51单片机的I2C例程
- #include <reg52.h>
- #include "1602.h"
- #include "dht.h"
- //#include "2402.h"
- //定义三个LED灯
- //sbit Led_qushi=P1^6; //去湿灯
- //sbit Led_jiangwen=P1^5; //降温灯
- //sbit Led_shengwen=P1^4; //升温灯
- //sbit Key_TH1 = P3^2;
- //sbit Key_TH2 = P3^3;
- //sbit Key_HH1 = P3^4;
- //sbit Key_HH2 = P3^5
- sbit BUZZER = P1^5; //蜂鸣器端口
- //定义标识
- volatile bit FlagStartRH = 0; //开始温湿度转换标志
- //volatile bit FlagKeyPress = 0; //有键按下
- //定义温湿度传感器用外部变量
- extern U8 U8FLAG,k;
- extern U8 U8count,U8temp;
- extern U8 U8T_data_H,U8T_data_L,U8RH_data_H,U8RH_data_L,U8checkdata;
- extern U8 U8T_data_H_temp,U8T_data_L_temp,U8RH_data_H_temp,U8RH_data_L_temp,U8checkdata_temp;
- extern U8 U8comdata;
- extern U8 count, count_r;
- U16 temp;
- S16 temperature, humidity;
- S16 idata TH, HH; //温度上限和湿度上限
- char * pSave;
- //U8 keyvalue, keyTH1, keyTH2, keyHH1, keyHH2;
- //定义变量
- U16 RHCounter;
- //数据初始化
- void Data_Init()
- RHCounter = 0;
- // Led_qushi = 1;
- // Led_jiangwen = 1;
- // Led_shengwen = 1;
- BUZZER = 1;
- TH = 40;
- HH = 85;
- // keyvalue = 0;
- // keyTH1 = 1;
- // keyTH2 = 1;
- // keyHH1 = 1;
- // keyHH2 = 1;
- //定时器0初始化
- void Timer0_Init()
- ET0 = 1; //允许定时器0中断
- TMOD = 1; //定时器工作方式选择
- TL0 = 0x06;
- TH0 = 0xf8; //定时器赋予初值
- TR0 = 1; //启动定时器
- //定时器0中断
- void Timer0_ISR (void) interrupt 1 using 0
- TL0 = 0x06;
- //每2秒钟启动一次温湿度转换
- RHCounter ++;
- if (RHCounter >= 1000)
- FlagStartRH = 1;
- RHCounter = 0;
- //存入设定值、
- //void Save_Setting()
- // pSave = (char *)&TH; //地址低位对应低8位,高位对应高8位
- // wrteeprom(0, *pSave); //存温度上限值TH低8位
- // DELAY(500);
- // pSave ++;
- // wrteeprom(1, *pSave); //存温度上限值TH高8位
- // DELAY(500);
- // pSave = (char *)&HH;
- // wrteeprom(2, *pSave); //存湿度上限值RH低8位
- // DELAY(500);
- // pSave ++;
- // wrteeprom(3, *pSave); //存湿度上限值RH高8位
- // DELAY(500);
- //载入设定值、
- //void Load_Setting()
- // *pSave++ = rdeeprom(0);
- // *pSave = rdeeprom(1);
- // *pSave++ = rdeeprom(2);
- // *pSave = rdeeprom(3);
- // if ((TH>99)||(TH<0)) TH = 40;
- // if ((HH>99)||(HH<0)) HH = 85;
- //void KeyProcess(uint num)
- // switch (num)
- // case 1:
- // if (TH<99) TH++;
- // L1602_char(1, 15, TH/10+48);
- // L1602_char(1, 16, TH%10+48);
- // break;
- // case 2:
- // if (TH>1) TH--;
- // break;
- // case 3:
- // if (HH<99) HH++;
- // L1602_char(2, 15, HH/10+48);
- // L1602_char(2, 16, HH%10+48);
- // break;
- // case 4:
- // if (HH>1) HH--;
- // break;
- // default:
- // break;
- // Save_Setting();
- * 名称 : Main()
- * 功能 : 主函数
- void main()
- U16 i, j, testnum;
- EA = 0;
- Timer0_Init(); //定时器0初始化
- Data_Init();
- EA = 1;
- L1602_init();
- L1602_string(1,1," Welcome to T&H ");
- L1602_string(2,1," Control System! ");
- //延时
- for (i=0;i<1000;i++)
- for (j=0;j<1000;j++)
- //清屏
- L1602_string(1,1," ");
- L1602_string(2,1," ");
- L1602_string(1,1,"Tem: C TH:");
- L1602_string(2,1,"Hum: % HH:");
- // //载入温度上限和湿度上限设定值
- // Load_Setting();
- BUZZER = 0;
- while(1)
- //温湿度转换标志检查
- if (FlagStartRH == 1)
- TR0 = 0;
- testnum = RH();
- FlagStartRH = 0;
- TR0 = 1;
- //读出温湿度,只取整数部分
- humidity = U8RH_data_H;
- temperature = U8T_data_H;
- //显示温湿度
- L1602_int(1,5,temperature);
- L1602_int(2,5,humidity);
- //温湿度控制
- // if (temperature > TH) Led_jiangwen = 0;
- // else Led_jiangwen = 1; //降温
- // if (humidity > HH) Led_qushi = 0;
- // else Led_qushi = 1; //去湿
- //键盘查询,在弹起时响应
- // if ((Key_TH1)&&(keyTH1==0)) {FlagKeyPress = 1; keyvalue = 1;}
- // else if ((Key_TH2)&&(keyTH2==0)) {FlagKeyPress = 1; keyvalue = 2;}
- // else if ((Key_HH1)&&(keyHH1==0)) {FlagKeyPress = 1; keyvalue = 3;}
- // else if ((Key_HH2)&&(keyHH2==0)) {FlagKeyPress = 1; keyvalue = 4;}
- // if (FlagKeyPress == 1)
- // KeyProcess(keyvalue);
- // FlagKeyPress = 0;
- // if (!Key_TH1) keyTH1 = 0;
- // else keyTH1 = 1;
- // if (!Key_TH2) keyTH2 = 0;
- // else keyTH2 = 1;
- // if (!Key_HH1) keyHH1 = 0;
- // else keyHH1 = 1;
- // if (!Key_HH2) keyHH2 = 0;
- // else keyHH2 = 1;
I2C.rar
(132.06 KB, 下载次数: 21)
