查看: 1932|回复: 3
关于单片机矩阵键盘改写C语言数组存储LCD显示的问题
想在LCD上通过矩阵键盘给数组重新赋值不知道为什么LCD显示全是空格,大佬求解。
  1. #include <reg52.h>
  2. #define uint unsigned int
  4.
  5. uchar code table1[]="Hello, World!    ";
  6. uchar code table2[]="What should to do";
  7. uchar code table3[]="21120115      ";
  8. uchar code table4[]="51102112         ";
  9.       uchar cache[]="             ";
  10. uchar var,K_count;
  11. sbit RS=P2^0;
  12. sbit EN=P2^2;
  13. sbit RW=P2^1;
  14. void delay(uint sc);
  15. void intion();
  16. void Write_con(uchar con);
  17. void Write_dat(uchar dat);
  18. void Dis_Lcd(uchar str[],uchar str1[]);
  19. void Key_scanf();
  20. void main()
  21. {
  22.         intion();
  23.         while(1)
  24.         {
  25.                 uchar i;
  26.                 Key_scanf();
  27.                 Write_con(0x80);
  28.                 for(i=0;i<16;i++)
  29.                 {
  30.                         Write_dat(cache[i]);
  31.                         delay(3);
  32.                 }
  33.         }
  34. }
  35. void delay(uint sc)
  36. {
  37.         uint i,j;
  38.         for(i=sc;i>0;i--)
  39.                 for(j=110;j>0;j--)
  40.                 {
  41.                         ;
  42.                 }
  43. }
  44. void intion()
  45. {
  46.         EN=0;
  47.         RW=0;
  48.         Write_con(0x38);
  49.         Write_con(0x0c);
  50.         Write_con(0x06);
  51.         Write_con(0x01);
  52.         Dis_Lcd(table1,table2);
  53. }
  54. void Write_con(uchar con)
  55. {
  56.         EN=0;
  57.         RS=0;
  58.         P0=con;
  59.         delay(5);
  60.         EN=1;
  61.         delay(5);
  62.         EN=0;
  63. }
  64. void Write_dat(uchar dat)
  65. {
  66.         EN=0;
  67.         RS=1;
  68.         P0=dat;
  69.         delay(5);
  70.         EN=1;
  71.         delay(5);
  72.         EN=0;
  73. }
  74. void Dis_Lcd(uchar str[],uchar str1[])
  75. {
  76.         uint i;
  77.         Write_con(0x80);
  78.         for(i=0;i<16;i++)
  79.         {
  80.                 Write_dat(str[i]);
  81.                 delay(5);
  82.         }
  83.         Write_con(0x80+0x40);
  84.         for(i=0;i<16;i++)
  85.         {
  86.                 Write_dat(str1[i]);
  87.                 delay(5);
  88.         }
  89. }
  90. void Key_scanf()
  91. {
  92.         uchar temp;
  93.         P3=0x0f;/*截取高四位IO端口数据,即列判断*/
  94.         temp=P3&0x0f;
  95.         if(temp!=0x0f)
  96.         {
  97.                         delay(10);
  98.                         K_count++;
  99.                         switch(temp)
  100.                         {
  101.                                 case 0x0e:var=0*4;break;
  102.                                 case 0x0d:var=1*4;break;
  103.                                 case 0x0b:var=2*4;break;
  104.                                 case 0x07:var=3*4;break;
  105.                         }
  106.
  107.                 P3=0xf0;/*行列电位翻转 */
  108.                 temp=P3&0xf0;
  109.                 if(temp!=0xf0)
  110.                 {
  111.                         switch(temp)
  112.                         {
  113.                                 case 0xe0:var+=0;break;
  114.                                 case 0xd0:var+=1;break;
  115.                                 case 0xb0:var+=2;break;
  116.                                 case 0x70:var+=3;break;
  117.                         }
  118.                 }
  119.                 switch(K_count)
  120.                 {
  121.                         case 1:cache[0]=var;break;
  122.                         case 2:cache[1]=var;break;
  123.                         case 3:cache[2]=var;break;
  124.                         case 4:cache[3]=var;break;
  125.                         case 5:cache[4]=var;break;
  126.                         case 6:cache[5]=var;break;
  127.                         case 7:cache[6]=var;break;
  128.                         case 8:cache[7]=var;break;
  129.                 }
  130.                 while(P3!=0xf0)
  131.                 {
  132.                         ;
  133.                 }
  134.         }
  135. }
ID:384109 发表于 2022-11-12 22:11 | 只看该作者
K_count没有赋初值,也没判断是否超出数组
ID:123289 发表于 2022-11-14 15:56 | 只看该作者
这个问题简单,
自己走单步调试一下。
ID:161164 发表于 2022-11-14 17:58 | 只看该作者
