查看: 2293|回复: 0
电子发声程序 8086播放两只老虎Proteus仿真图
ID:1023213 发表于 2022-5-2 12:10 | 显示全部楼层 |阅读模式
BUTTON        EQU 0280H
GATE1        EQU 0290H
TCONTR0 EQU 02A6H
TCON0        EQU 02A0H
TCON1        EQU 02A2H
TCON2        EQU 02A4H
DATA        SEGMENT
                F_LIST  DW 441,495,556,441,441,495,556,441
                                DW 556,589,661,556,589,661
                                DW 661,742,661,589,556,441
                                DW 441,330,441,441,330,441
                                DW 523,523,784,784,880,880,784
                                DW 698,698,659,659,587,587,523
                                DW 784,784,698,698,659,659,587
                                DW 698,698,659,659,587,587,523,0
                T_LIST  DW 2,2,2,2,2,2,2,2
                                DW 2,2,4,2,2,4
                                DW 1,1,1,1,2,2
                                DW 2,2,4,2,2,4
                                DW 2,2,2,2,2,2,2
                                DW 1,1,1,1,1,1,1
                                DW 1,1,1,1,1,1,1
                                DW 2,2,2,2,2,2,2
                                DW 2,2,2,2,2,2,2
                                DW 2,2,2,2,2,2,2
                CLK            DW 34DDH,12H
DATA        ENDS
CODE        SEGMENT
                ASSUME CS:CODE,DS:DATA
START:        MOV AX,DATA
                MOV DS,AX
                MOV AL,76H
                MOV        DX,TCONTR0
                OUT DX,AL
SCANBUTTON:
                MOV DX,BUTTON
                IN  AL,DX
                AND AL,01H
                JZ        SCANBUTTON
                MOV AL,01
                MOV DX,GATE1
                OUT DX,AL
REPEAT1:MOV SI,OFFSET F_LIST
                MOV DI,OFFSET T_LIST
AGAIN:        MOV BX,[SI]
                MOV AX,CLK
                MOV DX,CLK+2
                DIV BX
                MOV DX,TCON1
                OUT DX,AL
                MOV AL,AH
                OUT DX,AL
                MOV CX,[DI]
LP1:        CALL DELAY
                LOOP LP1
                ADD        SI,2
                ADD        DI,2
                CMP WORD PTR [SI],0
                JZ         REPEAT1
                MOV DX,BUTTON
                IN        AL,DX
                AND AL,01H
                JZ        EXIT
                JMP AGAIN
EXIT:        MOV AL,00H
                MOV DX,GATE1
                OUT DX,AL
                JMP SCANBUTTON
DELAY         PROC
                PUSH BX
                PUSH CX
                MOV  BX,40
L1:                MOV  CX,2801
L2:                LOOP L2
                DEC  BX
                JNZ  L1
                POP  CX
                POP  BX
                RET
DELAY   ENDP
CODE    ENDS
                END  START
仿真程序下载(注意有些电脑可能会仿真无效果): 12 电子发声器设计.rar (80.99 KB, 下载次数: 32)
