查看: 2684|回复: 1
分享libnodave-0.8.5,西门子PLC通讯方法
直接上附件。
  1. /*
  2. Part of Libnodave, a free communication libray for Siemens S7 200/300/400 via
  3. the MPI adapter 6ES7 972-0CA22-0XAC
  4. or  MPI adapter 6ES7 972-0CA23-0XAC
  5. or  TS adapter 6ES7 972-0CA33-0XAC
  6. or  MPI adapter 6ES7 972-0CA11-0XAC,
  7. IBH/MHJ-NetLink or CPs 243, 343 and 443
  8. (C) Thomas Hergenhahn (thomas.hergenhahn@web.de) 2002..2005
  9. S5 basic communication parts (C) Andrew Rostovtsew 2004.
  10. Libnodave is free software; you can redistribute it and/or modify
  11. it under the terms of the GNU Library General Public License as published by
  12. the Free Software Foundation; either version 2, or (at your option)
  13. any later version.
  14. Libnodave is distributed in the hope that it will be useful,
  15. but WITHOUT ANY WARRANTY; without even the implied warranty of
  16. MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
  17. GNU General Public License for more details.
  18. You should have received a copy of the GNU Library General Public License
  19. along with Libnodave; see the file COPYING.  If not, write to
  20. the Free Software Foundation, 675 Mass Ave, Cambridge, MA 02139, USA.
  21. */
  22. #include "nodave.h"
  23. #include <stdio.h>
  24. #include "log2.h"
  25. #include <string.h>
  26. #define DUMPLIMIT 11132
  27. #define DAVE_HAVE_MEMCPY  // normally we have
  28. //#define DEBUG_CALLS        // Define this and recompile to get parameters and results
  29.                         // of each function call printed. I could have made this an
  30.                         // option bit in daveDebug, but most applications will never,never
  31.                         // need it. Still they would have to do the jumps...
  32.                         // This option is just useful when developing bindings to new
  33.                         // programming languages.
  34. /**
  35.     Library specific:
  36. **/
  37. #ifdef LINUX
  38. #define HAVE_UNISTD
  39. #define HAVE_SELECT
  40. #define DECL2
  41. #include <time.h>
  42. #include <sys/time.h>
  43. #endif
  44. #ifdef HAVE_UNISTD
  45. #include <unistd.h>
  46. #define daveWriteFile(a,b,c,d) d=write(a,b,c)
  47. #endif
  48. #ifdef AVR
  49. #include <unistd.h>
  50. #endif
  51. int daveDebug=0;
  52. #ifdef BCCWIN
  53. #include <winsock2.h>
  54. #include "openS7online.h"        // We can use the Siemens transport dlls only on Windows
  55. void setTimeOut(daveInterface * di, int tmo) {
  56.     COMMTIMEOUTS cto;
  57. #ifdef DEBUG_CALLS
  58.     LOG3("setTimeOut(di:%p, time:%d)\n",        di,tmo);
  59.     FLUSH;
  60. #endif
  61. //    if(di->fd.connectionType==daveSerialConnection) {
  62.         GetCommTimeouts(di->fd.rfd, &cto);
  63.         cto.ReadIntervalTimeout=0;
  64.         cto.ReadTotalTimeoutMultiplier=0;
  65.         cto.ReadTotalTimeoutConstant=tmo/1000;
  66.         SetCommTimeouts(di->fd.rfd,&cto);
  67. //    } else if(di->fd.connectionType==daveTcpConnection) {
  68. //    }
  69. }
  70. #endif
  71. #ifdef HAVE_SELECT
  72. int DECL2 stdwrite(daveInterface * di, char * buffer, int length) {
  73.     if (daveDebug & daveDebugByte)
  74.         _daveDump("I send", (uc*)buffer, length);
  75.     return write(di->fd.wfd, buffer,length);
  76. }
  77. int DECL2 stdread(daveInterface * di, char * buffer, int length) {
  78.     fd_set FDS;
  79.     struct timeval t;
  80.     int i;
