查看: 4868|回复: 5
一款高性能avr单片机频率计程序 10khz
ID:21069 发表于 2018-12-18 04:22 | 显示全部楼层 |阅读模式
  1. #include <iom16v.h>
  3. #define uint unsigned int
  4. const uchar SEG_CODE[] =
  5. {0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x00};
  6. int main()
  7. {
  8.         uchar  LastKey = 0xff;
  9.
  10.         DDRA = 0xff;
  11.
  12.         DDRB = 0xff;
  13.
  14.         DDRC = 0xff;   PORTC = 0xff;
  15.
  16.         DDRD = 0x00;   PORTD = 0xff;
  17.
  18.         TCCR1B = BIT(ICNC1) | BIT(ICES1);
  19.
  20.         sei();
  21.
  22.         while(1)
  23.
  24.         {
  25.
  26.                 if( LastKey != PINC)
  27.
  28.                 {
  29.                         TIMSK = BIT(TICIE1);
  30.
  31.                         TCCR1B |= 0x01;
  32.
  33.                         LastKey = PINC;
  34.
  35.                 }
  36.
  37.                 Show_FRQ_ON_DSY();
  38.
  39.         }
  40. }
  41. ISR (TIMER1_CAPT_vect)
  42. {
  43.
  44.         uchar  i;
  45.
  46.         if(CAPi == 0)CAPi = ICR1;
  47.
  48.         else
  49.
  50.         {
  51.                 CAPj = ICR1 - CAPi;
  52.
  53.                 CAPj = 1000000/CAPj;
  54.
  55.                 TIMSK = 0;
  56.
  57.                 TCCR1B &= 0xfc;
  58.
  59.                 for(i = 3;i != 0xff;i--)
  60.
  61.                 {
  62.
  63.                         Display_Buffer[i] = CAPj % 10;
  64.
  65.                         CAPj /= 10;
  66.
  67.                 }
  68.
  69.                 TCNT1 = CAPi = CAPj =0;
  70.
  71.         }
  72.
  73. }
参与人数 3黑币 +73 收起 理由
站着说话不腰疼 + 8
shuisheng + 15
ID:1 发表于 2018-12-18 15:46 | 显示全部楼层
仿真工程能分享下吗?
ID:21069 发表于 2018-12-18 16:07 | 显示全部楼层
传上了
一款高性能avr单片机频率计程序.zip (17.83 KB, 下载次数: 30)
ID:472242 发表于 2019-2-3 21:12 | 显示全部楼层
好东东,谢谢分享!
ID:472268 发表于 2019-2-7 00:34 | 显示全部楼层
很好的东东咯
ID:102963 发表于 2019-2-25 20:02 | 显示全部楼层
程序怎么编译不了呢??
