查看: 4183|回复: 0
1602字符液晶垂直水平滚动演示程序及仿真 带暂停继续按钮
ID:57821 发表于 2016-10-21 00:22 | 显示全部楼层 |阅读模式
分享一个1602字符液晶滚动演示程序下面是仿真图:带3个按钮 自动垂直滚动 自动水平滚动 和暂停继续按钮
  1. /***************   writer:shopping.w   ******************/
  2. #include <reg52.h>
  3. #include <string.h>
  5. #define uint unsigned int
  6. void Initialize_LCD();
  7. void ShowString(uchar,uchar,uchar *);
  8. sbit K1 = P3^0;
  9. sbit K2 = P3^1;
  10. sbit K3 = P3^2;
  11. uchar code Prompt[]="PRESS K1--K4 TO START DEMO PROG";
  12. uchar const Line_Count = 6;
  13. uchar code Msg[][80]=
  14. {
  15.          "Many CAD users dismiss",
  16.         "process of creating PCB",
  17.         "of view.with PCB layout",
  18.         "placement and track routing,",
  19.         "can often be the most time",
  20.         "And if you use circuit simulation",
  21.         "you are going to spend even more"
  22. };
  23. uchar Disp_Buffer[32];
  24. void Delayxms(uint ms)
  25. {
  26.          uchar i;
  27.         while(ms--)
  28.         {
  29.                  for(i=0;i<120;i++);
  30.         }
  31. }
  32. void V_Scroll_Display()
  33. {
  34.          uchar i,j,k = 0;
  35.         uchar *p = Msg[0];
  36.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  37.         while(p<q)
  38.         {
  39.                  for(i=0;(i<16)&&(p<q);i++)
  40.                 {
  41.                          if(((i==0)||(i==15))&& *p == ' ')
  42.                                 p++;
  43.                         if(*p != '\0')
  44.                         {
  45.                                  Disp_Buffer[i] = *p++;
  46.                         }
  47.                         else
  48.                         {
  49.                                  if(++k>Line_Count)
  50.                                         break;
  51.                                 p = Msg[k];
  52.                                 Disp_Buffer[i] = *p++;
  53.                         }
  54.                 }
  55.                 for(j=i;j<16;j++)
  56.                         Disp_Buffer[j]=' ';
  57.                 while(F0)
  58.                         Delayxms(5);
  59.                 ShowString(0,0,"      ");
  60.                 Delayxms(150);
  61.                 while(F0)
  62.                         Delayxms(5);
  63.                 ShowString(0,1,Disp_Buffer);
  64.                 Delayxms(150);
  65.                 while(F0)
  66.                         Delayxms(5);
  67.                 ShowString(0,0,Disp_Buffer);
  68.                 ShowString(0,1,"      ");
  69.                 Delayxms(150);
  70.         }
  71.         ShowString(0,0,"         ");
  72.         ShowString(0,1,"         ");
  73. }
  74. void H_Scroll_Display()
  75. {
  76.         uchar m,n,t = 0,L=0;
  77.         uchar *p = Msg[0];
  78.         uchar *q = Msg[Line_Count] + strlen(Msg[Line_Count]);
  79.         for(m=0;m<16;m++)
  80.                         Disp_Buffer[m]=' ';
  81.         while(p<q)
  82.         {
  83.                  if((m=16||m==31)&& *p == ' ')
  84.                         p++;
  85.                 for(m=16;m<32&&p<q;m++)
  86.                 {
  87.                          if(*p != '\0')
  88.                         {
  89.                                 Disp_Buffer[m] = *p++;
  90.                         }
  91.                         else
  92.                         {
  93.                                  if(++t>Line_Count)
  94.                                         break;
  95.                                 p = Msg[t];
  96.                                 Disp_Buffer[m] = *p++;
  97.                         }
  98.                 }
  99.                 for(n=m;n<32;n++)
  100.                         Disp_Buffer[n]=' ';
  101.                 for(m=0;m<=16;m++)
  102.                 {
  103.                          while(F0)
  104.                                  Delayxms(5);
  105.                            ShowString(0,L,Disp_Buffer+1);
  106.                            while(F0)
  107.                                  Delayxms(5);
  108.                         Delayxms(20);
  109.                 }
  110.                 L = (L==0)? 1:0;
  111.                 Delayxms(200);
  112.         }
  113.         if(L==1)
  114.                 ShowString(0,1,"      ");
  115. }
  116. void EX_INT0() interrupt 0
  117. {
  118.          F0 = !F0;
  119. }
  120. void main()
  121. {
  122.          uint Count = 0;
  123.         IE = 0x81;
  124.         IT0 = 1;
  125.         F0  = 0;
  126.         Initialize_LCD();
  127.         ShowString(0,0,Prompt);
  128.         ShowString(0,1,Prompt+16);
  129.         while(1)
  130.         {
  131.                  if(K1 == 0)
  132.                 {
  133.                          V_Scroll_Display();
  134.                         Delayxms(200);
  135.                 }
  136.                 else if(K2 == 0)
  137.                 {
  138.                          H_Scroll_Display();
  139.                         Delayxms(200);
  140.                 }
  141.         }
  142. }
12 1602字符液晶滚动演示程序.zip
87.07 KB, 下载次数: 30, 下载积分: 黑币 -5
