查看: 1834|回复: 1
单片机模数转换的Proteus图和源代码
这是我基于C语言写的模数转换代码,其中包含硬件的Proteus图和源代码。
  1. #include <reg51.h>
  3. #define uint unsigned int
  4. sbit ST=P2^6;
  5. sbit OE=P2^1;
  6. sbit EOC=P2^0;
  7. sbit TP=P2^7;
  8. uchar data led[4];
  9. uint data date;
  10. int q=0;
  11. int w;
  12. uchar code weixuan[]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  13. uchar code a[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  14. uchar code b[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd};
  15.
  16.   void delay(unsigned int n)
  17.   {
  18.
  19.     unsigned int i=0,j=0;
  20.     for(i=0;i<n;i++)
  21.         for(j=0;j<123;j++);
  22.   }
  23. void display()
  24. {
  25.    uchar k,i;
  26.     q++;
  27.         q=q%2;
  28.
  29.           led[0]=(date*100/51)%10;
  30.    led[1]=(date*100/51)/10%10;
  31.    led[2]=(date*100/51)/100%10;
  32.         if(q==0)  {
  33.
  34.    for(k=0;k<3;k++)
  35.    {
  36.       P3=weixuan[k];
  37.   i=led[k];
  38.
  39.   if(k==2)
  40.   P1=b[i];
  41.   else
  42.   P1=a[i];
  43.   delay(1);
  44.
  45.    }
  46. }
  47. if(q==1)
  48. {
  49.
  50. for(k=0;k<3;k++)
  51.    {
  52.       P3=weixuan[k+5];
  53.   i=led[k];
  54.
  55.   if(k==2)
  56.   P1=b[i];
  57.   else
  58.   P1=a[i];
  59.   delay(1);
  60. }
  61.   }
  62.         }
  63. void main()
  64. {
  65.    TP=0;
  66.    while(1)
  67.    {
  68.       TP=~TP;
  69.       ST=1;
  70.   ST=0;
  71.   while(EOC==0);
  72.   OE=1;
  73.   date=P0;
  74.   OE=0;
  75.    delay(10);
  76.   display();
  77.
  78.    }
  79. }
5.2模数转换.rar (99.05 KB, 下载次数: 24)
ID:513368 发表于 2019-4-16 11:19 | 只看该作者
请问这个运行结果是什么?
