查看: 2404|回复: 1
下面程序怎么设置步进为50Hz,范围1Hz~800Hz
ID:122052 发表于 2016-6-2 22:19 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
#include <reg51.h>
#include<string.h>
#define uint unsigned int
//--LCD控制引脚
sbit RS=P3^0;
sbit RW=P3^1;
sbit EN=P3^3;
sbit K2=P2^1;
sbit K3=P2^2;
uchar ys=30;
uchar i,a=0;
uint freq;
uchar code Wave[]={"bujin:"};
uchar code Sin[]={"50Hz"};
uchar code No[]={"No Signal out "};
uchar code Fre[]={"Freq :"};
uchar code tosin[256]=
{0x80,0x83,0x86,0x89,0x8d,0x90,0x93,0x96,0x99,0x9c,0x9f,0xa2,0xa5,0xa8,0xab,
0xae,0xb1,0xb4,0xb7,0xba,0xbc,0xbf,0xc2,0xc5,0xc7,0xca,0xcc,0xcf,0xd1,0xd4,0xd6,0xd8,
0xda,0xdd,0xdf,0xe1,0xe3,0xe5,0xe7,0xe9,0xea,0xec,0xee,0xef,0xf1,0xf2,0xf4,
0xf5,0xf6,0xf7,0xf8,0xf9,0xfa,0xfb,0xfc,0xfd,0xfd,0xfe,0xff,0xff,0xff,0xff,0xff,0xff,
0xff,0xff,0xff,0xff,0xff,0xff,0xfe,0xfd,0xfd,0xfc,0xfb,0xfa,0xf9,0xf8,0xf7,0xf6,0xf5,
0xf4,0xf2,0xf1,0xef,0xee,0xec,0xea,0xe9,0xe7,0xe5,0xe3,0xe1,0xde,0xdd,0xda,0xd8,
0xd6,0xd4,0xd1,0xcf,0xcc,0xca,0xc7,0xc5,0xc2,0xbf,0xbc,0xba,0xb7,0xb4,0xb1,0xae,0xab,
0xa8,0xa5,0xa2,0x9f,0x9c,0x99,0x96,0x93,0x90,0x8d,0x89,0x86,0x83,0x80,
0x80,0x7c,0x79,0x76,0x72,0x6f,0x6c,0x69,0x66,0x63,0x60,0x5d,0x5a,0x57,0x55,
0x51,0x4e,0x4c,0x48,0x45,0x43,0x40,0x3d,0x3a,0x38,0x35,0x33,0x30,0x2e,0x2b,
0x29,0x27,0x25,0x22,0x20,0x1e,0x1c,0x1a,0x18,0x16,0x15,0x13,0x11,0x10,0x0e,
0x0d,0x0b,0x0a,0x09,0x08,0x07,0x06,0x05,0x04,0x03,0x02,0x02,0x01,0x00,0x00,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0x02 ,0x02,0x03,0x04,
0x05,0x06,0x07,0x08,0x09,0x0a,0x0b,0x0d,0x0e,0x10,0x11,0x13,0x15,0x16,0x18,
0x1a,0x1c,0x1e,0x20,0x22,0x25,0x27,0x29,0x2b,0x2e,0x30,0x33,0x35,0x38,0x3a,
0x3d,0x40,0x43,0x45,0x48,0x4c,0x4e ,0x51,0x55,0x57,0x5a,0x5d,0x60,0x63,0x66 ,
0x69,0x6c,0x6f,0x72,0x76,0x79,0x7c,0x80 }; //正弦波码
//--延时MS
void DelayMS(uchar ms)
        uchar i;
        while(ms--)
         for(i=0;i<120;i++);
//--延时y*9us
void Delay1(uint y)
        uint i;
        for(i=y;i>0;i--);
//忙检查
uchar Busy_Check()
        uchar LCD_Status;
        RS=0;  //        寄存器选择
        RW=1; //读状态寄存器
        EN=1;  // 开始读
        DelayMS(1);
        LCD_Status=P1;
        EN=0;
        return  LCD_Status;
//写LCD命令
void Write_LCD_Command(uchar cmd)
           while((Busy_Check()&0x80)==0x80);   //忙等待
           RS=0;  //选择命令寄存器
           RW=0;  //写
           EN=0;
           P1=cmd;
           EN=1;
           DelayMS(1);
           EN=0;
//发送数据
void Write_LCD_Data(uchar dat)
          RS=1;
          RW=0;
          EN=0;
          P1=dat;
          EN=1;
          DelayMS(1);
          EN=0;
//LCD初始化
void Init_LCD()
        Write_LCD_Command(0x38);
        DelayMS(1);
        Write_LCD_Command(0x01); //清屏
        DelayMS(1);
        Write_LCD_Command(0x06); //字符进入模式:屏幕不动,字符后移
        DelayMS(1);
        Write_LCD_Command(0x0C); //显示开、关光标
        DelayMS(1);
//--向LCD写频率值
void Write_freq(uint k)
        uchar bai,shi,ge;
        //qian=k/1000;
        bai=k/100;
        shi=k/100%10;
        ge=k%10;
        Write_LCD_Command(0x86+0x40);
        Write_LCD_Data(0x30+bai);
        Write_LCD_Data(0x30+shi);
        Write_LCD_Data(0x30+ge);
        Write_LCD_Data(0x48);
        Write_LCD_Data(0x5a);
//--LCD上显示不同波形频率
  void Xianshi_f()
     freq=(10000000/(50000+286*ys));
         Write_freq(freq);
//--LCD上写波形类型
void Write_wave()
                                //--正弦波
                                ys=25;
                                Write_LCD_Command(0x86);
                                   DelayMS(5);
                                    for (i=0;i<sizeof(Sin)-1;i++)
                                                Write_LCD_Data(Sin[i]);
                                                DelayMS(5);
//---输出波形
void Out_Wave()
{         uchar j;
                                //---正弦波
                                for (j=0;j<255;j++)
                                        P0=tosin[j];
                                        Delay1(ys);
//----按键扫描
void keyscanf()
        if(K2==0)
                DelayMS(5);
                if(K2==0)
                        while(!K2);
                        ys--;
                        if(ys==0)
                        ys=30;
        if(K3==0)
                DelayMS(5);
                if(K3==0)
                        while(!K3);
                        ys++;
                        if(ys>30)
                        ys=30;
        Init_LCD();
        IE=0X81;
        Write_LCD_Command(0x80);//--显示wave:
           DelayMS(5);
   for (i=0;i<sizeof(Wave)-1;i++)
                        Write_LCD_Data(Wave[i]);
                        DelayMS(5);
            Write_LCD_Command(0x80+0X40);//----显示freq:
     DelayMS(5);
    for (i=0;i<sizeof(Fre)-1;i++)
                        Write_LCD_Data(Fre[i]);
                        DelayMS(5);
           Write_wave();
        while (1)
                keyscanf();
                Out_Wave();
                if(!(K2&K3))
                                Xianshi_f();
谢谢谢谢
ID:390748 发表于 2018-9-28 09:34 | 只看该作者
ys是什么意思
