程序代码
#include<reg51.h>
#include"st7565.h"
//---存一个图片--//
unsigned char code pic[]={
/*-- 宽度x高度=128x64 --*/
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,
0x57,0x53,0x57,0x07,0xFF,0x0F,0xE3,0x0F,0xEF,0xFF,0xEF,0xEF,0xEF,0x03,0xEF,0xEF,
0xEF,0x0F,0xE3,0x0F,0xEF,0xFF,0x77,0x77,0x17,0x57,0x57,0x53,0x57,0x57,0x17,0x77,
0x77,0xFF,0xFB,0x8B,0xAB,0x83,0xAB,0x83,0xAB,0x8B,0xFF,0x37,0xDB,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xF5,
0xFB,0xF4,0xEF,0xE0,0xFF,0xF4,0xFB,0xF4,0xEF,0xFF,0xE0,0xEE,0xEE,0xEE,0xEE,0xE0,
0xFF,0xF4,0xFB,0xF5,0xEC,0xFF,0xE2,0xEF,0xEF,0xE1,0xFD,0xFD,0xFD,0xF9,0xF7,0xEF,
0xEE,0xFF,0xEB,0xF2,0xFA,0xE2,0xEA,0xFA,0xF2,0xEB,0xFF,0xE0,0xFD,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xE3,0x81,0x81,0xE3,0xFF,0xFF,0xDF,0xDD,0xD5,0x4D,0x9D,0x00,
0x9D,0x4D,0xD5,0xDD,0xDF,0xFF,0xFB,0xFB,0x00,0xFB,0xFB,0x9B,0xEB,0xFB,0x0F,0xE9,
0xEE,0xFF,0xEF,0xEE,0x2A,0xAA,0xAA,0xA8,0xA2,0x0A,0xAA,0x6E,0xEF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFE,0xFF,0x7F,0x78,
0x7F,0x7F,0xFE,0x7D,0x7D,0xBF,0xBB,0xBB,0xBA,0xBA,0x3A,0xBB,0xBB,0xBD,0xBE,0x7D,
0x7B,0xBF,0xBF,0xBF,0x78,0xFA,0xFA,0xFA,0xFA,0xF8,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x87,0xF8,0xFF,0xFF,
0xFF,0x7F,0x7E,0xBD,0xCF,0x73,0xBF,0xDB,0xDD,0xBD,0x7B,0xFE,0x7F,0xBB,0xDD,0xDD,
0xBB,0x7F,0xE7,0x9F,0x5F,0xBE,0x7D,0x73,0xEF,0x9F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFD,0x0D,0xF2,0xFC,
0xFE,0xFF,0xFF,0xEF,0x1F,0x3E,0xDC,0xE8,0xEB,0xED,0xDE,0xD7,0xD6,0xD4,0x68,0x6B,
0xED,0xF6,0xF7,0xEF,0x1F,0xFE,0xFD,0xF3,0x0E,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xC3,0x81,0x3C,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,
0xBD,0x00,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,0xBD,0xC3,0xFF,0xFC,0x73,
0x37,0x2F,0xAF,0xDE,0xDF,0xBF,0xAC,0x9B,0xB7,0xB7,0x6C,0x6C,0x6F,0x6F,0xB6,0xB6,
0xDB,0xCB,0xD5,0xAA,0x2F,0x37,0x7B,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,
0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,0xDF,0xDF,0xC1,0xC8,0xDC,
0xFF,0xF8,0xF7,0xEF,0xDF,0xF8,0xF2,0xF2,0xF8,0xFC,0xFE,0xFC,0xFC,0xFE,0xFC,0xF8,
0xF2,0xD2,0xE8,0xF7,0xF8,0xFF,0xDC,0xC8,0xC1,0xC3,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
* 函 数 名 : main
* 函数功能 : 主函数
* 输 入 : 无
* 输 出 : 无
void main(void)
uchar i , j;
uint n;
Lcd12864_Init(); //初始化
Lcd12864_ClearScreen(); //清屏
for (i=0;i<8;i++)
//--设置初始显示开始位置--//
LcdSt7565_WriteCmd(0x40);
//--设置Y坐标--//
LcdSt7565_WriteCmd(0xB0+i);
//--设置X坐标--//
LcdSt7565_WriteCmd(0x10);
LcdSt7565_WriteCmd(0x04);
for(j=0; j<128; j++)
LcdSt7565_WriteData(~pic[n]);
n=n+1;
while (1)
//---重定义关键词---//
#ifndef uchar
#endif
#ifndef uint
#endif
//--定时使用的IO口--//
#define DATA_PORT P0
sbit LCD12864_CS = P3^2;
sbit LCD12864_RSET = P3^3;
sbit LCD12864_RS = P2^6;
sbit LCD12864_RW = P2^7;
sbit LCD12864_RD = P2^5;
//--定义全局函数--//
void LcdSt7565_WriteCmd(cmd);
void LcdSt7565_WriteData(dat);
void Lcd12864_Init();
void Lcd12864_ClearScreen(void);
uchar Lcd12864_Write16CnCHAR(uchar x, uchar y, uchar *cn);
#endif
#include"st7565.h"
* 函 数 名 : LCD12864_WriteCmd
* 函数功能 : 写入一个命令到12864
* 输 入 : cmd
* 输 出 : 无
LCD12864_CS = 0; //chip select,打开片选
LCD12864_RD = 1; //disable read,读失能
LCD12864_RS = 0; //select command,选择命令