  81.     t.tv_sec = di->timeout / 1000000;
  82.     t.tv_usec = (di->timeout % 1000000);
  83.     FD_ZERO(&FDS);
  84.     FD_SET(di->fd.rfd, &FDS);
  85.     i=0;
  86.     if(select(di->fd.rfd + 1, &FDS, NULL, NULL, &t)>0) {
  87.         i=read(di->fd.rfd, buffer, length);
  88.     }
  89. //    if (daveDebug & daveDebugByte)
  90. //        _daveDump("got",buffer,i);
  91.     return i;
  92. }
  93. #endif
  94. #ifdef BCCWIN
  95. int DECL2 stdread(daveInterface * di,
  96.          char * buffer,
  97.          int length) {
  98.     unsigned long i;
  99.     ReadFile(di->fd.rfd, buffer, length, &i, NULL);
  100. //    if (daveDebug & daveDebugByte)
  101. //        _daveDump("got",buffer,i);
  102.     return i;
  103. }
  104. int DECL2 stdwrite(daveInterface * di, char * buffer, int length) {
  105.     unsigned long i;
  106.     if (daveDebug & daveDebugByte)
  107.         _daveDump("I send",buffer,length);
  108. //    EscapeCommFunction(di->fd.rfd, CLRRTS);  // patch from Keith Harris. He says:
  109.                                              //******* this is what microwin does (needed for usb-serial)
  110.     WriteFile(di->fd.rfd, buffer, length, &i,NULL);
  111. // patch from Andrea. He says:
  112. // In this way the PC Adapter connected to CPU313C hangs waiting for RTS line before answering back.
  113. // Added the following to regain answers:
  114. //    EscapeCommFunction(di->fd.rfd, SETRTS);
  115.     return i;
  116. }
  117. #endif
  118. /*
  119.     Setup a new interface structure from an initialized serial interface's handle and a name.
  120. */
  121. daveInterface * DECL2 daveNewInterface(_daveOSserialType nfd, char * nname, int localMPI, int protocol, int speed){
  122.     daveInterface * di=(daveInterface *) calloc(1, sizeof(daveInterface));
  123. #ifdef DEBUG_CALLS
  124.     LOG7("daveNewInterface(fd.rfd:%d fd.wfd:%d name:%s local MPI:%d protocol:%d PB speed:%d)\n",
  125.         nfd.rfd,nfd.wfd,nname, localMPI, protocol, speed);
  126.     FLUSH;
  127. #endif
  128.     if (di) {
  129. //        di->name=nname;
  130.         strncpy(di->realName,nname,20);
  131.         di->name=di->realName;
  132.         di->fd=nfd;
  133.         di->localMPI=localMPI;
  134.         di->protocol=protocol;
  135.         di->timeout=1000000; /* 1 second */
  136.         di->nextConnection=0x14;
  137.         di->speed=speed;
  138.
  139.         di->getResponse=_daveGetResponseISO_TCP;
  140.         di->ifread=stdread;
  141.         di->ifwrite=stdwrite;
  142.         di->initAdapter=_daveReturnOkDummy;
  143.         di->connectPLC=_daveReturnOkDummy2;
  144.         di->disconnectPLC=_daveReturnOkDummy2;
  145.         di->disconnectAdapter=_daveReturnOkDummy;
  146.         di->listReachablePartners=_daveListReachablePartnersDummy;
  147.         switch (protocol) {
  148.             case daveProtoMPI:
  149.                 di->initAdapter=_daveInitAdapterMPI1;
  150.                 di->connectPLC=_daveConnectPLCMPI1;
  151.                 di->disconnectPLC=_daveDisconnectPLCMPI;
  152.                 di->disconnectAdapter=_daveDisconnectAdapterMPI;
  153.                 di->exchange=_daveExchangeMPI;
  154.                 di->sendMessage=_daveSendMessageMPI;
  155.                 di->getResponse=_daveGetResponseMPI;
  156.                 di->listReachablePartners=_daveListReachablePartnersMPI;
  157.                 break;
  158.
