查看: 10149|回复: 0
用keil软件C语言编写的能够在单片机上运行的简易计算器程序
ID:211500 发表于 2017-6-15 13:10 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
使用keil软件生成hex文件,烧录进单片机即可上电运行
下载:
简易计算器.doc (42.5 KB, 下载次数: 12)
源程序:
  1. #include<reg51.h>
  2. #include<intrins.h>
  4. #define uint  unsigned  int
  5. #define LED P0
  6. #define KEY P1
  7. sbit led1=P2^2;
  8. sbit led2=P2^3;
  9. sbit led3=P2^4;
  10. sbit Beep=P1^5;
  11. sbit SRCLK=P3^6;
  12. sbit RCLK=P3^5;
  13. sbit SER=P3^4;
  14. unsigned char code CHARCODE[6][8]={
  15. {0x00,0x00,0x08,0x08,0x3e,0x08,0x08,0x00},
  16. {0x00,0x00,0x08,0x08,0x08,0x08,0x08,0x00},
  17. {0x00,0x00,0x22,0x14,0x08,0x14,0x22,0x00},
  18. {0x00,0x00,0x08,0x08,0x2a,0x08,0x08,0x00},
  19. {0x00,0x00,0x14,0x14,0x14,0x14,0x14,0x00},
  20. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00},
  21. };
  22. uchar code TAB[8]={0x7f,0xbf,0xdf,0xef,0xf7,0xfb,0xfd,0xfe};
  23. uchar code shu[10]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f};
  24. void zhifu(uchar q);
  25. void yinyue(uchar m);
  26. void xuehao(void);
  27. void delay10ms(uchar c);
  28. uchar keyscan(void);
  29. void Hc595Byte(uchar dat);
  30. void lay(unsigned int i);
  31. int main()
  32. {
  33.     uchar a=0x00,num1=0x00,num2=0x00,num3=0x00,w=0x00,w2=0x00,g,an,d,ans1,ans2,ans3,C,L;
  34.   while(1)        //++++++++++++++++++?a??????+++++++++++++++++++++++++++
  35.         {
  36.           xuehao();
  37.               a=keyscan();
  38.               if(a==16)
  39.                     break;
  40.         }
  41. while(1)
  42. {
  43.         g=0x00;        // 存键入的第一个字符
  44. while(1)
  45. { num1=keyscan();
  46.                            if(num1<10)
  47.                             break;
  48.                     }
  49. while(1)
  50. {   w2=w;   //存键入的第一个数
  51.     d=g;//+-*/
  52.         g=0;
  53.         w=num1;//存键入的数
  54.         L=num1;        //
  55. while(1)//显示键入的第一位数
  56. {
  57. led3=0,led2=0,led1=0,LED=shu[num1],LED=0x00;
  58. num2=keyscan();
  59. if(num2<=16)
  60. break;
  61. }
  62. if(num2<10)
  63.
  64. {
  65.
  66.         w=(num1)*10+num2;//当前数值
  67.         while(1)
  68.
  69.         {
  70.
