查看: 2145|回复: 1
简易示波器stm32f4源码
ID:323148 发表于 2018-5-14 21:21 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
简易示波器 stm32f4单片机源程序如下:
  1. #include "sys.h"
  2. #include "delay.h"
  3. #include "usart.h"
  4. #include "lcd.h"
  5. #include "display.h"
  6. #include "adc.h"
  7. #include "dma.h"
  8. #include "Key.h"
  9. #include "timer.h"
  10. #include "control.h"
  11. #include "dac.h"
  12. u16 buffer[4096]; //缓存区
  13. u8 pause = 0;
  14. extern uint32_t        TIM5CH1_CAPTURE_VAL;        //输入捕获值
  15. extern u8 count_Update;
  16. extern u16 peakValue;
  17. extern u16 valleyValue;
  18. extern u16 points[250];
  19. extern u8 graphIndex;
  20. IsSuitable_Type isSuit;
  21. int main(void)
  22. {
  23.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//设置系统中断优先级分组2
  24.         delay_init(168);
  25.         uart_init(9600);
  26.         display_Init();
  27.         DMA_ADCToMemory_Init((u32)buffer,4096);
  28.         Adc_Init();
  29.         Key_Init();
  30.         Control_Init();
  31.         TIM5_CH1_Cap_Init(0XFFFFFFFF,84-1); //以1Mhz的频率计数
  32.
  33.
  34.
  35.   while(1)
  36.         {
  37.                 ADC_DMACmd(ADC1,DISABLE);
  38.                 DMA_Cmd(DMA2_Stream0, DISABLE);
  39.                 if(count_Update)        //成功捕获到了一次高电平
  40.                 {
  41.                         float temp = 80000 / (float)TIM5CH1_CAPTURE_VAL;
  42.                         display_Frequence(temp);
  43.                         count_Update = 0;                     //开启下一次捕获
  44.                 }
  45.                 if(!pause)
  46.                 {
  47.                         while(!DMA_GetCurrDataCounter(DMA2_Stream0));
  48.                         display_DrawWave(buffer,4096);
  49.                         if(graphIndex == 250)
  50.                         {
  51.                                 display_DrawWavePoint();
  52.                                 graphIndex = 0;
  53.                         }
  54.                         DMA_ClearFlag(DMA2_Stream0,DMA_FLAG_TEIF0);
  55.                         DMA_ClearFlag(DMA2_Stream0,DMA_FLAG_TCIF0);
  56.                         DMA_Cmd(DMA2_Stream0,ENABLE);
  57.                         ADC_ClearFlag(ADC1,ADC_FLAG_OVR);
  58.                         ADC_DMACmd(ADC1,ENABLE);
  59.                         ADC_SoftwareStartConv(ADC1);
  60.                         delay_ms(10);
  61.                 }
  62.                 IsSuitable_Type isSuit = Control_NeedToAdjust(peakValue,valleyValue);
  63.                 if(isSuit!= OK)//
  64.                 {
  65.                         if(isSuit == Large)
  66.                                 Control_DecInput();
  67.                         else if(isSuit == Small)
  68.                                 Control_IncInput();
  69.                 }
  70.         }
  71. }
stm32Scope_Trainning-master.zip (670.93 KB, 下载次数: 50)
收藏收藏1 分享淘帖 顶 踩
ID:309521 发表于 2019-1-25 13:06 | 只看该作者
请问用32开发板可以实现嘛