LCD12864_RW = 0; //select write,选择写模式
_nop_();
_nop_();
DATA_PORT = cmd; //put command,放置命令
_nop_();
_nop_();
LCD12864_RW = 1; //command writing ,写入命令
* 函 数 名 : LcdSt7565_WriteData
* 函数功能 : 写入一个数据到12864
* 输 入 : dat
* 输 出 : 无
LCD12864_RS = 1; //select data,选择数据
_nop_();
_nop_();
DATA_PORT = dat; //put data,放置数据
_nop_();
_nop_();
LCD12864_RW = 1; //data writing,写数据
* 函 数 名 : LCD12864_Init
* 函数功能 : 初始化12864
* 输 入 : 无
* 输 出 : 无
* 说 明 : LCD12864的命令指令可以查看例程文件夹下的《ST7565p数据手册》
* * 的第51页的位置。
uchar i;
LCD12864_RSET = 0;
for (i=0; i<100; i++);
LCD12864_CS = 0;
LCD12864_RSET = 1;
//----------------Star Initial Sequence-------//
//------程序初始化设置,具体命令可以看文件夹下---//
//--软件初始化--//
LcdSt7565_WriteCmd(0xE2); //reset
for (i=0; i<100; i++); //延时一下
//--表格第8个命令,0xA0段(左右)方向选择正常方向(0xA1为反方向)--//
LcdSt7565_WriteCmd(0xA1); //ADC select segment direction
//--表格第15个命令,0xC8普通(上下)方向选择选择反向,0xC0为正常方向--//
LcdSt7565_WriteCmd(0xC8); //Common direction
//--表格第9个命令,0xA6为设置字体为黑色,背景为白色---//
//--0xA7为设置字体为白色,背景为黑色---//
LcdSt7565_WriteCmd(0xA6); //reverse display
//--表格第10个命令,0xA4像素正常显示,0xA5像素全开--//
LcdSt7565_WriteCmd(0xA4); //normal display
//--表格第11个命令,0xA3偏压为1/7,0xA2偏压为1/9--//
LcdSt7565_WriteCmd(0xA2); //bias set 1/9
//--表格第19个命令,这个是个双字节的命令,0xF800选择增压为4X;--//
//--0xF801,选择增压为5X,其实效果差不多--//
LcdSt7565_WriteCmd(0xF8); //Boost ratio set
LcdSt7565_WriteCmd(0x01); //x4
//--表格第18个命令,这个是个双字节命令,高字节为0X81,低字节可以--//
//--选择从0x00到0X3F。用来设置背景光对比度。---/
LcdSt7565_WriteCmd(0x81); //V0 a set
LcdSt7565_WriteCmd(0x23);
//--表格第17个命令,选择调节电阻率--//
LcdSt7565_WriteCmd(0x25); //Ra/Rb set
//--表格第16个命令,电源设置。--//
LcdSt7565_WriteCmd(0x2F);
//--表格第2个命令,设置显示开始位置--//
LcdSt7565_WriteCmd(0x40); //start line
//--表格第1个命令,开启显示--//
LcdSt7565_WriteCmd(0xAF); // display on
* 函 数 名 : LCD12864_ClearScreen
* 函数功能 : 清屏12864
* 输 入 : 无
* 输 出 : 无
uchar i, j;
for(i=0; i<8; i++)
//--表格第3个命令,设置Y的坐标--//
//--Y轴有64个,一个坐标8位,也就是有8个坐标--//
//所以一般我们使用的也就是从0xB0到0x07,就够了--//
//--表格第4个命令,设置X坐标--//
//--当你的段初始化为0xA1时,X坐标从0x10,0x04到0x18,0x04,一共128位--//
//--当你的段初始化为0xA0时,X坐标从0x10,0x00到0x18,0x00,一共128位--//
//--在写入数据之后X坐标的坐标是会自动加1的,我们初始化使用0xA0所以--//
//--我们的X坐标从0x10,0x00开始---//
//--X轴有128位,就一共刷128次,X坐标会自动加1,所以我们不用再设置坐标--//
LcdSt7565_WriteData(0x00); //如果设置背景为白色时,清屏选择0XFF
* 函 数 名 : LCD12864_Write16CnCHAR
* 函数功能 : 在12864上面书写16X16的汉字
* 输 入 : x, y, cn
* 输 出 : 无
* 说 明 : 该函数可以直接书写字符串,但是书写是从右到左,所以输入的时
* * 侯注意输入。汉字的取模方式请观看文件夹下的《汉字取模软件的
* * 使用说明》
#ifdef CHAR_CODE
#include"charcode.h"
uchar j, x1, x2, wordNum;
//--Y的坐标只能从0到7,大于则直接返回--//
if(y > 7)
return 0;
//--X的坐标只能从0到128,大于则直接返回--//
if(x > 128)
return 0;
y += 0xB0; //求取Y坐标的值
//--设置Y坐标--//
LcdSt7565_WriteCmd(y);
while ( *cn != '\0') //在C语言中字符串结束以‘\0’结尾
//--设置Y坐标--//
x1 = (x >> 4) & 0x0F; //由于X坐标要两句命令,分高低4位,所以这里先取出高4位
x2 = x & 0x0F; //去低四位
//--设置X坐标--//
LcdSt7565_WriteCmd(0x10 + x1); //高4位
LcdSt7565_WriteCmd(0x04 + x2); //低4位
for (wordNum=0; wordNum<50; wordNum++)
//--查询要写的字在字库中的位置--//
if ((CN16CHAR[wordNum].Index[0] == *cn)
&&(CN16CHAR[wordNum].Index[1] == *(cn+1)))
for (j=0; j<32; j++) //写一个字
if (j == 16) //由于16X16用到两个Y坐标,当大于等于16时,切换坐标
//--设置Y坐标--//
LcdSt7565_WriteCmd(y + 1);
//--设置X坐标--//
LcdSt7565_WriteData(CN16CHAR[wordNum].Msk[j]);
x += 16;
}//if查到字结束
} //for查字结束
cn += 2;
} //while结束
return 1;
#endif
