分享一下GY-271 HMC5883L的资料 手册 单片机例程 希望对需要的老哥们有帮助!!!
- #include "reg52.h"
- #include "intrins.h"
- #include "math.h"
- #include "iic.h"
- #include "lcd.h"
- #include "stdio.h"
- u8 ge=0,shi=0,bai=0,qian=0,wan=0; //显示变量
- u8 BUF[8]=0; //数据缓冲区
- //******************************显示在LCD的数据取位********************************//
- void Conversion(u16 temp_data)
- wan=temp_data/10000+0x30 ;
- temp_data=temp_data%10000; //取余运算
- qian=temp_data/1000+0x30 ;
- temp_data=temp_data%1000; //取余运算
- bai=temp_data/100+0x30 ;
- temp_data=temp_data%100; //取余运算
- shi=temp_data/10+0x30 ;
- temp_data=temp_data%10; //取余运算
- ge=temp_data+0x30;
- void main()
- // u16 i;
- int X=0,Y=0,Z=0;
- double Angle_XY=0,Angle_XZ=0,Angle_YZ=0;
- Delay_ms(200);
- Init_Lcd();
- Init_QMC5883();
- Delay_ms(300);
- while(1)
- Multiple_Read_QMC5883(); //连续读取三轴角度数据,存储在BUF中
- //---------显示XY轴
- X=BUF[1] << 8 | BUF[0]; //Combine MSB and LSB of X Data output register 最高有效位
- Y=BUF[3] << 8 | BUF[2]; //Combine MSB and LSB of Y Data output register
- Z=BUF[5] << 8 | BUF[4]; //Combine MSB and LSB of Z Data output register
- if(X>0x7fff)X-=0xffff;
- if(Y>0x7fff)Y-=0xffff;
- if(Z>0x7fff)Z-=0xffff;
- Display_One_Char(0,0,'Q');
- Display_One_Char(1,0,'M');
- Display_One_Char(2,0,'C');
- Display_One_Char(3,0,'5');
- Display_One_Char(4,0,'8');
- Display_One_Char(5,0,'8');
- Display_One_Char(6,0,'3');
- Angle_XY= atan2((double)Y,(double)X) * (180 / 3.14159265) + 180; //计算XY平面角度
- Angle_XY*=10;
- Conversion(Angle_XY); //计算XY平面角度数据和显示
- Display_One_Char(8,0,'X');
- Display_One_Char(9,0,'Y');
- Display_One_Char(10,0,':');
- Display_One_Char(11,0,qian);
- Display_One_Char(12,0,bai);
- Display_One_Char(13,0,shi);
- Display_One_Char(14,0,'.');
- Display_One_Char(15,0,ge);
- Angle_XZ= atan2((double)Z,(double)X) * (180 / 3.14159265) + 180; //计算XZ平面角度
- Angle_XZ*=10;
- Conversion(Angle_XZ); //计算XZ平面角度数据和显示
- Display_One_Char(0,1,'X');
- Display_One_Char(1,1,'Z');
- Display_One_Char(2,1,':');
- Display_One_Char(3,1,qian);
- Display_One_Char(4,1,bai);
- Display_One_Char(5,1,shi);
- Display_One_Char(6,1,'.');
- Display_One_Char(7,1,ge);
- Angle_YZ= atan2((double)Z,(double)Y) * (180 / 3.14159265) + 180; //计算YZ平面角度
- Angle_YZ*=10;
- Conversion(Angle_YZ); //计算YZ平面角度数据和显示
- Display_One_Char(8,1,'Y');
- Display_One_Char(9,1,'Z');
复制代码- //***************************************
- // HMC5883 51串口测试程序
- // 使用单片机STC89C51
- // 晶振:11.0592M
- // 显示:PC串口
- // 编译环境 Keil uVision2
- // 参考宏晶网站24c04通信程序
- // 时间:2011年3月1日
- #include <REG51.H>
- #include <math.h> //Keil library
- #include <stdio.h> //Keil library
- #include <INTRINS.H>
- #define uchar unsigned char
- #define uint unsigned int
- //使用的端口,请按照以下接线
- #define DataPort P0 //LCD1602数据端口
- sbit SCL=P1^0; //IIC时钟引脚定义
- sbit SDA=P1^1; //IIC数据引脚定义
- #define SlaveAddress 0x3C //定义器件5883在IIC总线中的从地址
- typedef unsigned char BYTE;
- typedef unsigned short WORD;
- BYTE BUF[8]; //接收数据缓存区
- uchar ge,shi,bai,qian,wan; //显示变量
- int dis_data; //变量
- void delay(unsigned int k);
- void Init_HMC5883(void); //初始化5883
- void conversion(uint temp_data);
- void Single_Write_HMC5883(uchar REG_Address,uchar REG_data); //单个写入数据
- //uchar Single_Read_HMC5883(uchar REG_Address); //单个读取内部寄存器数据
- void Multiple_Read_HMC5883(); //连续的读取内部寄存器数据
- //以下是模拟iic使用函数-------------
- void Delay5us();
