=0;
TMOD=0x1l;
TH0=(65536-50000)/256;
TL0=(65536-50000)%256;
TH1=(65536-50000)/256;
TL1=(65536-50000)%256;
EA=1;
ET0=1;
ET1=1;
TR0=1;
TR1=1;
aa=0xff;
                display(table[hour/10],table[hour%10],table[10],table[min/10],
                   table[min%10],table[10],table[sec/10],table[sec%10],0Xff);
                                                              time_change();
/****************显示函数*****************/
    if(num==1){P1=0x01 &aa;P0=a;delay(2);}else{P1=0x01;P0=a;delay(2);}    //hour
    if(num==1){P1=0x02&aa;P0=b;delay(2);}else{P1=0x02;P0=b;delay(2);}    //hour
P1=0x04;P0=ab;delay(2);
    if(num==2){P1=0x08&aa;P0=c;delay(2);}else{P1=0x08;P0=c;delay(2);}     //min
    if(num==2){P1=0x10&aa;P0=d;delay(2);}else{P1=0x10;P0=d;delay(2);}     //min
P1=0x20;P0=cd;delay(2);
    if(num==3){P1=0x40&aa;P0=e;delay(2);}else{P1=0x40;P0=e;delay(2);}     //sec
    if(num==3){P1=0x80&aa;P0=f;delay(2);}else{P1=0x80;P0=f;delay(2);}     //sec
/************定时器0中断函数************/
void timer0() interrupt 1
temp++;
/**************定时器1中断函数************/
void timer1() interrupt 3
count++;
if(count>=20)
count=0;
/**************延时子函数***************/
void delay(uint z)
     uint j,k;
    for(j=z;j>0;j--)
    for(k=120;k>0;k--);
/***************读按键函数***************/
void read_key()
if(key1=0)
delay(100);
if(key1==0)
    delay(100);
    num++;
    if(num>3){num=0;}
if(key1==0)
delay(10);
if(key1=0)
num++;
if(num>3){num=0;break;}
while(!key1);
delay(10);
while(!key1);
if(key2==0)
delay(100);
if(key2==0)
    if(num==1){hour++;if(hour==24)hour=0;}
    if(num==2){min++;if( min==60)min=0;}
    if(num==3){sec++;if(sec==60)sec=0;}
           while(!key1);
           delay(100);
           while(!key1);
if(key3==0)
delay(100);
if(key3==0)
if(num==1){hour--;if(hour==0)hour=23;}
if(num==2){min--;if(min==0)min=59;}
if(num==3){sec--;if(sec==0)sec=59;}
      while(!key1);
      delay(10);
      while(!key1);
    if(count<=15)
table[min%10],table[10],table[sec/10],table[sec%10],0xff);
    if(count>15)
table[min%10],table[10],table[sec/10],table[sec%10],0x00);
while(!key1);
delay(10);
while(!key1);
/*************时间调整函数**************/
void time_change()
read_key0();
if(temp>=20)
temp=0;
sec++;
if(sec>=60)
sec=0;
min++;
if(min>=60)
    min=0;
    hour++;
    if(hour>=24)
hour=0;
新建文件夹.zip
18.95 KB, 下载次数: 23
ID:362198 发表于 2018-6-30 11:56 | 显示全部楼层
求大神帮忙看一下,谢谢啦
ID:111634 发表于 2018-6-30 16:25 | 显示全部楼层
给你介绍一个正确有效看得懂的案例,自己对照查错吧!电路虽不同,但思路可参考。
实例94  模拟电子钟(由80C51定时器产生秒时基)
Proteus仿真一下,确认有效。 实例94 模拟电子钟(由80C51定时器产生秒时基).rar (43.05 KB, 下载次数: 51) 模拟电子钟.jpg
以上摘自张志良编著《80C51单片机仿真设计实例教程——基于Keil CProteus》清华大学出版社ISBN 978-7-302-41682-1内有常用的单片机应用100案例,用于仿真实验操作,电路与程序真实可靠可信可行。书中电路和程序设计有详细说明,程序语句条条有注解。
参与人数 1黑币 +5 收起 理由
mengsiu + 5 很给力!
ID:140371 发表于 2018-6-30 23:02 | 显示全部楼层
第94列   if(key1=0)  ,第107列 if(key1=0) 應該是 if(key1==0) 才對.....請你更改後測試一下
ID:362198 发表于 2018-12-27 17:28 | 显示全部楼层
谢谢,已经很久没来黑论坛了
ID:21069 发表于 2018-12-27 21:21 | 显示全部楼层
不是程式有错,你数码管与单片机没连上,74HC373也没连数码管,总体来说就是线没连上。应该是你还不放好网络标号,参考连接图连下去,刷机时暗快一些试试
参与人数 3黑币 +64 收起 理由
shuisheng60 + 14
刀刀见红 + 15 绝世好帖!
shuisheng + 35 回帖助人的奖励!
