查看: 2713|回复: 1
求大神帮我改一下程序,我想实现的功能是启动/停止、调速和点动控制角度
ID:76295 发表于 2015-4-6 23:02 | 只看该作者 回帖奖励 |正序浏览 |阅读模式
  #include <reg51.h>       //51芯片管脚定义头文件
#include <intrins.h>  //内部包含延时函数 _nop_();
#define uint  unsigned int
#define delayNOP(); {_nop_();_nop_();_nop_();_nop_();};
uchar code FFW[8]={0xf1,0xf3,0xf2,0xf6,0xf4,0xfc,0xf8,0xf9};
uchar code REV[8]={0xf9,0xf8,0xfc,0xf4,0xf6,0xf2,0xf3,0xf1};
sbit  K1   = P3^0;       //运行与停止
sbit  K2   = P3^1;       //设定圈数
sbit  K3   = P3^2;       //方向转换
sbit  K4   = P3^3;       //速率调整
sbit  K5   = P3^4;                 //点动
sbit  BEEP = P3^5;       //蜂鸣器
sbit  LCD_RS = P2^0;
sbit  LCD_RW = P2^1;
sbit  LCD_EN = P2^2;
bit  on_off=0;            //运行与停止标志
bit  direction=1;         //方向标志
bit  rate_dr=1;           //速率标志
bit  snum_dr=1;           //圈数标志
uchar code  cdis1[ ] = {" 201133595140 "};
uchar code  cdis2[ ] = {"STEPPING MOTOR"};
uchar code  cdis3[ ] = {"    STOP        "};
uchar code  cdis4[ ] = {"NUM:    RATE:   "};
uchar code  cdis5[ ] = {"  RUNNING       "};
uchar code  cdis6[] = {"ONE STEP"};
uchar  v=0,q=0;
uchar m;
uchar zs;
uchar angle;
uint   number=0,number1=0;
uchar   snum=10,snum1=10;       //预设定圈数
uchar   rate=3;               //预设定速率
uchar   data_temp,data_temP1,data_temp2 ,data_temp3, data_temp4 ;
/* 延时t毫秒
/* 11.0592MHz时钟,延时约1ms
void delay(uint t)
   uchar k;
   while(t--)
     for(k=0; k<125; k++)
void delayB(uchar x)    //x*0.14MS
   uchar i;
   while(x--)
     for (i=0; i<13; i++)
void beep()
   uchar j;
   for (j=0;j<100;j++)
     delayB(4);
     BEEP=!BEEP;                 //BEEP取反
     BEEP=1;                    //关闭蜂鸣器
  delay(170);
/*检查LCD忙状态
/*lcd_busy为1时,忙,等待。为0时,闲,可写指令与数据。
bit lcd_busy()
    bit result;
    LCD_RS = 0;
    LCD_RW = 1;
    LCD_EN = 1;
    delayNOP();
    result = (bit)(P0&0x80);
    LCD_EN = 0;
    return(result);
/*写指令数据到LCD
/*RS=L,RW=L,E=高脉冲,D0-D7=指令码。
void lcd_wcmd(uchar cmd)
   while(lcd_busy());
    LCD_RS = 0;
    LCD_RW = 0;
    LCD_EN = 0;
    _nop_();
    _nop_();
    P0 = cmd;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*写显示数据到LCD
/*RS=H,RW=L,E=高脉冲,D0-D7=数据。
void lcd_wdat(uchar dat)
   while(lcd_busy());
    LCD_RS = 1;
    LCD_RW = 0;
    LCD_EN = 0;
    P0 = dat;
    delayNOP();
    LCD_EN = 1;
    delayNOP();
    LCD_EN = 0;
/*  LCD初始化设定
void lcd_init()
    delay(30);
    lcd_wcmd(0x38);      //16*2显示,5*7点阵,8位数据
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x38);
    delay(5);
    lcd_wcmd(0x0c);      //显示开,关光标
    delay(5);
    lcd_wcmd(0x06);      //移动光标
    delay(5);
    lcd_wcmd(0x01);      //清除LCD的显示内容
    delay(5);
/*  设定显示位置
void lcd_pos(uchar pos)
  lcd_wcmd(pos | 0x80);  //数据指针=80+地址变量
/* LCD1602初始显示子程序
void  LCD_init_DIS()
     delay(10);                 //延时
     lcd_init();                //初始化LCD
     lcd_pos(0);                //设置显示位置为第一行的第1个字符
     m = 0;
     while(cdis1[m] != '\0')
      {                         //显示字符
        lcd_wdat(cdis1[m]);
        m++;
     lcd_pos(0x40);             //设置显示位置为第二行第1个字符
     m = 0;
     while(cdis2[m] != '\0')
        lcd_wdat(cdis2[m]);      //显示字符
        m++;
      delay(3000);               //延时
      m = 0;
      while(cdis3[m] != '\0')
        {                        //显示字符
          lcd_wdat(cdis3[m]);
          m++;
      m = 0;
     while(cdis4[m] != '\0')
          lcd_wdat(cdis4[m]);    //显示字符
          m++;
        for(m=0;m<2;m++)
       lcd_pos(0x0c+m);    //显示方向符号
             lcd_wdat(0x3e);
/*数据转换子程序
