Symbolism-master C#源程序如下:
- using System;
- using System.Collections.Generic;
- using System.Linq;
- using System.Text;
- using Symbolism.Has;
- using Symbolism.Trigonometric;
- using Symbolism.CoefficientGpe;
- using Symbolism.AlgebraicExpand;
- using Symbolism.DegreeGpe;
- namespace Symbolism.IsolateVariable
- public static class Extensions
- public static MathObject IsolateVariableEq(this Equation eq, Symbol sym)
- if (eq.Operator == Equation.Operators.NotEqual) return eq;
- if (eq.FreeOf(sym)) return eq;
- // sin(x) / cos(x) == y -> tan(x) == y
- if (eq.a is Product && (eq.a as Product).elts.Any(elt => elt == new Sin(sym)) &&
- eq.a is Product && (eq.a as Product).elts.Any(elt => elt == 1 / new Cos(sym)))
- return
- (eq.a / new Sin(sym) * new Cos(sym) * new Tan(sym) == eq.b).IsolateVariableEq(sym);
- // A sin(x)^2 == B sin(x) cos(x) -> A sin(x)^2 / (B sin(x) cos(x)) == 1
- if (
- (eq.a as Product).elts.Any(elt =>
- (elt == new Sin(sym)) ||
- ((elt is Power) && (elt as Power).bas == new Sin(sym) && (elt as Power).exp is Number)) &&
- eq.b is Product &&
- (eq.b as Product).elts.Any(elt =>
- return
- (eq.a / eq.b == 1).IsolateVariableEq(sym);
- if (eq.b.Has(sym)) return IsolateVariableEq(new Equation(eq.a - eq.b, 0), sym);
- if (eq.a == sym) return eq;
- // (a x^2 + c) / x == - b
- elt =>
- elt is Power &&
- (elt as Power).bas == sym &&
- (elt as Power).exp == -1))
- return IsolateVariableEq(eq.a * sym == eq.b * sym, sym);
- //if (eq.a is Product &&
- // (eq.a as Product).elts.Any(
- // elt =>
- // elt is Power &&
- // (elt as Power).bas == sym &&
- // (elt as Power).exp is Integer &&
- // ((elt as Power).exp as Integer).val < 0))
- // return IsolateVariableEq(eq.a * sym == eq.b * sym, sym);
- // if (eq.a.Denominator() is Product &&
- // (eq.a.Denominator() as Product).Any(elt => elt.Base() == sym)
- // (x + y)^(1/2) == z
- // x == -y + z^2 && z >= 0
- if (eq.a is Power && (eq.a as Power).exp == new Integer(1) / 2)
- return IsolateVariableEq((eq.a ^ 2) == (eq.b ^ 2), sym);
- // 1 / sqrt(x) == y
- if (eq.a is Power && (eq.a as Power).exp == -new Integer(1) / 2)
- return (eq.a / eq.a == eq.b / eq.a).IsolateVariable(sym);
- // x ^ 2 == y
- // x ^ 2 - y == 0
- if (eq.a.AlgebraicExpand().DegreeGpe(new List<MathObject>() { sym }) == 2 &&
- eq.b != 0)
- return
- (eq.a - eq.b == 0).IsolateVariable(sym);
- // a x^2 + b x + c == 0
- if (eq.a.AlgebraicExpand().DegreeGpe(new List<MathObject>() { sym }) == 2)
- var a = eq.a.AlgebraicExpand().CoefficientGpe(sym, 2);
- var b = eq.a.AlgebraicExpand().CoefficientGpe(sym, 1);
- var c = eq.a.AlgebraicExpand().CoefficientGpe(sym, 0);
- if (a == null || b == null || c == null) return eq;
- return new Or(
- new And(
- sym == (-b + (((b ^ 2) - 4 * a * c) ^ (new Integer(1) / 2))) / (2 * a),
- (a != 0).Simplify()
- ).Simplify(),
- new And(
- sym == (-b - (((b ^ 2) - 4 * a * c) ^ (new Integer(1) / 2))) / (2 * a),
- ).Simplify(),
