查看: 1435|回复: 1
STM32 KEY 4*4按键扫描源程序
ID:562020 发表于 2019-11-26 16:11 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
原理很简单 慢慢看 就看懂了
  1. #include "key.h"
  2. #include "delay.h"
  3. typedef struct
  4. {
  5.         GPIO_TypeDef* GPIOX;
  6.         uint16_t GPIO_Pin;
  7. }KGPT[2][4];
  8. KGPT KPIN={ {{GPIOG,GPIO_Pin_11},{GPIOG,GPIO_Pin_9}, {GPIOD,GPIO_Pin_6},{GPIOD,GPIO_Pin_4}} ,//row 横行
  9.                                                 {{GPIOD,GPIO_Pin_2}, {GPIOD,GPIO_Pin_0},{GPIOC,GPIO_Pin_11},{GPIOA,GPIO_Pin_15}}
  10.           }; //col 竖行
  11. #define RCC_APB2_GPIOX  RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_GPIOD|RCC_APB2Periph_GPIOG//IO时钟
  12. #define MAX_Time   36000000 // 松手检测最大延时
  13. //按键初始化函数
  14. void KEY_Init(void)
  15. {
  16.   u8 i;
  17.         GPIO_InitTypeDef GPIO_InitStructure;
  18.   RCC_APB2PeriphClockCmd(RCC_APB2_GPIOX,ENABLE);//使能PORTC时钟
  19.   for(i=0;i<4;i++)
  20.         {
  21.          GPIO_InitStructure.GPIO_Pin = KPIN[0][i].GPIO_Pin;
  22.          GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP; //设置成推挽输出
  23.          GPIO_Init(KPIN[0][i].GPIOX, &GPIO_InitStructure);//初始化row
  24.          GPIO_ResetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin);
  25.         }
  26. for(i=0;i<4;i++)
  27.         {
  28.                  GPIO_InitStructure.GPIO_Pin  = KPIN[1][i].GPIO_Pin;
  29.                  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU; //设置成S拉输入
  30.                  GPIO_Init(KPIN[1][i].GPIOX, &GPIO_InitStructure);//初始化col
  31.         }
  32. }
  33. u8 ReScan(GPIO_TypeDef* GPIOX,uint16_t colPin,u8 colIndex)
  34. {
  35. u8 i;
  36. delay_ms(10);//消抖延时
  37. for(i = 0;i<4;i++){
  38.   GPIO_SetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin);//每个行置1
  39.   if((GPIO_ReadInputDataBit(GPIOX, colPin) == 1)) //如果列也变了 行的值就知道了 为 i
  40.                 {
  41.                         GPIO_ResetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin); //行恢复 置0
  42.                   return colIndex+i*4+1;//返回的数据 为1-16 对应4x4键盘的16个键
  43.                 }
  44.         GPIO_ResetBits(KPIN[0][i].GPIOX,KPIN[0][i].GPIO_Pin);     //行恢复 置0
  45. }
  46. return 0;
  47. }
  48. u8 KEY_Scan(void)
  49. {
  50. u8 i,keyvalue;
  51.         //u32 j=0;
  52.         for(i = 0;i<4;i++)
  53.         {
  54.          if(GPIO_ReadInputDataBit(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin) == 0)//检测列 列值为 i
  55.          {
  56.                         keyvalue = ReScan(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin,i);//检测行 取键值
  57.                   while(GPIO_ReadInputDataBit(KPIN[1][i].GPIOX,KPIN[1][i].GPIO_Pin) == 0);
  58.                 //        while((GPIO_ReadInputDataBit(KPIN[col][i].GPIOX,KPIN[col][i].GPIO_Pin) == 0)&&(j<MAX_Time))j++;//松手检测
  59.                         return keyvalue;//返回键值
  60.                 }
  61.         }
  62. return 0;
  63. }
KEY按键扫描.rar (1.33 KB, 下载次数: 21)
ID:1 发表于 2019-11-26 19:49 | 只看该作者