  71.                 led3=0,led2=0,led1=0,LED=shu[num2],LED=0x00;
  72.                 led3=0,led2=0,led1=1,LED=shu[num1],LED=0x00;
  73.                 num3=keyscan();
  74.                 if(num3<=16)
  75.                 {
  76.                         if(num3<10)
  77.                         {
  78.                                 w=(num1)*100+(num2)*10+num3;
  79.                                 while(1)
  80.                                 {
  81.                                         led3=0,led2=0,led1=0,LED=shu[num3],LED=0x00;
  82.                      led3=0,led2=0,led1=1,LED=shu[num2],LED=0x00;
  83.                                         led3=0,led2=1,led1=0,LED=shu[num1],LED=0x00;
  84.                                         g=keyscan();
  85.                                         if(g==15)
  86.                                                 break;
  87.                                         if(g>10&&g<16)        //判断是否为+-*/
  88.                                         {
  89.                                                 while(1)
  90.                                                 {
  91.                                                         led3=0,led2=0,led1=0,LED=shu[num3];
  92.                                                         lay(5);
  93.                                                         LED=0x00;    //消隐
  94.                                                         led3=0,led2=0,led1=1,LED=shu[num2];
  95.                                                         lay(5);
  96.                                                         LED=0x00;
  97.                                                         led3=0,led2=1,led1=0,LED=shu[L];
  98.                                                         lay(5);
  99.                                                         LED=0x00;
  100.                                                         led3=1,led2=1,led1=1,zhifu(g),LED=0x00;
  101.                                                         num1=keyscan();
  102.                                                         if(num1<10)
  103.        break;
  104.                                                 }
  105.                                         }
  106.                                         if(g>10&&g<16)
  107.                                                 break;
  108.                                 }
  109.                         }
  110.                         else
  111.                         {        g=num3;
  112.                         if(g==15)
  113.                                 break;
  114.                         while(1)
  115.                         {
  116.                                 led3=0,led2=0,led1=0,LED=shu[num2];
  117.                                 lay(5);
  118.                                 LED=0x00;
  119.                                 led3=0,led2=0,led1=1,LED=shu[L];
  120.                                 lay(5);
  121.                                 LED=0x00;
  122.                                 led3=1,led2=1,led1=1,zhifu(g),LED=0x00;
  123.                                 num1=keyscan();
  124.                                 if(num1<10)
  125.                                         break;
  126.                         }
  127.                         }
  128.                         if(g==15)
  129.                                 break;
  130.     }
  131.     if(g>10)
  132.     break;
  133.   }
  134. }
  135. else
  136. { g=num2;
  137. w=num1;
  138. if(g==15)                        //================================================
  139.          break;                                //===============================================
  140. while(1)                                //===================================================
  141. {
  142.          led3=0,led2=0,led1=0,LED=shu[L];
  143.          lay(5);
  144.          LED=0x00;
  145.          led3=1,led2=1,led1=1,zhifu(g),LED=0x00;
  146.          num1=keyscan();
  147.          if(num1!=17)
  148.                  break;
  149. }
  150. }
  151. if(g==15)
  152.          break;
  153. else
  154.          continue;
  155. }
  156.      switch(d)                                                          //+++++++++++++++++++++???????+++++++++++++++++++++++
  157.           {case 0x0b: an=w2+w; break;
  158.            case 0x0c: an=w2-w; break;
  159.            case 0x0d: an=w2*w; break;
  160.            case 0x0e: an=w2/w; break;
  161.            default: an=0;break;
  162.       }
  163.            while(1)
  164.            {
  165.                    if(an<10)
  166.                    {
  167.                            led3=0,led2=0,led1=0,LED=shu[an];
  168.                        lay(5);
  169.                        LED=0x00;
  170.                            led3=1,led2=1,led1=1,zhifu(g),LED=0x00;        }
  171.
  172.                    else
  173.                    {
  174.                           if(an<100)
  175.                           {
  176.                                    ans2=an/10;
  177.                                    ans1=an%10;
  178.                                    led3=0,led2=0,led1=0,LED=shu[ans1];
  179.                                    lay(5);
  180.                                    LED=0x00;
