查看: 2546|回复: 4
怎么修改单片机程序可以使步进电机在满足条件后正转和反转180°
回帖奖励 10 黑币 回复本帖可获得 10 黑币奖励! 每人限 1 次
ID:757095 发表于 2020-5-22 00:47 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
  1. #include "include.h"
  2. #define   uchar unsigned char
  3. #define   uint unsigned int
  4. #define   DataPort P2
  5. #define MotorData P0
  6. #define GapValue 305
  7. uchar phasecw[4] ={0x08,0x04,0x02,0x01};
  8. uchar phaseccw[4]={0x01,0x02,0x04,0x08};
  9. sbit LCM_RS=P0^7;
  10. sbit LCM_RW=P0^6;
  11. sbit LCM_EN=P0^5;
  12. sbit IN1 = P3^4;
  13. sbit IN2 = P3^5;
  14. sbit IN3 = P3^6;
  15. sbit IN4 = P3^7;
  16. sbit HX711_DOUT=P3^3;
  17. sbit HX711_SCK=P3^2;
  18. unsigned long Time_Cont = 0;
  19. unsigned char PollCount = 0;
  20. unsigned int qupi=0;
  21. long weight_wuti = 0;
  22. long weight_wutinew = 0;
  23. unsigned long weight_maopi = 0;
  24. unsigned long weight_maopi_0 = 0;
  25. unsigned char tx_buf[5];
  26. void Get_maopi();
  27. void Get_weight();
  28. void Delay__hx711_us(void);
  29. unsigned long HX711_Read(void);
  30. void Delay_ms(unsigned int n)
  31. {
  32.         unsigned int  i,j;
  33.         for(i=0;i<n;i++)
  34.                 for(j=0;j<121;j++);
  35. }
  36. void Delay__hx711_us(void)
  37. {
  38.         _nop_();
  39.         _nop_();
  40. }
  41. unsigned long HX711_Read(void)
  42. {
  43.         unsigned long count;
  44.         unsigned char i;
  45.           HX711_DOUT=1;
  46.                 Delay__hx711_us();
  47.           HX711_SCK=0;
  48.           count=0;
  49.           while(HX711_DOUT);
  50.           for(i=0;i<24;i++)
  51.         {
  52.                   HX711_SCK=1;
  53.                   count=count<<1;
  54.                         HX711_SCK=0;
  55.                   if(HX711_DOUT)
  56.                         count++;
  57.         }
  58.         HX711_SCK=1;
  59.         count=count^0x800000;
  60.         Delay__hx711_us();
  61.         HX711_SCK=0;
  62.         return(count);
  63. }
  64. void Get_Weight()
  65. {
  66.         weight_wuti = HX711_Read();
  67.         weight_wuti = weight_wuti - weight_maopi;
  68.
  69.
  70.
  71.         weight_wuti = (unsigned int)((weight_wuti)/GapValue);
  72. if(weight_wuti>5000)weight_wuti=0;
  73.                 tx_buf[0]= weight_wuti/1000;
  74.                 tx_buf[1]= weight_wuti/100%10;
  75.                 tx_buf[2]= weight_wuti%100/10;
  76.                 tx_buf[3]= weight_wuti%10;
  77. }
  78. void Get_maopi()
  79. {
  80.         unsigned char clear;
  81. mm:        weight_maopi_0 = HX711_Read();
  82.         for(clear=0;clear<2;clear++)
  83.         {
  84.                 Delay_ms(200);
  85.         }
  86.         weight_maopi = HX711_Read();
  87.         if(weight_maopi/GapValue!=weight_maopi_0/GapValue)
  88.         goto mm;
  89. }
  90. void Timer0Interrupt(void)  interrupt 1
  91. {
  92.         TH0 = (65536 - 20000)/256;
  93.         TL0 = (65536 - 20000)%256;
  94.         PollCount++;
  95.         if(PollCount==50)
  96.         {
  97.           PollCount=0;
  98.
