断断续续自学了一个月,在学长给的模板下简单写了一个小车寻迹
花了一个星期写的
附件里有源码、原理图等
原创
电路原理图如下:
- #include "stm32f10x.h"
- #include "delay.h"
- #include "key.h"
- #include "motor.h"
- #include "usart.h"
- #include "timer.h"
- #include "led.h"
- extern u8 state;
- u16 MOTOR_L_SPEED,MOTOR_R_SPEED;
- int main(void)
- //系统时钟初始化
- SystemInit();
- delay_init();
- //光电传感器引脚初始化
- LED_Init();
- TIM3_Int_Init(); //定时检测光电传感器的状态
- //电机初始化
- Motor_Init();
- MotorDriver_L_Turn_Forward();
- MotorDriver_R_Turn_Forward();
- TIM_SetCompare3(TIM4,0); //控制右电机速度
- TIM_SetCompare4(TIM4,0); //控制左电机速度
- //蜂鸣器停止鸣叫 表示初始化完成
- Beep_Led_Init();
- Sys_OK_Sound();
- while(1)
- switch (state)
- //直行 D1 D2 D3 D4
- case 0: //0 0 0 0
- case 6: //0 1 1 0
- case 15: //1 1 1 1
- MOTOR_R_SPEED=MOTOR_SPEED_BASE;
- MOTOR_L_SPEED=MOTOR_SPEED_BASE;
- break;
- //右转
- case 2: //0 0 1 0
- MOTOR_L_SPEED=MOTOR_SPEED_BASE+MOTOR_SPEED_PLUS;
- break;
- case 3: //0 0 1 1
- MOTOR_R_SPEED=MOTOR_SPEED_BASE-2*MOTOR_SPEED_PLUS;
- break;
- case 1: //0 0 0 1
- MOTOR_R_SPEED=MOTOR_SPEED_BASE-4*MOTOR_SPEED_PLUS;
- MOTOR_L_SPEED=MOTOR_SPEED_BASE+2*MOTOR_SPEED_PLUS;
- break;
- //左转
- case 4: //0 1 0 0
- MOTOR_R_SPEED=MOTOR_SPEED_BASE+MOTOR_SPEED_PLUS;
- break;
- case 12: //1 1 0 0
- MOTOR_L_SPEED=MOTOR_SPEED_BASE-2*MOTOR_SPEED_PLUS;
- break;
- case 8: //1 0 0 0
- MOTOR_R_SPEED=MOTOR_SPEED_BASE+2*MOTOR_SPEED_PLUS;
- MOTOR_L_SPEED=MOTOR_SPEED_BASE-4*MOTOR_SPEED_PLUS;
- break;
- default: ;
- TIM_SetCompare3(TIM4,MOTOR_R_SPEED); //控制右电机速度
- TIM_SetCompare4(TIM4,MOTOR_L_SPEED); //控制左电机速度
复制代码- #include "motor.h"
- #define MOTOR_R_IN1_LOW (GPIO_ResetBits(GPIOC, GPIO_Pin_0))
- #define MOTOR_R_IN1_HIGH (GPIO_SetBits(GPIOC, GPIO_Pin_0))
- #define MOTOR_R_IN2_LOW (GPIO_ResetBits(GPIOC, GPIO_Pin_1))
- #define MOTOR_R_IN2_HIGH (GPIO_SetBits(GPIOC, GPIO_Pin_1))
- #define MOTOR_L_IN1_LOW (GPIO_ResetBits(GPIOC, GPIO_Pin_2))
- #define MOTOR_L_IN1_HIGH (GPIO_SetBits(GPIOC, GPIO_Pin_2))
- #define MOTOR_L_IN2_LOW (GPIO_ResetBits(GPIOC, GPIO_Pin_3))
- #define MOTOR_L_IN2_HIGH (GPIO_SetBits(GPIOC, GPIO_Pin_3))
- //PWM输出初始化
- //arr:自动重装值
- //psc:时钟预分频数
- void Motor_Init(void)
- GPIO_InitTypeDef GPIO_InitStructure;
- TIM_TimeBaseInitTypeDef TIM_TimeBaseStructure;
- TIM_OCInitTypeDef TIM_OCInitStructure;
- RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM4, ENABLE);//
- RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC, ENABLE); //使能GPIO外设时钟使能
- //设置该引脚为复用输出功能,输出TIM4 CH3/4的PWM脉冲波形
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9 ; //TIM4_CH3 TIM4_CH4
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP; //复用推挽输出
- GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
- GPIO_Init(GPIOB, &GPIO_InitStructure);
- TIM_TimeBaseStructure.TIM_Period = 10000; //设置在下一个更新事件装入活动的自动重装载寄存器周期的值 80K
- TIM_TimeBaseStructure.TIM_Prescaler =72; //设置用来作为TIMx时钟频率除数的预分频值 不分频
- TIM_TimeBaseStructure.TIM_ClockDivision =0; //设置时钟分割:TDTS = Tck_tim
- TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up; //TIM向上计数模式
- TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure); //根据TIM_TimeBaseInitStruct中指定的参数初始化TIMx的时间基数单位
- TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1; //选择定时器模式:TIM脉冲宽度调制模式2
- TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
- TIM_OCInitStructure.TIM_Pulse = 0;
- TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
- TIM_OC3Init(TIM4, &TIM_OCInitStructure);
- TIM_OCInitStructure.TIM_OutputState =TIM_OutputState_Enable; //比较输出使能
- TIM_OCInitStructure.TIM_Pulse = 0; //设置待装入捕获比较寄存器的脉冲值
- TIM_OC4Init(TIM4, &TIM_OCInitStructure); //输出极性:TIM输出比较极性高
- TIM_OC4PreloadConfig(TIM4, TIM_OCPreload_Enable); //根据TIM_OCInitStruct中指定的参数初始化外设TIMx
- TIM_CtrlPWMOutputs(TIM4,ENABLE); //MOE 主输出使能
- TIM_ARRPreloadConfig(TIM4, ENABLE); //使能TIMx在ARR上的预装载寄存器
- TIM_Cmd(TIM4, ENABLE); //使能TIM4
- /*初始化PC端口为Out_PP模式*/
- GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
- GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
- GPIO_Init(GPIOC, &GPIO_InitStructure);
- * @brief 左轮电机正转
- * @param none
- * @retval none
- void MotorDriver_L_Turn_Forward(void)
- MOTOR_L_IN1_LOW;
- MOTOR_L_IN2_HIGH;
- * @brief 左轮电机反转
- * @param none
- * @retval none
- void MotorDriver_L_Turn_Reverse(void)
- MOTOR_L_IN1_HIGH;
- MOTOR_L_IN2_LOW;
- * @brief 右轮电机正转
- * @param none
- * @retval none
- void MotorDriver_R_Turn_Forward(void)
- MOTOR_R_IN1_HIGH;
- MOTOR_R_IN2_LOW;
- * @brief 右轮电机反转
- * @param none
- * @retval none
- void MotorDriver_R_Turn_Reverse(void)
- MOTOR_R_IN1_LOW;
- MOTOR_R_IN2_HIGH;
寻迹.rar
(286.68 KB, 下载次数: 132)
