查看: 2703|回复: 2
51单片机驱动中文字库12864液晶显示
//c51驱动中文字库12864液晶显示
#include <stdio.h>
#include <reg52.h>
#include <intrins.h>
#include <string.h>
uchar code LCD_data1[];
uchar code LCD_data2[];
uchar code LCD_picture1[];
uchar code LCD_picture2[];
/*sbit RS = P3^0; //2051
sbit RW = P3^1;
sbit EN = P3^2;
sbit PSB = P3^3;
sbit RES = P3^4;       */
/*sbit RS = P2^4;
sbit RW = P2^5;
sbit EN = P2^6;
sbit PSB = P2^1;
sbit RES = P2^3;
sbit Dataport = P0;//l-1定义数据端口
sbit Busyport = P0^7;
void delay_ms(unsigned int n)   //延时10*N毫秒
unsigned int i,j;
for(i=0;i<n;i++)
for(j=0;j<2000;j++);
void delay(unsigned int m)        //延时1u秒
unsigned int i,j;
for(i=0;i<m;i++)
for(j=0;j<10;j++);
void check_LCD_busy (void) //判断LCM忙子程序
Dataport = 0xff;
RS = 0;
RW = 1;
EN = 1;
while (Busyport);
EN = 0;
void write_com(uchar Command) //写命令子程序
check_LCD_busy();
RW=0;
RS=0;
delay(1);
P0=Command;
EN=1;
delay(1);
EN=0;
void write_data(uchar Data)  //写数据子程序
check_LCD_busy();
RW=0;
RS=1;
delay(1);
P0=Data;
EN=1;
delay(1);
EN=0;
void lcdClear (void) //LCM清屏子函数
write_com(0x01);
void reset () //LCm复位子函数
RES=0;// 复位
delay(1);
RES=1;//复位置高
delay(10);
void dispString (uchar X, Y,uchar*msg)  //显示汉字,X为哪一行,y为哪一列 ,msg为汉字
if(X==0) X = 0x80; //第一行,汉字显示坐标
else if(X==1) X = 0x90; // 第2行,汉字显示坐标
else if(X==2) X = 0x88;  //第3行
else X = 0x98;                           //第4行
//Y = X + Y;          //去掉+Y,显示从第一格开始
Y = X ;                            //y为一往右边移动 一位
write_com(Y);                    //写入坐标
while (*msg)               //
write_data(*msg++);//显示汉字
void disppicture(uchar code*adder)  //显示图像
uint i,j;
for(i=0;i<32;i++) //上半屏32个列地址
write_com(0x80 + i);   //set垂直地址VERTICALADD
write_com(0x80);      //set水平地址HORIZONTALADD
for(j=0;j<16;j++)
write_data(*adder);
adder++;
for(i=0;i<32;i++)//显示下半屏内容设置
write_com(0x88);    //set水平地址HORIZONTALADD
for(j=0;j<16;j++)
write_data(*adder);
adder++;
void lcdinit_str(void)//lcd字库初始化程序
delay(40);             //大于40MS延时
PSB=1;                        //设置为8BIT并口工作模式
delay(1);
reset();                  //复位
write_com(0x30);
delay(100);
write_com(0x30);
delay(37);
write_com(0x08);
delay(100);
write_com(0x10);
delay(100);
write_com(0x0C);
delay(100);
write_com(0x01);
delay(10);
write_com(0x06);  // 光标从右向左加1    位移动
delay(100);
void lcdinit_pic(void)//lcd图片(扩展 )初始化函数
delay(40);
PSB=1;//设置为8BIT并口工作模式
delay(1);
reset();
write_com(0x36);
delay(100);
write_com(0x36);
delay(37);
write_com(0x3E);
delay(100);
write_com(0x01);
delay(100);
lcdinit_str();
delay_ms(10);
dispString(0, 1,"钟山风雨起苍黄,");
delay_ms(10);
dispString(1, 1,"百万雄师过大江。");
delay_ms(10);
dispString(2, 1,"虎踞龙盘今胜昔,");
delay_ms(10);
dispString(3, 1,"天翻地覆慨而慷");
delay_ms(200);
delay_ms(200);
lcdClear();
delay_ms(10);
dispString(0, 1,"宜将剩勇追穷寇,");
delay_ms(10);
dispString(1, 1,"不可沽名学霸王。");
delay_ms(10);
dispString(2, 1,"天若有情天亦老,");
delay_ms(10);
dispString(3, 1,"人间正道是沧桑。");
delay_ms(200);
delay_ms(200);
delay_ms(10);
dispString(1, 1,"万水千山只等闲。");
delay_ms(10);
dispString(2, 1,"五岭逶迤腾细浪,");
delay_ms(10);
dispString(3, 1,"乌蒙磅礴走泥丸。");
delay_ms(200);
delay_ms(200);
delay_ms(10);
dispString(0, 1,"金沙水拍云崖暖,");
delay_ms(10);
dispString(1, 1,"大渡桥横铁索寒。");
delay_ms(10);
dispString(2, 1,"更喜民山千里雪,");
delay_ms(10);
dispString(3, 1,"三军过后尽开颜。");
delay_ms(200);
delay_ms(200);
lcdinit_pic();
lcdClear();
delay_ms(10);
disppicture(LCD_picture1);
delay_ms(300);
delay_ms(300);
这里发一个51单片机驱动中文字库12864液晶显示代码,大家一起学习。中文字库12864液晶用起来比较简单。
收藏收藏2 分享淘帖 顶顶 踩踩
ID:1064915 发表于 2024-1-10 10:32 | 只看该作者
这是带字库的
ID:291549 发表于 2024-1-13 18:52 | 只看该作者
这个特别实用。