  99.         }
  100. }
  101. void positive(unsigned int time)
  102. {
  103.         IN1 = 1;IN2 = 0; IN3 = 0;IN4 = 0;
  104.         Delay_ms(time);
  105.         IN1 = 0;IN2 = 1; IN3 = 0;IN4 = 0;
  106.         Delay_ms(time);
  107.         IN1 = 0;IN2 = 0; IN3 = 1;IN4 = 0;
  108.         Delay_ms(time);
  109.         IN1 = 0;IN2 = 0; IN3 = 0;IN4 = 1;
  110.         Delay_ms(time);
  111. }
  112. unsigned int count;
  113. void run(unsigned int time,unsigned int k)
  114. {
  115.         for(count=0;count<time;count++)
  116.                 positive(k);
  117. }
  118. void MotorCW(void)
  119. {
  120. uchar i;
  121. for(i=0;i<4;i++)
  122.   {
  123.    MotorData=phasecw[i];
  124.    Delay_ms(4);
  125.   }
  126. }
  127. void MotorCCW(void)
  128. {
  129. uchar i;
  130. for(i=0;i<4;i++)
  131.   {
  132.    MotorData=phaseccw[i];
  133.    Delay_ms(4);
  134.   }
  135. }
  136. void MotorStop(void)
  137. {
  138. MotorData=0x00;
  139. }
  140. void main()
  141. {
  142.   InitLcd();
  143.         Get_maopi();
  144.         DisplayOneChar(0,0,'W');
  145.         DisplayOneChar(1,0,'E');
  146.         DisplayOneChar(2,0,'I');
  147.         DisplayOneChar(3,0,'G');
  148.         DisplayOneChar(4,0,':');
  149.
  150.         DisplayOneChar(0,1,'N');
  151.         DisplayOneChar(1,1,'U');
  152.         DisplayOneChar(2,1,'M');
  153.         DisplayOneChar(3,1,'B');
  154.         DisplayOneChar(4,1,':');
  155.
  156.         while(1)
  157.         {
  158.                 Get_weight();
  159.                 DisplayOneChar(5,0,'0'+tx_buf[0]);
  160.                 DisplayOneChar(6,0,'0'+tx_buf[1]);
  161.                 DisplayOneChar(7,0,'0'+tx_buf[2]);
  162.                 DisplayOneChar(8,0,'0'+tx_buf[3]);
  163.                 DisplayOneChar(9,0,'G');
  164.                 if((weight_wutinew-weight_wuti>10)||(weight_wuti-weight_wutinew>10))
  165.                 {
  166.                                 weight_wutinew        = weight_wuti;
  167.
  168.
  169.
  170.                                         if((weight_wuti>0)&&(weight_wuti<100)){DisplayOneChar(5,1,'1');MotorCW();
  171.
  172.                                   MotorStop();
  173.
  174.                           else if(weight_wuti>100){DisplayOneChar(5,1,'2'); MotorCCW(); }
  175.                                   MotorStop();
  176.
  177.
  178.
  179.                 }
  180.                 Delay_ms(2);
  181.         }
  182. }
  183. /*******************************/
  184. void WaitForEnable(void)
  185. {
  186.                 DataPort=0xff;
  187.                 LCM_RS=0;LCM_RW=1;_nop_();
  188.                 LCM_EN=1;_nop_();_nop_();
  189.                 while(DataPort&0x80);
  190.                 LCM_EN=0;
  191. }
  192. /*******************************/
  193. void WriteCommandLCM(uchar CMD,uchar Attribc)
  194. {
  195.                 if(Attribc)WaitForEnable();
  196.                 LCM_RS=0;LCM_RW=0;_nop_();
  197.                 DataPort=CMD;_nop_();
  198.                 LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  199. }
  200. /*******************************/
  201. void WriteDataLCM(uchar dataW)
  202. {
  203.                 WaitForEnable();
  204.                 LCM_RS=1;LCM_RW=0;_nop_();
  205.                 DataPort=dataW;_nop_();
  206.                 LCM_EN=1;_nop_();_nop_();LCM_EN=0;
  207. }
  208. /***********************************/
  209. void InitLcd()
  210. {
  211.                 WriteCommandLCM(0x38,1);
  212.                 WriteCommandLCM(0x08,1);
  213.                 WriteCommandLCM(0x01,1);
  214.                 WriteCommandLCM(0x06,1);
  215.                 WriteCommandLCM(0x0c,1);
  216. }
  217. /***********************************/
  218. void DisplayOneChar(uchar X,uchar Y,uchar DData)
  219. {
  220.                 Y&=1;
  221.                 X&=15;
  222.                 if(Y)X|=0x40;
  223.                 X|=0x80;
  224.                 WriteCommandLCM(X,0);
  225.                 WriteDataLCM(DData);
  226. }
ID:440403 发表于 2020-5-22 08:13 | 只看该作者
具体要看步进电机上面的驱动器,一步是多少度,一个脉冲是半步还是一步,单片机只是负责发脉冲
ID:757095 发表于 2020-5-22 10:49 | 只看该作者
看了一下,只需解决正反转就行,度数可以随时调整
ID:94031 发表于 2020-5-22 13:13 | 只看该作者
把你现在的现象描述一下。这一句MotorStop(); 要屏蔽掉,否则每次都要停一下。
ID:758414 发表于 2020-5-23 12:08 | 只看该作者
MotorStop(); 要屏蔽掉
