查看: 2855|回复: 4
单片机跑马灯加音乐
ID:263267 发表于 2017-12-18 18:28 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
         下面是我的程序以及错误求大师们帮我改一下,最后是跑马灯加音乐就行,我用的是AT89C52
  1. #include "reg52.h"
  2. sbit key1=P0^0;
  3. sbit key2=P0^1;
  4. sbit key3=P0^2;
  5. sbit key4=P0^3;
  6. sbit key5=P0^4;
  7. sbit key6=P0^5;
  8. sbit key7=P0^6;
  9. sbit key8=P0^7;
  10. #include <INTRINS.H>
  11. sbit Beep =  P1^2;
  12. unsigned char n=0;  //n为节拍常数变量
  13. unsigned char code music_tab[] ={
  14. 0x18, 0x30, 0x1C , 0x10, //格式为: 频率常数, 节拍常数, 频率常数, 节拍常数,
  15. 0x20, 0x40, 0x1C , 0x10,
  16. 0x18, 0x10, 0x20 , 0x10,
  17. 0x1C, 0x10, 0x18 , 0x40,
  18. 0x1C, 0x20, 0x20 , 0x20,
  19. 0x1C, 0x20, 0x18 , 0x20,
  20. 0x20, 0x80, 0xFF , 0x20,
  21. 0x30, 0x1C, 0x10 , 0x18,
  22. 0x20, 0x15, 0x20 , 0x1C,
  23. 0x20, 0x20, 0x20 , 0x26,
  24. 0x40, 0x20, 0x20 , 0x2B,
  25. 0x20, 0x26, 0x20 , 0x20,
  26. 0x20, 0x30, 0x80 , 0xFF,
  27. 0x20, 0x20, 0x1C , 0x10,
  28. 0x18, 0x10, 0x20 , 0x20,
  29. 0x26, 0x20, 0x2B , 0x20,
  30. 0x30, 0x20, 0x2B , 0x40,
  31. 0x20, 0x20, 0x1C , 0x10,
  32. 0x18, 0x10, 0x20 , 0x20,
  33. 0x26, 0x20, 0x2B , 0x20,
  34. 0x30, 0x20, 0x2B , 0x40,
  35. 0x20, 0x30, 0x1C , 0x10,
  36. 0x18, 0x20, 0x15 , 0x20,
  37. 0x1C, 0x20, 0x20 , 0x20,
  38. 0x26, 0x40, 0x20 , 0x20,
  39. 0x2B, 0x20, 0x26 , 0x20,
  40. 0x20, 0x20, 0x30 , 0x80,
  41. 0x20, 0x30, 0x1C , 0x10,
  42. 0x20, 0x10, 0x1C , 0x10,
  43. 0x20, 0x20, 0x26 , 0x20,
  44. 0x2B, 0x20, 0x30 , 0x20,
  45. 0x2B, 0x40, 0x20 , 0x15,
  46. 0x1F, 0x05, 0x20 , 0x10,
  47. 0x1C, 0x10, 0x20 , 0x20,
  48. 0x26, 0x20, 0x2B , 0x20,
  49. 0x30, 0x20, 0x2B , 0x40,
  50. 0x20, 0x30, 0x1C , 0x10,
  51. 0x18, 0x20, 0x15 , 0x20,
  52. 0x1C, 0x20, 0x20 , 0x20,
  53. 0x26, 0x40, 0x20 , 0x20,
  54. 0x2B, 0x20, 0x26 , 0x20,
  55. 0x20, 0x20, 0x30 , 0x30,
  56. 0x20, 0x30, 0x1C , 0x10,
  57. 0x18, 0x40, 0x1C , 0x20,
  58. 0x20, 0x20, 0x26 , 0x40,
  59. 0x13, 0x60, 0x18 , 0x20,
  60. 0x15, 0x40, 0x13 , 0x40,
  61. 0x18, 0x80, 0x00
  62. };
  63. void int0()  interrupt 1
  64. {  TH0=0xd8;
  65.    TL0=0xef;
  66.    n--;
  67. }
  68. void delay (unsigned char m)   //控制频率延时
  69. {
  70. unsigned i=3*m;
  71. while(--i);
  72. }
  73. void delayms(unsigned char a)  //豪秒延时子程序
  74. {
  75.   while(--a);
  76. }
  77. void sound()
  78. { unsigned char p,m;   //m为频率常数变量
  79.   unsigned char i=0;
  80.   TMOD&=0x0f;
  81.   TMOD|=0x01;
  82.   TH0=0xd8;TL0=0xef;
  83.   IE=0x82;
  84. play:
  85.    while(1)
  86.     {
  87.     a: p=music_tab[i];
  88.        if(p==0x00)       { i=0, delayms(1000); goto play;}     //
  89.        else if(p==0xff)  { i=i+1;delayms(100),TR0=0; goto a;}
  90.             else         {m=music_tab[i++], n=music_tab[i++];}  /