  159.             case daveProtoMPI2:
  160.             case daveProtoMPI4:
  161.                 di->initAdapter=_daveInitAdapterMPI2;
  162.                 di->connectPLC=_daveConnectPLCMPI2;
  163.                 di->disconnectPLC=_daveDisconnectPLCMPI;
  164.                 di->disconnectAdapter=_daveDisconnectAdapterMPI;
  165.                 di->exchange=_daveExchangeMPI;
  166.                 di->sendMessage=_daveSendMessageMPI;
  167.                 di->getResponse=_daveGetResponseMPI;
  168.                 di->listReachablePartners=_daveListReachablePartnersMPI;
  169.                 di->nextConnection=0x3;
  170.                 break;
  171.
  172.             case daveProtoMPI3:
  173.                 di->initAdapter=_daveInitAdapterMPI3;
  174.                 di->connectPLC=_daveConnectPLCMPI3;
  175.                 di->disconnectPLC=_daveDisconnectPLCMPI3;
  176.                 di->disconnectAdapter=_daveDisconnectAdapterMPI3;
  177.                 di->exchange=_daveExchangeMPI3;
  178.                 di->sendMessage=_daveSendMessageMPI3;
  179.                 di->getResponse=_daveGetResponseMPI3;
  180.                 di->listReachablePartners=_daveListReachablePartnersMPI3;
  181.                 di->nextConnection=0x3;
  182.                 break;
  183.             case daveProtoISOTCP:
  184.             case daveProtoISOTCP243:
  185.                 di->getResponse=_daveGetResponseISO_TCP;
  186.                 di->connectPLC=_daveConnectPLCTCP;
  187.                 di->exchange=_daveExchangeTCP;
  188.                 break;
  189.
  190.             case daveProtoPPI:
  191.                 di->getResponse=_daveGetResponsePPI;
  192.                 di->exchange=_daveExchangePPI;
  193.                 di->connectPLC=_daveConnectPLCPPI;
  194.                 di->timeout=150000; /* 0.15 seconds */
  195.                 break;
  196.             case daveProtoMPI_IBH:
  197.                 di->exchange=_daveExchangeIBH;
  198.                 di->connectPLC=_daveConnectPLC_IBH;
  199.                 di->disconnectPLC=_daveDisconnectPLC_IBH;
  200.                 di->sendMessage=_daveSendMessageMPI_IBH;
  201.                 di->getResponse=_daveGetResponseMPI_IBH;
  202.                 di->listReachablePartners=_daveListReachablePartnersMPI_IBH;
  203.                 break;
  204.             case daveProtoPPI_IBH:
  205.                 di->exchange=_daveExchangePPI_IBH;
  206.                 di->connectPLC=_daveConnectPLCPPI;
  207.                 di->sendMessage=_daveSendMessageMPI_IBH;
  208.                 di->getResponse=_daveGetResponsePPI_IBH;
  209.                 di->listReachablePartners=_daveListReachablePartnersMPI_IBH;
  210.                 break;
  211.             case daveProtoS7online:
  212.                 di->exchange=_daveExchangeS7online;
  213.                 di->connectPLC=_daveConnectPLCS7online;
  214.                 di->sendMessage=_daveSendMessageS7online;
  215.                 di->getResponse=_daveGetResponseS7online;
  216.                 di->listReachablePartners=_daveListReachablePartnersS7online;
  217.                 di->disconnectPLC=_daveDisconnectPLCS7online;
  218. //                di->disconnectAdapter=_daveDisconnectAdapterS7online;
  219.                 break;
  220.             case daveProtoAS511:
  221.                 di->connectPLC=_daveConnectPLCAS511;
  222.                 di->disconnectPLC=_daveDisconnectPLCAS511;
  223.                 di->exchange=_daveFakeExchangeAS511;
  224.                 di->sendMessage=_daveFakeExchangeAS511;
  225.                 break;
  226.             case daveProtoNLpro:
  227.                 di->initAdapter=_daveInitAdapterNLpro;
  228.                 di->connectPLC=_daveConnectPLCNLpro;
  229.                 di->disconnectPLC=_daveDisconnectPLCNLpro;
  230.                 di->disconnectAdapter=_daveDisconnectAdapterNLpro;
  231.                 di->exchange=_daveExchangeNLpro;
  232.                 di->sendMessage=_daveSendMessageNLpro;
  233.                 di->getResponse=_daveGetResponseNLpro;
  234.                 di->listReachablePartners=_daveListReachablePartnersNLpro;
  235.                 break;
  236.
