查看: 1925|回复: 11
有没有大佬看一下,这个单片机代码出了什么问题,lcd板亮但是不显示温度
#include <reg52.h>
sbit DQ = P2^0;
sbit RS = P2^1;
sbit RW = P2^2;
sbit E = P2^3;
sbit K1 = P2^4;
sbit K2 = P2^5;
sbit Buzzer = P2^6;
unsigned int highTemp = 30;
unsigned int lowTemp = 20;
unsigned int currentTemp = 0;
void delay(unsigned int ms) {
    unsigned int i, j;
    for (i = ms; i > 0; i--)
        for (j = 110; j > 0; j--);
bit Init_DS18B20() {
    bit presence;
    DQ = 1;
    delay(1);
    DQ = 0;
    delay(75);
    DQ = 1;
    delay(4);
    presence = DQ;
    delay(20);
    return presence;
void Write_DS18B20(unsigned char dat) {
    unsigned char i;
    for (i = 0; i < 8; i++) {
        DQ = 0;
        _nop_();
        DQ = dat & 0x01;
        delay(5);
        DQ = 1;
        dat >>= 1;
unsigned char Read_DS18B20() {
    unsigned char i, dat;
        DQ = 0;
        _nop_();
        DQ = 1;
        _nop_();
        dat >>= 1;
        if (DQ)
            dat |= 0x80;
        delay(5);
    return dat;
unsigned char ReadTemperature() {
    unsigned char temp_h, temp_l;
    Init_DS18B20();
    Write_DS18B20(0xCC);
    Write_DS18B20(0xBE);
    temp_l = Read_DS18B20();
    temp_h = Read_DS18B20();
    currentTemp = temp_h;
    return temp_l;
void LCD_Init() {
    delay(15);
    Write_Command(0x38);
    Write_Command(0x0C);
    Write_Command(0x06);
    Write_Command(0x01);
void Write_Command(unsigned char com) {
    RS = 0;
    RW = 0;
    E = 1;
    P0 = com;
    delay(1);
    E = 0;
void Write_Data(unsigned char dat) {
    RS = 1;
    RW = 0;
    E = 1;
    P0 = dat;
    delay(1);
    E = 0;
void Display_Temperature(unsigned char temp) {
    unsigned char temp_str[5];
    temp_str[0] = temp / 10 + '0';
    temp_str[1] = temp % 10 + '0';
    temp_str[2] = '.';
    temp_str[3] = ReadTemperature() / 10 + '0';
    temp_str[4] = ReadTemperature() % 10 + '0';
    Write_Command(0x80);
    Write_String("Temp: ");
    Write_Command(0x86);
    Write_String(temp_str);
    Write_Command(0xC0);
    Write_String("High: ");
    Write_Command(0xC6);
    Write_Char(highTemp / 10 + '0');
    Write_Char(highTemp % 10 + '0');
    Write_Command(0xCB);
    Write_String("Low: ");
    Write_Command(0xCF);
    Write_Char(lowTemp / 10 + '0');
    Write_Char(lowTemp % 10 + '0');
void Write_String(unsigned char *str) {
    while (*str != '\0') {
        Write_Data(*str);
        str++;
void Write_Char(unsigned char dat) {
    Write_Data(dat);
void Alarm() {
    Buzzer = 0;
    delay(500);
    Buzzer = 1;
    delay(500);
void Key_Scan() {
    if (K1 == 0) {
        delay(5);
        if (K1 == 0) {
            highTemp++;
            while (!K1);
    if (K2 == 0) {
        delay(5);
        if (K2 == 0) {
            lowTemp--;
            while (!K2);
void main() {
    LCD_Init();
    while (1) {
        ReadTemperature();
        Display_Temperature(currentTemp);
        if (currentTemp > highTemp || currentTemp < lowTemp) {
            Alarm();
        Key_Scan();
屏幕截图 2024-10-10 143311.png (52.86 KB, 下载次数: 1)
ID:844772 发表于 2024-10-10 16:29 | 只看该作者
线接错了,还有些漏接的,程序是粘贴的吧。
ID:59202 发表于 2024-10-10 16:46 | 只看该作者
LCD亮但是不显示温度是显示字符正确只是温度值没显示出来吗
ID:619259 发表于 2024-10-10 18:43 | 只看该作者
sbit RS = P2^1;
sbit RW = P2^2;
sbit E = P2^3;
以上三行有误,电路中LCD三个控制端口用的是P1口,不是P2口
ID:611988 发表于 2024-10-10 19:12 | 只看该作者
屏管脚检查过了吗?
ID:1133322 发表于 2024-10-11 14:31 | 只看该作者
是粘贴的
啥也没有显示,只是亮屏
ID:1133322 发表于 2024-10-11 14:32 | 只看该作者
cy009 发表于 2024-10-10 18:43
sbit RS = P2^1;
sbit RW = P2^2;
sbit E = P2^3;
好的,谢谢
ID:1133322 发表于 2024-10-11 14:34 | 只看该作者
好技术致用 发表于 2024-10-10 19:12
屏管脚检查过了吗?
只是在Proteus模拟,还没有弄硬件
ID:1133323 发表于 2024-10-11 15:31 | 只看该作者
代码错了
ID:844772 发表于 2024-10-11 15:58 | 只看该作者
那不用改程序,按程序接线,你接错4根,另外,lcd漏接的三条线接好
ID:1133322 发表于 2024-10-14 21:10 | 只看该作者
好的,谢谢