void  data_conv()
     data_temP1=data_temp/10;       //高位
  if(data_temP1==0)
  {data_temP1=0x20;}             //高位为0不显示
  {data_temP1=data_temP1+0x30;}
   data_temp2=data_temp%10;       //低位
     data_temp2=data_temp2+0x30;
/*数据转换子程序
void  data_conv1()
  if(data_temP1==0)
data_temp3=data_temp%10;
data_temp3=data_temp3+0x30;
data_temp4=data_temp%10;
data_temp4=data_temp4+0x30;
/********************************************************/   //单步
void data_angle()
uchar angle;
zs=1.8*angle;
data_temp=zs;
Data_conv1();
lcd_pos(0x45);
lcd_wdat(data_temP1);
lcd_pos(0x46);
lcd_wdat(data_temp2);
lcd_pos(0x47);
lcd_wdat(data_temp3);
lcd_pos(0x48);
lcd_wdat(data_temp4);
void motor_ffwdb()     //单步正转
v=v+1;
if(v==8)
v=0;
P1=FFW[v];
/*数据显示子程序
void  data_dis()
    data_temp = snum;        //显示圈数
    data_conv();
       lcd_pos(0x44);
       lcd_pos(0x45);
    data_temp = rate;         //显示速率
    data_conv();
       lcd_pos(0x4d);
       lcd_pos(0x4e);
/* 显示运行方向符号
void  motor_DR()
       if(direction==1)           //正转方向标志
        { for(m=0;m<2;m++)
            lcd_wdat(0x3e);
         { for(m=0;m<2;m++)       //反转方向标志
             lcd_wdat(0x3c);
/* 显示运行状态
void  motor_RUN()
      if(on_off==1)
    { TR0=1;
         m = 0;
         while(cdis5[m] != '\0')
          { lcd_wdat(cdis5[m]);      //RUNNING
            m++;   }
            motor_DR();              //
    { TR0=0; P1 =0x0f;
         m = 0;
          { lcd_wdat(cdis3[m]);      //STOP
            m++;   }
            motor_DR();              //
   snum=snum1;             //
   number1=0;              //清圈数计数器
*  主程序
main()
         LCD_init_DIS();
   TMOD = 0x01;       //T0定时方式1
   TL0  = 0x33;
   TH0  = 0xf5;
   EA   = 1;
   ET0  = 1;
    P1   = 0x0f;
  if( K5==0)
      {delay(5);
   if(K5==0)
  beep();
    motor_ffwdb();
delay(500);
lcd_wcmd(0x01);
lcd_pos(0x50) ;
    m = 0;
         while(cdis6[m] != '\0')
          { lcd_wdat(cdis6[m]);      //ONE  STEP
            m++;   }
     angle=angle+1;
     data_angle();
K5=1;        // K5 end
if(K1==0)
         beep();
      while(K1==0);       //等待键释放
      on_off=~on_off;
         motor_RUN();
        }   //K1 end
      if(K2==0)
      beep();
   if(snum_dr==1)
    { snum++;
        snum1=snum;
      if(snum==0x14)
            { snum_dr=~snum_dr;}
     {snum--;
   snum1=snum;
      if(snum==0x01)
   { snum_dr=~snum_dr; }
    } //K2  end
        if(K3==0)
      beep();
   direction=~direction;
         motor_DR();
      }//K3 end
        if(K4==0)
      beep();
   if(rate_dr==1)
    { rate++;
      if(rate==0x10)
            { rate_dr=~rate_dr;}
      rate--;
      if(rate==0x01)
   { rate_dr=~rate_dr; }
  } //K4 end
      if(number1==snum1)   //与设定圈数是否相等
     { number1=0;
         on_off=0;
         TR0=0;
        snum=snum1;
   P1=0x0f;
    motor_RUN();
         data_dis();
}  // while(1) end
          //main end
/*  定时器 0 中断
void  motor_onoff()  interrupt  1
       TL0  = 0x33;
       TH0  = 0xf5;
       q++;
    if(q < rate)
        { return; }
       {  q=0;
       number++;                  //脉冲计数
      if(number==4096)              //64个脉冲电机转一圈
       { snum--;
      number=0;
            number1++; }          //电机转动圈数
         if(direction==1)            //方向标志
       { if(v<8)
         {P1 = FFW[v];v++;}       //取数据,正转
        if(v==8)
        { v=0; }
       { if(v<8)
         {P1 = REV[v];v++;}       //取数据,反转
         if(v==8)
         { v=0; }
ID:75077 发表于 2015-4-6 23:42 来自触屏版 | 只看该作者
太长了。。。
