寻迹小车pid调速
- #include "adc.h"
- #include "common.h"
- #include "usart.h"
- #include "L298N.h"
- #include "senser.h"
- #include "NVIC.h"
- #include "ir1838.h"
- #include "DMA.h"
- #define kP 11
- #define kdI 200 //nI除数 kI=1/kdI
- #define kD 120
- #define kdPID 28//PID除数
- #define D_INTERVAL 1200
- #define I_INTERVAL 15
- #define ONLINE_MINVAL 25
- #define POSVAL_MAX SENSER_MAXVAL*2//位置量值域(-POSVAL_MAX,POSVAL_MAX)
- #define SPEED_MIN 1700
- #define SPEED_NORMAL 1950
- #define SPEED_MAX 2000
- #define CHECK_WAIT_TIMEOUT 100000
- extern u16 ADC_DataBuffer[ADC_DMA_BUFFER_LENGTH];
- extern u32 senVals[3];
- u16 mod=0;
- int main()
- s32 PID;
- s32 nP=0;
- s32 nI=0;
- s32 nD=0;
- s32 nLastP=0;
- u32 nDC=D_INTERVAL;
- u32 nIC=I_INTERVAL;
- s32 carSpeed=SPEED_NORMAL;
- u32 checkWait=0;
- u8 adjustMod=100;
- common_init();
- ADC_init();
- #ifdef USART_ON
- usart_init();
- #endif
- L298N_init();
- #ifdef IR_CTRL_
- IR1838_init();
- #else
- //mod=1;
- #endif
- DMA_init();
- NVIC_init();
- delayms(120);//等待DMA将 adc_buffer 填满,避免senser校准值出错(如果有0会导致minvs不正确)
- while (1)
- #ifdef IR_CTRL_
- Ircordpro();
- #endif
- switch (mod)
- case 0:
- //等待车被放上跑道
- senVals[0]=ADC_DMA_getVal(0);
- senVals[1]=ADC_DMA_getVal(1);
- senVals[2]=ADC_DMA_getVal(2);
- #ifdef USART_ON
- #define LSHIFTBIT 9
- #define SENVALGATE 9
- //printDebug("senVals[0]=",senVals[0]);
- //printDebug("senVals[1]=",senVals[1]);
- //printDebug("senVals[2]=",senVals[2]);
- //printDebug("-------------\n",0);
- if(senVals[2]>SENVALGATE)
- senVals[2]-=SENVALGATE;
- else
- senVals[2]=0;
- senVals[2]<<=LSHIFTBIT;
- L298N_setLS(senVals[2]);
- L298N_setRS(senVals[2]);
- //delayms(3000);
- continue;
- #endif
- if (senVals[0]>SENSER_ORIGIN_MIN&&senVals[0]>SENSER_ORIGIN_MIN&&senVals[0]>SENSER_ORIGIN_MIN)//车被提起
- checkWait=CHECK_WAIT_TIMEOUT;
- adjustMod=100;
- L298N_setLS(0);
- L298N_setRS(0);
- else
- if(adjustMod==100)
- adjustMod=0;
- Senser_reset();
- switch (adjustMod)
- case 0:
- if (checkWait)
- checkWait--;
- else
- adjustMod=1;
- beep(900,300);
- break;
- case 1:
- //将左传感器移动到线上
- L298N_setLS(1400);
- L298N_setRS(0);
- if(senVals[0]>SENSER_ORIGIN_MIN)
- adjustMod=2;
- break;
- case 2:
- //将左传感器移动到线右边
- if(senVals[0]<SENSER_ORIGIN_MIN)
- L298N_setLS(0);
- L298N_setRS(0);
- adjustMod=3;
- beep(900,300);
- break;
- case 3:
- //左转开始扫描,直到右传感在线上
- L298N_setLS(0);
- L298N_setRS(1400);
- if(senVals[2]>SENSER_ORIGIN_MIN)
- adjustMod=4;
- break;
- case 4:
- //直到右传感器移动到线左边
- if(senVals[2]<SENSER_ORIGIN_MIN)
- adjustMod=5;
- beep(900,300);
- break;
- case 5:
- //右转直到中间传感器在线上
- L298N_setLS(0);
- if(senVals[1]>SENSER_ORIGIN_MIN)
- beep(800,300);
- delayms(10);
- beep(600,300);
- delayms(10);
- beep(600,300);
- delayms(10);
- beep(600,300);
- mod=1;
- if(adjustMod==3||adjustMod==4)
- //校正
- Senser_getsv(0);
- Senser_getsv(1);
- Senser_getsv(2);
- case 1:
- Senser_getsv(0);
- Senser_getsv(1);
- Senser_getsv(2);
- /* ------------P------------ */
- /* 计算位置 */
- if (senVals[1]>ONLINE_MINVAL)
- //线在中间传感器下
- if (carSpeed<SPEED_MAX)
- //加速
- carSpeed++;
- if (senVals[0]>ONLINE_MINVAL)
- //中间偏左
- nP=POSVAL_MAX/2-senVals[1];
- else
- //中间偏右
- nP=senVals[1]-POSVAL_MAX/2;
- else if (senVals[0]>ONLINE_MINVAL)
- //线在左边传感器偏左
- nP=POSVAL_MAX-senVals[0];
- else if (senVals[2]>ONLINE_MINVAL)
- //线在右边传感器偏右
- nP=senVals[2]-POSVAL_MAX;
- else
- //线离开传感器检测范围
- if (carSpeed>SPEED_MIN)
- //减速
- carSpeed--;
- if (nP<0)
- nP=-POSVAL_MAX;
- else
- nP=POSVAL_MAX;
- //nP/=4;
- /* ------------I------------ */
- if(nIC)
- nIC--;
- else
- nIC=I_INTERVAL;
- if(nP>ONLINE_MINVAL||nP<-ONLINE_MINVAL)
- nI+=nP/20;//nI=9*nI/10;
- else
- nI=0;
- /* ------------D------------ */
- if(nDC)
- nDC--;
- else
- nDC=D_INTERVAL;
- nD=nP-nLastP;
- nLastP=nP;
- /* PID */
- PID=nP*kP + nI/kdI + nD*kD;
- PID/=kdPID;
- L298N_setSpeed(carSpeed,PID);
- printDebug("nP=",nP*kP);
- printDebug("nI=",nI/kdI);
- printDebug("nD=",nD*kD);
- printDebug("PID=",PID);
- printChar('\n',USART2);
- printDebug("LS=",TIM4->CCR3);
- printDebug("RS=",TIM4->CCR4);
巡线.rar
(116.53 KB, 下载次数: 363)