  91.              TR0=1;                                             //开定时器1
  92.            while(n!=0) Beep=~Beep,delay(m);                         /
  93.        TR0=0;                                             //关定时器1
  94.     }
  95. }
  96. int num=0;
  97. int flag_hz=10;
  98. void main()
  99. {
  100.         TMOD=0X01;
  101.         TH0=(65536-50000)/256;
  102.         TL0=(65536-50000)%256;
  103.         EA=1;
  104.         ET0=1;
  105.         TR0=1;
  106.         P2=0xff;
  107.         while(1)
  108.         {
  109.                         sound();
  110.                 if(key1==0)
  111.                 {
  112.                         flag_hz=5;
  113.
  114.                 }
  115.                 if(key2==0)
  116.                 {
  117.                         flag_hz=25;
  118.                 }
  119.                 if(key3==0)
  120.                 {
  121.                  flag_hz=45;
  122.                 }
  123.                 if(key4==0)
  124.                 {
  125.
  126.                 }
  127.                 if(key5==0)
  128.                 {
  129.                         P3=0X03;
  130.
  131.                         P2=0X03;
  132.                 }
  133.                 if(key6==0)
  134.                 {
  135.                         P3=0X33;
  136.                         P2=0X33;
  137.                 }
  138.                 if(key7==0)
  139.                 {
  140.                         P3=0XAA;
  141.                         P2=0XAA;
  142.                 }
  143.                 if(key8==0)
  144.                 {
  145.                         P3=0X99;
  146.                         P2=0X99;
  147.                 }
  148.         }
  149. }
  150. void T0_time() interrupt 1                                 //50MS
  151. {
  152.         TH0=(65536-50000)/256;
  153.         TL0=(65536-50000)%256;
  154.         num++;
  155.         if(num>=flag_hz)
  156.         {
  157.                 num=0;
  158.                 P3=~P3;
  159.                 P2=~P2;
  160.         }
  161. }
警告:Build target 'Target 1'
assembling STARTUP.A51...
compiling shijian 7.c...
linking...
*** WARNING L5: CODE SPACE MEMORY OVERLAP
    TO:      000DH
Program Size: data=14.0 xdata=0 code=606
creating hex file from "shijian  7"...
"shijian  7" - 0 Error(s), 1 Warning(s).
收藏收藏 分享淘帖 顶1 踩
ID:472242 发表于 2019-2-4 05:17 | 只看该作者
这个真的不难,从数组取出的节拍作LED的按制变量
参与人数 6黑币 +150 收起 理由
刀刀见红 + 35
Sawardeakar + 35
#include51.h + 15
jinsheng7533967 + 35
yoxi + 15
Trump1438 + 15
ID:355917 发表于 2019-2-4 17:57 | 只看该作者
定义了两个同级中断函数,得去掉一个
ID:155507 发表于 2019-2-4 18:37 | 只看该作者
重复用同一个中断,看一下interrupt N 这个N
ID:355917 发表于 2019-2-4 20:00 | 只看该作者
void int0() interrupt 1       void T0_time() interrupt 1 定义了两个同级中断函数,得去掉前面那个中断函数