  237.         }
  238. #ifdef BCCWIN
  239.         setTimeOut(di, di->timeout);
  240. #endif
  241.     }
  242.     return di;
  243. }
  244. daveInterface * DECL2 davePascalNewInterface(_daveOSserialType* nfd, char * nname, int localMPI, int protocol, int speed){
  245. #ifdef DEBUG_CALLS
  246.     LOG7("davePascalNewInterface(fd.rfd:%d fd.wfd:%d name:%s local MPI:%d protocol:%d PB speed:%d)\n",
  247.         nfd->rfd,nfd->wfd,nname, localMPI, protocol, speed);
  248.     FLUSH;
  249. #endif
  250.     return daveNewInterface(*nfd,nname, localMPI, protocol, speed);
  251. }
  252. /*
  253.     debugging:
  254.     set debug level by setting variable daveDebug. Debugging is split into
  255.     several topics. Output goes to stderr.
  256.     The file descriptor is written after the module name, so you may
  257.     distinguish messages from multiple connections.
  258.
  259.     naming: all stuff begins with dave... to avoid conflicts with other
  260.     namespaces. Things beginning with _dave.. are not intended for
  261.     public use.
  262. */
  263. void DECL2 daveSetDebug(int nDebug) {
  264. #ifdef DEBUG_CALLS
  265.     LOG2("daveSetDebug(%d)\n",nDebug);
  266.     FLUSH;
  267. #endif
  268.     daveDebug=nDebug;
  269. }
  270. int DECL2 daveGetDebug() {
  271. #ifdef DEBUG_CALLS
  272.     LOG1("daveGetDebug()\n");
  273.     FLUSH;
  274. #endif
  275.     return daveDebug;
  276. }
  277. /**
  278.     C# interoperability:
  279. **/
  280. void DECL2 daveSetTimeout(daveInterface * di, int tmo) {
  281. #ifdef DEBUG_CALLS
  282.     LOG3("daveSetTimeOut(di:%p, time:%d)\n",        di,tmo);
  283. #endif
  284.     di->timeout=tmo;
  285. #ifdef BCCWIN
  286.     setTimeOut(di,tmo);
  287. #endif
  288. }
  289. int DECL2 daveGetTimeout(daveInterface * di) {
  290. #ifdef DEBUG_CALLS
  291.     LOG2("daveGetTimeOut(di:%p)\n",di);
  292.     FLUSH;
  293. #endif
  294.     return di->timeout;
  295. }
  296. char * DECL2 daveGetName(daveInterface * di) {
  297. #ifdef DEBUG_CALLS
  298.     LOG2("daveGetName(di:%p)\n",di);
  299.     FLUSH;
  300. #endif
  301.     return di->name;
  302. }
  303. int DECL2 daveGetMPIAdr(daveConnection * dc) {
  304. #ifdef DEBUG_CALLS
  305.     LOG2("daveGetMPIAdr(dc:%p)\n",dc);
  306.     FLUSH;
  307. #endif
  308.     return dc->MPIAdr;
  309. }
  310. int DECL2 daveGetAnswLen(daveConnection * dc) {
  311. #ifdef DEBUG_CALLS
  312.     LOG2("daveGetAnswLen(dc:%p)\n",dc);
  313.     FLUSH;
  314. #endif
  315.     return dc->AnswLen;
  316. }
  317. int DECL2 daveGetMaxPDULen(daveConnection * dc) {
  318. #ifdef DEBUG_CALLS
  319.     LOG2("daveGetMaxPDULen(dc:%p)\n",dc);
  320.     FLUSH;
  321. #endif
  322.     return dc->maxPDUlength;
  323. }
  324. /**
  325.     PDU handling:
  326. **/
  327. /*
  328.     set up the header. Needs valid header pointer
  329. */
  330. void DECL2 _daveInitPDUheader(PDU * p, int type) {
  331.     memset(p->header, 0, sizeof(PDUHeader));
  332.     if (type==2 || type==3)
  333.         p->hlen=12;
  334.     else
  335.         p->hlen=10;
  336.     p->param=p->header+p->hlen;
  337.     ((PDUHeader*)p->header)->P=0x32;
  338.     ((PDUHeader*)p->header)->type=type;
  339.     p->dlen=0;
  340.     p->plen=0;
  341.     p->udlen=0;
  342.     p->data=NULL;
  343.     p->udata=NULL;
  344. }
  345. /*
  346.     add parameters after header, adjust pointer to data.
