查看: 2962|回复: 2
fpga模拟一个自动售货机 源代码
ID:393004 发表于 2018-9-3 15:27 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
售货机卖出的商品价值5元,只能投入1元,2元,5元。因此需要多种状态,分别代表投入的钱数,直到投够5元显示出货状态,当超过5元时还要找零。
源代码如下:
library ieee;
use ieee.std_logic_1164.all;
entity state is
port(
  clk,reset:in std_logic;
  input : in std_logic_vector(0 to 1);
  sel : buffer std_logic_vector(0 to 2);    --片选
  show : out std_logic_vector(0 to 6);      --八位七段
  output:out std_logic_vector(0 to 1)
end state;
architecture behave of state is
type s_m is (s0,s1,s2,s3,s5,s6);
signal current_state,next_state:s_m;
begin
   sel<="000";
       process(reset,clk)
       begin
                    if (clk'event and clk='1') then
   current_state<=next_state;
     if reset='1' then
                  current_state<=s0;
                    end if;
                      end if;
       end process;
       process(current_state,input)
begin
       case current_state is
       when s0=>output<="00";
        show<="1111110";  --0
        if input="00" then next_state<=s0;
        elsif input="01" then next_state<=s1;
                       elsif input="10" then next_state<=s2;
        elsif input="11" then next_state<=s5;
        end if;
       when s1=>output<="00";
        show<="0110000";   --1
        if input="00" then next_state<=s1;
        elsif input="01" then next_state<=s2;
        elsif input="10" then next_state<=s3;
        elsif input="11" then next_state<=s6;
       end if;
       when s2=>output<="11";
  show<="0110111";   --H
  end if;
       when s3=>output<="11";
  show<="0110000";   --找1
  end if;
       when s5=>output<="11";
  end if;
       when s6=>output<="11";
  end if;
end case;
                end process;
end behave;
ID:375250 发表于 2018-12-19 19:38 | 只看该作者
这个是vhdl
ID:453467 发表于 2018-12-24 15:13 | 只看该作者
复位信号建议写成:异步复位,同步释放
