查看: 4051|回复: 1
8951连接74HC138后C语言编程控制8个发光二极管依次点亮,proteus绘制原理图
#include <reg51.h>
sbit HC138A = P1^0;                //定义译码器输入端A 在 P1.0 管脚上
sbit HC138B = P1^1;                //定义译码器输入端B 在 P1.1 管脚上
sbit HC138C = P1^2;                //定义译码器输入端C 在 P1.2 管脚上
void delay(unsigned int i)
  unsigned char j;
   for(i; i > 0; i--)
    for(j = 200; j > 0; j--);
HC138C = 0; HC138B = 0; HC138A = 0;   //输入 000   点亮第一个LED灯
delay(1500); //延时
HC138C = 0; HC138B = 0; HC138A = 1;   //输入 001   点亮第二个LED灯
delay(1500); //延时
HC138C = 0; HC138B = 1; HC138A = 0;   //输入 010   点亮第三个LED灯
delay(1500); //延时
HC138C = 0; HC138B = 1; HC138A = 1;   //输入 011   点亮第四个LED灯
delay(2000); //延时
HC138C = 1; HC138B = 0; HC138A = 0;   //输入 100   点亮第五个LED灯
delay(1500);  //延时
HC138C = 1; HC138B = 0; HC138A = 1;   //输入 101   点亮第六个LED灯
delay(1500);  //延时
HC138C = 1; HC138B = 1; HC138A = 0;   //输入 110   点亮第七个LED灯
delay(1500);  //延时
HC138C = 1; HC138B = 1; HC138A = 1;   //输入 111   点亮第八个LED灯
delay(1500);  //延时
proteus仿真原理图
proteus仿真原理图
收藏收藏2 分享淘帖 顶 踩
ID:754135 发表于 2020-5-19 11:11 | 只看该作者
能不能同时点亮所有灯呢