- new And(sym == -c / b, a == 0, (b != 0).Simplify()).Simplify(),
- new And(
- (a == 0).Simplify(),
- (b == 0).Simplify(),
- (c == 0).Simplify()
- ).Simplify()
- ).Simplify();
- // (x + y == z).IsolateVariable(x)
- if (eq.a is Sum && (eq.a as Sum).elts.Any(elt => elt.FreeOf(sym)))
- var items = ((Sum)eq.a).elts.FindAll(elt => elt.FreeOf(sym));
- //return IsolateVariable(
- // new Equation(
- // eq.a - new Sum() { elts = items }.Simplify(),
- // eq.b - new Sum() { elts = items }.Simplify()),
- // sym);
- //var new_a = eq.a; items.ForEach(elt => new_a = new_a - elt);
- //var new_b = eq.b; items.ForEach(elt => new_b = new_b - elt);
- var new_a = new Sum() { elts = (eq.a as Sum).elts.Where(elt => items.Contains(elt) == false).ToList() }.Simplify();
- var new_b = eq.b; items.ForEach(elt => new_b = new_b - elt);
- // (new_a as Sum).Where(elt => items.Contains(elt) == false)
- return IsolateVariableEq(new Equation(new_a, new_b), sym);
- // new Equation(
- // eq.a + new Sum() { elts = items.ConvertAll(elt => elt * -1) }.Simplify(),
- // sym);
- // a b + a c == d
- // a + a c == d
- if (eq.a is Sum && (eq.a as Sum).elts.All(elt => elt.DegreeGpe(new List<MathObject>() { sym }) == 1))
- //return
- // (new Sum() { elts = (eq.a as Sum).elts.Select(elt => elt / sym).ToList() }.Simplify() == eq.b / sym)
- // .IsolateVariable(sym);
- return
- (sym * new Sum() { elts = (eq.a as Sum).elts.Select(elt => elt / sym).ToList() }.Simplify() == eq.b)
- .IsolateVariable(sym);
- // -sqrt(x) + z * x == y
- if (eq.a is Sum && eq.a.Has(sym ^ (new Integer(1) / 2))) return eq;
- // sqrt(a + x) - z * x == -y
- if (eq.a is Sum && eq.a.Has(elt => elt is Power && (elt as Power).exp == new Integer(1) / 2 && (elt as Power).bas.Has(sym)))
- return eq;
- if (eq.a is Sum && eq.AlgebraicExpand().Equals(eq)) return eq;
- if (eq.a is Sum) return eq.AlgebraicExpand().IsolateVariable(sym);
- // (x + 1) / (x + 2) == 3
- if (eq.a.Numerator().Has(sym) && eq.a.Denominator().Has(sym))
- return IsolateVariableEq(eq.a * eq.a.Denominator() == eq.b * eq.a.Denominator(), sym);
- // sqrt(2 + x) * sqrt(3 + x) == y
- if (eq.a is Product && (eq.a as Product).elts.All(elt => elt.Has(sym))) return eq;
- if (eq.a is Product)
- var items = ((Product)eq.a).elts.FindAll(elt => elt.FreeOf(sym));
- new Equation(
- eq.a / new Product() { elts = items }.Simplify(),
- eq.b / new Product() { elts = items }.Simplify()),
- sym);
- // x ^ -2 == y
- (eq.a as Power).bas == sym &&
- (eq.a as Power).exp is Integer &&
- ((eq.a as Power).exp as Integer).val < 0)
- return (eq.a / eq.a == eq.b / eq.a).IsolateVariableEq(sym);
- if (eq.a is Power) return eq;
- // sin(x) == y
- // Or(x == asin(y), x == Pi - asin(y))
- if (eq.a is Sin)
- return
- new Or(
- (eq.a as Sin).args[0] == new Asin(eq.b),
- (eq.a as Sin).args[0] == new Symbol("Pi") - new Asin(eq.b))
- // tan(x) == y
- // x == atan(t)
Symbolism-master.zip
(62.31 KB, 下载次数: 4)
