Hex keypad or tablet counting system
源程序如下:
- Project/Module : Assignment
- File name : HexKeyCodeGenerator.v
- Version : 1-0
- Date created : 25 Aug 2017
- Author : Vimalraj Kasivisvanathan
- Code type : Verilog
- Description : Verilog code for HexKeypad
- //`default_nettype none
- module HEXKEY
- #(parameter [3:0]
- PRESSKEY = 4'b0001,
- KEYCOL0 = 4'b0010,
- KEYCOL1 = 4'b0011,
- KEYCOL2 = 4'b0100,
- KEYCOL3 = 4'b0101,
- //DELAY1 = 4'b0110,
- //DELAY2 = 4'b0111,
- KEYVALID = 4'b1000,
- KEYRELEASE = 4'b1001,
- KEYERROR = 4'b1010)
- (input b_ip_hex_sys_clock,
- input b_ip_hex_sys_reset,
- input b_ip_hex_clear,
- input [3:0] b_ip_hex_keypad_row
- output reg [3:0] b_op_hex_keycode,
- output reg b_op_hex_valid_code,
- output reg [3:0] b_op_hex_keypad_column,
- reg [3:0] current,next,row;
- ///////////////FIRST//////////////////////////////////////
- always @(posedge b_ip_hex_sys_clock) begin: BGN
- if (b_ip_hex_sys_reset || b_ip_hex_clear) current <= PRESSKEY;
- else current <= next;
- end
- ///////////////////////CURRENTSTATE/////////////////////////
- always @(b_ip_hex_keypad_row || current)begin: NSL
- case(current)
- PRESSKEY:
- if ((|b_ip_hex_keypad_row)) next <= KEYCOL0;
- else next <= PRESSKEY;
- KEYCOL0:
- if ((|b_ip_hex_keypad_row)) next = KEYVALID;
- else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0001) next = KEYCOL1;
- KEYCOL1:
- else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0010) next = KEYCOL2;
- KEYCOL2:
- else if ((!(|b_ip_hex_keypad_row)) && b_op_hex_keypad_column == 4'b0100) next = KEYCOL3;
- KEYCOL3:
- else if (!(b_ip_hex_keypad_row)) next = KEYERROR;
- else next = 4'bx;
- KEYVALID:
- next = KEYRELEASE;
- KEYRELEASE:
- if (!(|b_ip_hex_keypad_row)) next = PRESSKEY;
- else next = KEYRELEASE;
- KEYERROR:
- next = PRESSKEY;
- default:
- next = 4'bx;
- endcase
- end
- /////////////////////NEXTSTATE LOGIC///////////////////////////////////////////////
- always @(posedge b_ip_hex_sys_clock)begin: ROL
- if (b_ip_hex_sys_reset || b_ip_hex_clear)begin
- b_op_hex_keypad_column <= 4'b1111;
- b_op_hex_valid_code <= 1'b0;
- b_op_hex_keycode <= 4'b0000;
- row <= 4'b0000;
- end
- else begin
- case(next)
- PRESSKEY:begin
- row <= 4'b0000;
- end
- KEYCOL0:begin
- b_op_hex_keypad_column <= 4'b0001;
- row <= b_ip_hex_keypad_row;
- if (row == 4'b0001) b_op_hex_keycode <= 4'b0000;
- else if (row == 4'b0010) b_op_hex_keycode <= 4'b0100;
- else if (row == 4'b0100) b_op_hex_keycode <= 4'b1000;
- else if(row == 4'b1000) b_op_hex_keycode <= 4'b1100;
- end
- KEYCOL1:begin
- b_op_hex_keypad_column <= 4'b0010;
- row <= row;
- if (row == 4'b0001) b_op_hex_keycode <= 4'b0001;
- else if (row == 4'b0010) b_op_hex_keycode <= 4'b0101;
- else if (row == 4'b0100) b_op_hex_keycode <= 4'b1001;
- else if(row == 4'b1000) b_op_hex_keycode <= 4'b1101;
- end
- KEYCOL2:begin
- b_op_hex_keypad_column <= 4'b0100;
- row <= row;
- if (row == 4'b0001) b_op_hex_keycode <= 4'b0010;
- else if (row == 4'b0010) b_op_hex_keycode <= 4'b0110;
- else if (row == 4'b0100) b_op_hex_keycode <= 4'b1010;
- else if(row == 4'b1000) b_op_hex_keycode <= 4'b1110;
- end
- KEYCOL3:begin
- b_op_hex_keypad_column <= 4'b1000;
- row <= row;
- if (row == 4'b0001) b_op_hex_keycode <= 4'b0011;
- else if (row == 4'b0010) b_op_hex_keycode <= 4'b0111;
- else if (row == 4'b0100) b_op_hex_keycode <= 4'b1011;
- else if(row == 4'b1000) b_op_hex_keycode <= 4'b1111;
- end
- KEYRELEASE:begin
- b_op_hex_keycode <= b_op_hex_keycode;
- end
HexKeypad.rar
(72.42 KB, 下载次数: 6)