- void Delay5ms();
- void HMC5883_Start();
- void HMC5883_Stop();
- void HMC5883_SendACK(bit ack);
- bit HMC5883_RecvACK();
- void HMC5883_SendByte(BYTE dat);
- BYTE HMC5883_RecvByte();
- void HMC5883_ReadPage();
- void HMC5883_WritePage();
- //串口初始化
- //9600 bps @ 11.059 MHz
- void init_uart()
- TMOD=0x21;
- TH1=0xfd;
- TL1=0xfd;
- SCON=0x50;
- PS=1; //串口中断设为高优先级别
- TR0=1; //启动定时器
- TR1=1;
- ET0=1; //打开定时器0中断
- ES=1;
- //*********串口数据发送******************
- void SeriPushSend(uchar send_data)
- SBUF=send_data;
- while(!TI);TI=0;
- unsigned int i,j;
- for(i=0;i<k;i++)
- for(j=0;j<121;j++)
- 延时5微秒(STC90C52RC@12M)
- 不同的工作环境,需要调整此函数,注意时钟过快时需要修改
- 当改用1T的MCU时,请调整此延时函数
- void Delay5us()
- _nop_();_nop_();_nop_();_nop_();
- 延时5毫秒(STC90C52RC@12M)
- 不同的工作环境,需要调整此函数
- void Delay5ms()
- WORD n = 560;
- while (n--);
- 起始信号
- SDA = 1; //拉高数据线
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SDA = 0; //产生下降沿
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- 停止信号
- SDA = 0; //拉低数据线
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SDA = 1; //产生上升沿
- Delay5us(); //延时
- 发送应答信号
- 入口参数:ack (0:ACK 1:NAK)
- SDA = ack; //写应答信号
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- 接收应答信号
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- CY = SDA; //读应答信号
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- return CY;
- 向IIC总线发送一个字节数据
- BYTE i;
- for (i=0; i<8; i++) //8位计数器
- dat <<= 1; //移出数据的最高位
- SDA = CY; //送数据口
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- HMC5883_RecvACK();
- 从IIC总线接收一个字节数据
- BYTE i;
- BYTE dat = 0;
- SDA = 1; //使能内部上拉,准备读取数据,
- dat <<= 1;
- SCL = 1; //拉高时钟线
- Delay5us(); //延时
- dat |= SDA; //读数据
- SCL = 0; //拉低时钟线
- Delay5us(); //延时
- return dat;
- HMC5883_Start(); //起始信号
- HMC5883_SendByte(SlaveAddress); //发送设备地址+写信号
- HMC5883_SendByte(REG_Address); //内部寄存器地址,请参考中文pdf
- HMC5883_SendByte(REG_data); //内部寄存器数据,请参考中文pdf
- HMC5883_Stop(); //发送停止信号
- //********单字节读取内部寄存器*************************
- uchar Single_Read_HMC5883(uchar REG_Address)
- { uchar REG_data;
- HMC5883_SendByte(REG_Address); //发送存储单元地址,从0开始
- HMC5883_SendByte(SlaveAddress+1); //发送设备地址+读信号
- REG_data=HMC5883_RecvByte(); //读出寄存器数据
- HMC5883_SendACK(1);
- HMC5883_Stop(); //停止信号
- return REG_data;
- //连续读出HMC5883内部角度数据,地址范围0x3~0x5
- void Multiple_read_HMC5883(void)
- { uchar i;
- HMC5883_SendByte(0x03); //发送存储单元地址,从0x3开始
- for (i=0; i<7; i++) //连续读取6个地址数据,存储中BUF
- BUF[i] = HMC5883_RecvByte(); //BUF[0]存储0x32地址中的数据
- if (i == 6)
- HMC5883_SendACK(1); //最后一个数据需要回NOACK
- else
- HMC5883_SendACK(0); //回应ACK
- Delay5ms();
- //初始化HMC5883,根据需要请参考pdf进行修改****
- void Init_HMC5883()
- Single_Write_HMC5883(0x02,0x00); //
- Single_Write_HMC5883(0x01,0xE0); //
- //主程序********
- void main()
- { // bit sign_bit;
- unsigned int i;
- int x,y,z;
- double angle;
- delay(100);
- init_uart();
- Init_HMC5883();
- while(1) //循环
- Multiple_Read_HMC5883(); //连续读出数据,存储在BUF中
- x = BUF[0] << 8 | BUF[1];
- y = BUF[4] << 8 | BUF[5];
- z = BUF[2] << 8 | BUF[3];
- angle= atan2((double)y,(double)x) * (180 / 3.14159265) + 180; // angle in degrees
- conversion(angle); //计算数据和显示
- SeriPushSend(bai);
- SeriPushSend(shi);
- SeriPushSend(ge);
- SeriPushSend(0x0d);
- SeriPushSend(0x0a);
- for (i=0;i<10000;i++); //延时
GY-271 QMC5883L电子指南针罗盘模块 三轴磁场传感器(1).zip
(3.18 MB, 下载次数: 32)