  181.                                    led3=0,led2=0,led1=1,LED=shu[ans2];
  182.                                    lay(5);//延时
  183.                                    LED=0x00;
  184.                                    led3=1,led2=1,led1=1,zhifu(g),LED=0x00;
  185.                           }
  186.                           else
  187.                           {
  188.                                   ans3=an/100;
  189.                                   ans2=(an%100 )/10;
  190.                                   ans1=an%10;
  191.                                   led3=0,led2=0,led1=0,LED=shu[ans1];
  192.                                   lay(5);
  193.                                   LED=0x00;
  194.                                   led3=0,led2=0,led1=1,LED=shu[ans2];
  195.                                   lay(5);
  196.                                   LED=0x00;
  197.                                   led3=0,led2=1,led1=0,LED=shu[ans3];
  198.                                   lay(5);
  199.                                   LED=0x00;
  200.                                   led3=1,led2=1,led1=1,zhifu(g),LED=0x00;
  201.                           }
  202.                         }
  203.                    C=keyscan();
  204.                    if(C==16)
  205.                       break;
  206.                 }
  207. }
  208. //======================================================
  209.    return 0;
  210. }
  211. //===================================
  212. void xuehao(void)
  213. {
  214. led3=0,led2=0,led1=0,LED=shu[1],LED=0x00;
  215. led3=0,led2=0,led1=1,LED=shu[2],LED=0x00;
  216. led3=0,led2=1,led1=0,LED=shu[0],LED=0x00;
  217. led3=0,led2=1,led1=1,LED=shu[3],LED=0x00;
  218. led3=1,led2=0,led1=0,LED=shu[2],LED=0x00;
  219. led3=1,led2=0,led1=1,LED=shu[3],LED=0x00;
  220. led3=1,led2=1,led1=0,LED=shu[0],LED=0x00;
  221. led3=1,led2=1,led1=1,LED=shu[3],LED=0x00;
  222. }
  223. //=====================================
  224. uchar keyscan(void)
  225. {   uchar Keyvalue=17;
  226.         KEY=0x0f;
  227.         if(KEY!=0x0f)
  228.         {
  229.                 delay10ms(1);
  230.                 if(KEY!=0x0f)
  231.                 {
  232.                         KEY=0x0F;
  233.                         switch(KEY)
  234.                         {
  235.                                 case(0x07):        Keyvalue=1;break;
  236.                                 case(0x0b):        Keyvalue=2;break;
  237.                                 case(0x0d): Keyvalue=3;break;
  238.                                 case(0x0e):        Keyvalue=4;break;
  239.                         }
  240.                         //2a?DD
  241.                         KEY=0xf0;
  242.                         switch(KEY)
  243.                         {
  244.                                 case(0x70):        Keyvalue=Keyvalue;   break;
  245.                                 case(0xb0):        Keyvalue=Keyvalue+4; break;
  246.                                 case(0xd0): Keyvalue=Keyvalue+8; break;
  247.                                 case(0xe0):        Keyvalue=Keyvalue+12;break;
  248.                         }
  249.                         while(KEY!=0xf0);
  250.
  251.                 }
  252.                 yinyue(        Keyvalue);
  253.         }
  254.         if(Keyvalue==10)
  255.         {
  256.         Keyvalue=Keyvalue-10;
  257.         }
  258.            return Keyvalue;
  259. }
  260. //....................................................................................
  261. //.....................................................................................
  262. void delay10ms(uchar c)
  263. {
  264.     uchar a,b;
  265.     for(;c>0;c--)
  266.         for(b=38;b>0;b--)
  267.             for(a=130;a>0;a--);
  268. }
  269. //............................................................................................
  270. void yinyue(uchar m)
  271. {
  272.      uchar k;
  273.      for(k=0;k<100;k++)
  274.         {
  275.                 Beep=0;
  276.          lay(m*2);
  277.                 Beep=1;
  278.         lay(m*2);
  279.         }
  280. }
  281.     //=========================
  282. void Hc595Byte(unsigned char dat)
  283. {        unsigned char a;
  284.         SRCLK=0;
  285.         RCLK=0;
  286.         for(a=0;a<8;a++)
  287.         {
  288.                 SER=dat>>7;
  289.                 dat<<=1;
  290.                 SRCLK=1;
  291.                 _nop_();
  292.                 _nop_();
  293.                 SRCLK=0;
  294.         }
  295.         RCLK=1;
  296.         _nop_();
  297.         _nop_();
  298.         RCLK=0;
  299. }
  300. //**********************************************
  301. void zhifu(uchar q)
  302. {
  303.           unsigned char tab,j;
  304.         j=q-11;
  305.                 for(tab=0;tab<8;tab++)
  306.                         {
  307.                                 Hc595Byte(0x00);
  308.                                 LED= TAB[tab];
  309.                                 Hc595Byte(CHARCODE[j][tab]);
  310.                         }
  311. }
  312. void lay(unsigned int i)
  313. {
  314.         char j;
  315.         for(i; i > 0; i--)
  316.                 for(j = 200; j > 0; j--);
  317. }
收藏收藏1 分享淘帖 顶顶 踩踩
