电子密码锁仿真原理图如下(proteus仿真工程文件可到本帖附件中下载)
- //原始程序中相邻两位密码不能相同.
- //本压缩包中的HEX由修改后的新程序编译生成,允许输入任意密码.
- //改动的主要是main函数中while循环内的代码.
- // 主程序
- void main()
- uchar i = 0;
- uchar IIC_Password[10];
- uchar IS_Valid_User = 0;
- P0 = 0xFF;
- P1 = 0xFF;
- P2 = 0xFF;
- TMOD = 0x02; //T0设置为8位自动重装模式
- TH0 = 175;
- TL0 = 175;
- TR0 = 1; //启动T0
- DelayMS(10);
- LCD_Init(); //初始化LCD
- IIC_24C04_Init(); //初始化24C04
- Display_String(Title_Text,0x00); //在第1行显示标题
- //24C04的内容已由初始化BIN文件导入
- //将24C04中预先写入的密码读入pass
- RecString(0xa0, 0 , IIC_Password, 6);
- IIC_Password[6] = '\0';
- while(1)
- P1 = 0xF0;
- if(P1 != 0xF0) KeyNo = Keys_Scan(); //扫描键盘获取键序号KeyNo
- switch ( KeyNo )
- case 0: case 1: case 2: case 3: case 4:
- case 5: case 6: case 7: case 8: case 9:
- if ( i<= 5 ) //密码限制在6位以内
- //如果i为0则执行一次清屏
- if (i ==0) Display_String(" ",0x40);
- UserPassword[i] = KeyNo + '0';
- UserPassword[i+1] = '\0';
- DSY_BUFFER[i] = '*';
- DSY_BUFFER[i+1] = '\0';
- Display_String(DSY_BUFFER,0x40);
- i++;
- break;
- case 10: //按A键开锁
- if (strcmp(UserPassword,IIC_Password) == 0)
- LED_OPEN = 0; //点亮LED
- Clear_Password();
- Display_String("Unlock OK! ",0x40);
- IS_Valid_User = 1;
- else
- LED_OPEN =1; //关闭LED
- Clear_Password();
- Display_String("ERROR ! ",0x40);
- IS_Valid_User = 0;
- i = 0;
- break;
- case 11: //按B键上锁
- LED_OPEN =1;
- Clear_Password();
- Display_String(" ",0x40);
- i = 0;
- break;
- case 12: //按C键设置新密码
- //如果是合法用户则提示输入新密码
- if ( !IS_Valid_User ) Display_String("No rights !",0x40);
- else
- i = 0;
- Display_String("New Password: ",0x00);
- break;
- case 13: //按D键保存新密码
- else
- SendString(0xa0, 0 , UserPassword, 6);
- //重新读入刚写的密码
- i = 0;
- Display_String("Password Saved! ",0x40);
- break;
- case 14: //按E键消除所有输入
- i = 0;
- Clear_Password();
- Beep();
- DelayMS(100);
- P1= 0xF0;
- while (P1 != 0xF0); //如果有键未释放则等待
- while (P1 == 0xF0); //如果没有再次按下按键则等待
34 用24C04与1602LCD设计电子密码锁.rar
(24.48 KB, 下载次数: 100)