  347.     needs valid header
  348. */
  349. void DECL2 _daveAddParam(PDU * p,uc * param,us len) {
  350. #ifdef DEBUG_CALLS
  351.     LOG4("_daveAddParam(PDU:%p, param %p, len:%d)\n", p, param, len);
  352.     FLUSH;
  353. #endif
  354.     p->plen=len;
  355. #ifdef DAVE_HAVE_MEMCPY
  356.     memcpy(p->param, param, len);
  357. #else
  358.     int i;
  359.     for (i=0;i<len;i++) p->param[i]=param[i];
  360. #endif
  361.     ((PDUHeader2*)p->header)->plenHi=len/256;
  362.     ((PDUHeader2*)p->header)->plenLo=len%256;
  363. //    ((PDUHeader*)p->header)->plen=daveSwapIed_16(len);
  364.     p->data=p->param+len;
  365.     p->dlen=0;
  366. }
  367. /*
  368.     add data after parameters, set dlen
  369.     needs valid header,parameters
  370. */
  371. void DECL2 _daveAddData(PDU * p,void * data,int len) {
  372. #ifdef DEBUG_CALLS
  373.     LOG4("_daveAddData(PDU:%p, data %p, len:%d)\n", p, data, len);
  374. //    _daveDumpPDU(p);
  375.     FLUSH;
  376. #endif
  377.     uc * dn= p->data+p->dlen;
  378.     p->dlen+=len;
  379. #ifdef DAVE_HAVE_MEMCPY
  380.     memcpy(dn, data, len);
  381. #else
  382.     int i; uc * d=(uc*)data;
  383.     for (i=0;i<len;i++) p->data[p->dlen+i]=d[i];
  384. #endif
  385.     ((PDUHeader2*)p->header)->dlenHi=p->dlen/256;
  386.     ((PDUHeader2*)p->header)->dlenLo=p->dlen%256;
  387. //    ((PDUHeader*)p->header)->dlen=daveSwapIed_16(p->dlen);
  388. }
  389. /*
  390.     add values after value header in data, adjust dlen and data count.
  391.     needs valid header,parameters,data,dlen
  392. */
  393. void DECL2 _daveAddValue(PDU * p,void * data,int len) {
  394.     us dCount;
  395.     uc * dtype;
  396. #ifdef DEBUG_CALLS
  397.     LOG4("_daveAddValue(PDU:%p, data %p, len:%d)\n", p, data, len);
  398.     _daveDumpPDU(p);
  399.     FLUSH;
  400. #endif
  401.     dtype=p->data+p->dlen-4+1;                        /* position of first byte in the 4 byte sequence */
  402.     dCount= p->data[p->dlen-4+2+1];
  403.     dCount+= 256*p->data[p->dlen-4+2];
  404.
  405.     if (daveDebug & daveDebugPDU)
  406.         LOG2("dCount: %d\n", dCount);
  407.     if (*dtype==4) {        /* bit data, length is in bits */
  408.         dCount+=8*len;
  409.     } else if (*dtype==9) {        /* byte data, length is in bytes */
  410.         dCount+=len;
  411.     } else if (* dtype==3) {        /* bit data, length is in bits */
  412.         dCount+=len;
  413.     } else {
  414.         if (daveDebug & daveDebugPDU)
  415.             LOG2("unknown data type/length: %d\n", *dtype);
  416.     }
  417.     if (p->udata==NULL) p->udata=p->data+4;
  418.     p->udlen+=len;
  419. …………
  420. …………
  421. …………限于本文篇幅 余下代码请从51黑下载附件…………
libnodave-0.8.5.rar (3.26 MB, 下载次数: 11)
ID:394669 发表于 2018-9-6 18:04 | 显示全部楼层
自己顶
