查看: 2435|回复: 2
求助,请问为什么我的计时器数码管没起作用
ID:393625 发表于 2018-9-25 08:49 | 显示全部楼层 |阅读模式
就正常是一天加一,现在是只能通过按键加一。
#include <REGX51.H>
#include<intrins.h>  //包含_nop_();定义的头文件
#include<LS595driver.h>
#include<LS595_2driver.h>
#include<ds1302driver.h>
SYSTEMTIME today;                  //2018.1.2 12:00:00 2
unsigned int T0loop;          //记录进入T0的次数
unsigned int flag;        //约10秒1次,
unsigned int countupday; //记录正计时天数的参数
unsigned char olddaytemp,newdaytemp;  //用来比较是否已经过一天
unsigned char keyvalue;//记录按键扫描函数的返回值
//unsigned int test[10]={0,111,222,333,444,555,666,777,888,999}; //记录倒计时天数的参数
unsigned char i;
sbit key1 = P1^0;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit LEDr=P1^3;
sbit LEDg=P1^4;
sbit LEDy=P1^5;
void Init_89C52();       //初始化89C52
void InitT0();
char Keyscan();         //按键扫描并返回键值
void Setcountupday();   //按键设置正计时天数
  Init_89C52();
  Delay_ms(1000);
  countupday = 1;
  LEDr = 1;
  LEDg = 1;
  LEDy = 1;
  Init_1302();  //初始化时钟
  InitT0();     //初始化T0定时器
  Displayround();
   Displaysecond_595(&today);
   Displayday_595(&today);
   Displayhour_595(&today);
   Displayminute_595(&today);
   Setcountupday(unsigned int chu=888);
   Displaycountupnum(countupday);
   if(flag==1)
     flag = 0;
         if(olddaytemp=!newdaytemp)
           countupday++;
//Time0中断函数
//功能:定时出10秒/50毫秒=200个循环
//参数:无
void Time0(void) interrupt 1 using 1
  TR0 = 0;
  T0loop++;
  if(T0loop==200)
    Gettime_1302(&today);
        olddaytemp = today.day;
  if(T0loop==400)
        newdaytemp = today.day;
        flag = 1;
        T0loop = 0;
  TH0 = (65536-46083)/256;                                  //重新给T0赋初始值
  TL0 = (65536-46083)%256;                                  //
  TR0 = 1;                                //启动T0
//Time0中断函数
//功能:每8秒进入中断,执行开门或关门操作,并重设Time0
//参数:无
void InitT0()
  TMOD=0x01;    //使用定时器T0,11.0592MHz晶振的12分频,16位定时器65536-1
  TH0 =(65536-46083)/256;  //将定时器计时时间设定为46083*1.085微秒=50000微秒=50毫秒
  TL0 =(65536-46083)%256;  //
  EA  = 1;       //开启总中断
  ET0 = 1;       //T0中断允许
  TR0 = 1;       //启动定时器T0
  T0loop = 0;                          //记录进入T0的次数
  flag = 0;         //10秒一个周期
/*89C52初始化*/
void Init_89C52()
  P0 = 0;
  P1 = 1;
  P2 = 0;
  T0loop = 0;
/*按键扫描函数*/
char Keyscan()
  if(key1==0)
    Delay_ms(200);
        if(key1==0)
          return 1;
  if(key2==1)
    Delay_ms(200);
        if(key2==1)
          return 2;
  if(key3==1)
    Delay_ms(200);
        if(key3==1)
          return 2;
    return 0;
/*按键调整函数*/
  switch(Keyscan())
    case 1:
        countupday++;
        break;
        case 2:
        countupday--;
        break;
        default:
        break;
头文件595
/*                     第二组级联74LS595_2数码管驱动程序         */
#ifndef _LS595_2driver_H_
#define _LS595_2driver_H_
sbit RCK_595_2 = P0^4;        //第二组级联595的并行输出时钟
sbit DS_595_2 = P0^3;         //第二组级联595数据线
sbit CLK_595_2 = P0^5;        //第二组级联595移位输入时钟
unsigned char code countupseg[] =        //第二组595中定义0~9,高亮低灭
{// 0         1          2           3        4         5          6           7        8         9
        0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
unsigned char code roundseg[6]={0x01,0x02,0x04,0x08,0x10,0x20}; //花式旋转
/*延时函数  1ms为单位*/
void Delay_ms(unsigned int t)           //延时函数,t/ms
  unsigned int a,b;
  for(a=0;a<t;a++)
    for(b=0;b<100;b++)
       _nop_();
/* 向1个LS595_2写入1个字节*/
void Send1byte_595_2(unsigned char dat)
  unsigned char i;
  for(i=0;i<8;i++)
        if(dat&0x80)
        DS_595_2 = 1;
        DS_595_2 = 0;
        dat <<=1;
        CLK_595_2 = 0;
        _nop_();
        CLK_595_2 = 1;
/* 向3个级联LS595_2写入3个字节*/
void Send3byte_595_2(unsigned char dat1,unsigned char dat2,unsigned char dat3)
  Send1byte_595_2(dat1);
  Send1byte_595_2(dat2);
  Send1byte_595_2(dat3);
/*允许将LS595输出并行数据*/
void Out_595_2()
  RCK_595_2 = 0;
  _nop_();
  RCK_595_2 = 1;
/*显示倒计时 3位*/
void Displaycountupnum(unsigned int num)
  unsigned int units,tens,hundreds;
  units = num%10;
  tens = (num/10)%10;
  hundreds = num/100;
  Send3byte_595_2(countupseg[hundreds],countupseg[tens],countupseg[units]);        //显示倒计时的个、十、百位
  Out_595_2();
/*大字花式转圈*/
void Displayround()
  unsigned char j;
  for(j=0;j<5;j++)
    Send3byte_595_2(roundseg[j],roundseg[j],roundseg[j]);
        Out_595_2();
        Delay_ms(800);
#endif
ID:111634 发表于 2018-9-27 18:02 | 显示全部楼层
这种电路图最难看,是给软件看的,真正的电路图应该是有明确连接线路的原理图。
ID:387733 发表于 2018-9-28 07:27 | 显示全部楼层
是的,都这样画图,以后都不需要 连接线 的功能了。原理图绘制也需要好的布局,元器件放置合理,这样走线清晰明了,便于别人审图,也方便自己修改维护。
