硬件平台:红牛stm32F103ZE开发板,DDS模块:AD9910
软件版本:Keil 4
固件库版本:v3.5
完成功能:
(1)产生频率范围:1Hz - 400MHz 的正弦波(按键触发(F = 100KHz,Vpp:500mV):开发板上 WAKEUP 按键)
(2)产生幅度范围:1mV - 650mV 的正弦波(初始化后:F = 100Hz,Vpp:100mV)
(3)产生上下限频率、频率步进(单位:Hz)、步进时间间隔(单位:us;输入范围:1-262us)可调的扫频波(按键触发(Fmin = 1KHz,Fmax = 100KHz,频率步进:10Hz,步进时间间隔:240us,Vpp:500mV):开发板上 USER1 按键)
(Hardware platform: Red Bull stm32F103ZE development board, DDS module: AD9910. Software version: Keil 4 Firmware library version: v3.5 Complete function: (1) produce frequency range: 1Hz - 400MHz sine wave (keystroke trigger (F = 100KHz, Vpp:500mV): WAKEUP button on development board). (2) the amplitude range is 1mV - 650mV sine wave (initialization: F = 100Hz, Vpp:100mV). (3) generation of upper and lower frequency, frequency step (unit: Hz), step time interval (unit: US; input range: 1-262us) adjustable sweep wave (key trigger (Fmin = 1KHz, Fmax = 100KHz, frequency step: 10Hz, step time interval: 240us, Vpp:500mV): developing the USER1 button on board))
单片机源码:
- #include "pbdata.h"
- void RCC_Configuration(void);
- //void GPIO_Configuration(void);
- extern uchar cfr2[4]; //cfr2控制字
- int main(void)
- RCC_Configuration();//系统时钟初始化
- // GPIO_Configuration();//端口时钟初始化
- delay_init(72);
- Init_ad9910();
- //初始状态:100Hz,Vpp:100mV
- Freq_convert(300000000); //写频率,输入范围:1-400 000 000Hz
- Write_Amplitude(150); //写幅度,输入范围:1-650 mV
- while(1)
- if(PAin(0) == 0)
- delay_ms(5);
- cfr2[1] = 0x00; //DRG 失能
- Init_ad9910();
- Write_Amplitude(100); //写幅度,输入范围:1-650 mV
- // if(PAin(8) == 0)
- // delay_ms(5);
- // cfr2[1]=0x0e; //DRG 使能
- // Init_ad9910();
- // Write_Amplitude(500); //写幅度,输入范围:1-650 mV
- // //扫频波下限频率,上限频率,频率步进(单位:Hz),步进时间间隔(单位:us)
- // SweepFre(1000, 100000, 10, 240); //步进时间范围:1-262us
- SystemInit();
- // RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE); //使能APB2外设(GPIOB)时钟
- void GPIO_Configuration(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
全部资料51hei下载地址:
DDS v1.0.zip
(301.97 KB, 下载次数: 209)
